POV-Ray : Newsgroups : povray.general : Map Mollweide projection (elliptical) onto sphere Server Time
10 Oct 2025 22:01:57 EDT (-0400)
  Map Mollweide projection (elliptical) onto sphere (Message 1 to 10 of 13)
Subject: Map Mollweide projection (elliptical) onto sphere
Date: 7 Nov 2011 05:55:01
Message: <web.4eb7b7752242f00631dc6fa00@news.povray.org>
I have an image [1] of a spherical surface that I want to map onto a sphere, but
it is a Mollweide projection. I tried to convert it to a rectangular Mercator
projection (is that even the right one?) with Mathematica [2], but it doesn't
really work. I do get a rectangular image which kind of looks right, but when I
use the texture in Povray with
pigment { image_map { png "text.png" map_type 1 } }
the edges don't seem to match up and the texture looks distorted around the
poles. In the end, I want to create something similar to this [3]. What can I
do?
Adrian
[1] http://map.gsfc.nasa.gov/media/101080/101080_7yrFullSky_WMAP_1280B.png (I
cropped it properly, of course)
[2] invmerc[{x_, y_}] := {ArcTan[Sinh[y]], x};
theta2[phi_] := theta2[phi] =
   FindRoot[2 th + Sin[2 th] == Pi Sin[phi], {th, 0}][[1, 2]];
moll[{phi_, lambda_}] := {2 Sqrt[2] lambda Cos[theta2[phi]]/Pi,
   Sqrt[2] Sin[theta2[phi]]};
merc2moll[p_] := moll[invmerc[p]];
result = ImageTransformation[Import["text.png"], merc2moll,
   DataRange -> Sqrt[2] {{-2, 2}, {-1, 1}}];
Export["text-merc.png", result];
[3] http://particle.physics.ucdavis.edu/Graphics/rotate/wmap_movie.gif
Subject: Re: Map Mollweide projection (elliptical) onto sphere
Date: 7 Nov 2011 08:36:40
Message: <4eb7dee8$1@news.povray.org>
I think Mercator is cylindrical so you could try map_type 2.
Date: 7 Nov 2011 10:10:00
Message: <web.4eb7f3e85ab24bf331dc6fa00@news.povray.org>
Unfortunately, that doesn't help, even after I adjust the scale and translate
the sphere such that it goes from y=0 to y=1, as required by map_type 2. The
distortions are still present.
Yes, I am not entirely sure that this is the case. My Mathematica implementation
of the conversion may be faulty (even though I followed mathworld [1]), is there
a standard way to deal with this? Some UNIX tool or even a built-in feature of
povray?
Adrian
[1] http://mathworld.wolfram.com/MercatorProjection.html
http://mathworld.wolfram.com/MollweideProjection.html
Date: 7 Nov 2011 12:09:18
Message: <4eb810be$1@news.povray.org>
Am 07.11.2011 11:49, schrieb Adrian:
> do?
You want to convert the image to an "equirectangular projection" (see
http://en.wikipedia.org/wiki/Equirectangular_projection); that'll allow
you to use map type 1.
Date: 7 Nov 2011 12:17:24
Message: <4eb812a4@news.povray.org>
> povray?
There appears to be a unix tool at
http://www.users.globalnet.co.uk/~arcus/mmps/
I think the unprojected latlong format will be the
correct one for map_type 1.
Regarding the WMAP data it seems they already provide it in latlong
format for the "Science on a Sphere" 3d visualization system, so you
might be able to simply use these:
http://lambda.gsfc.nasa.gov/product/map/current/sos/7year/
Date: 10 Nov 2011 09:55:01
Message: <web.4ebbe3485ab24bf331dc6fa00@news.povray.org>
Thanks, I guess I was over-complicating things! Also thanks to Christian for the
hint at Matthew's "project". Unfortunately it yields a wrong result for my case.
I am considering letting him know about it, because that would have been a great
tool otherwise. I appreciate the hint at the WMAP data as well, but I was
curious on how to handle this for future projects as well.
For the record, since Mathematica didn't yield a satisfactory result for
whatever reason, I wrote a small Python script using SciPy that takes a cropped
*ppm Mollweide projection and converts it to plate carree, which can be mapped
onto a sphere by Povray just fine. Of course, it is much slower than a C/C++
solution, but it's fast enough for my purposes (around 2m on my PC for a
2048x1024 image). If anyone wants to use it, see below for the source.
Adrian
#!/usr/bin/python
import numpy as np
from scipy import misc
import sys
infile = "wmap.ppm"
outfile = "wmap2.ppm"
arr = misc.imread(infile)
result = np.empty(arr.shape)
height, width, depth = arr.shape # Backwards but correct
print "Dimensions: %ix%i" % (width, height)
class memoized(object):
   def __init__(self, func):
      self.func = func
      self.cache = {}
   def __call__(self, *args):
      try:
         return self.cache[args]
      except KeyError:
         value = self.func(*args)
         self.cache[args] = value
         return value
@memoized #Improves runtime by factor of 2 easily
def theta(phi):
    # First guess for newton method
    xn = 0
    old = xn + 1.
    while abs(xn - old)>1e-6:
        old = xn
        xn = xn - (xn + np.sin(xn) - np.pi * np.sin(phi)) / (1 + np.cos(xn))
    return xn / 2.
def mollweide(x, y):
    th = theta(y)
    return np.sqrt(8) * x * np.cos(th) / np.pi, np.sqrt(2) * np.sin(th)
def img2coord(a, b):
    return (a * 1. / width - .5) * 2 * np.pi, (b * 1. / height - .5) * np.pi
def coord2img(x, y):
    # Try to stay inside ellipse to minimize background effects
    xround = yround = np.floor
    if x<0: xround = lambda z: -np.floor(-z)
    if y<0: yround = lambda z: -np.floor(-z)
    return (xround((x / (2 * np.sqrt(8)) + .5) * width),
            yround((y / (2 * np.sqrt(2)) + .5) * height))
for a in range(width):
    sys.stdout.write("\r%i%%" % ( 100 * a / width ))
    sys.stdout.flush()
    for b in range(height):
        x, y = img2coord(a, b)
        x, y = mollweide(x, y)
        x, y = coord2img(x, y)
        result[b, a] = arr[y-1, x-1]
misc.imsave(outfile, result)
sys.stdout.write("\nDone\n")
Date: 16 Dec 2011 16:55:01
Message: <web.4eebbd2c5ab24bf32cf1bdcc0@news.povray.org>
Nice solution.  You could also use GDAL utilities to handle this-- which are
written in C++ (and also have APIs for Python, etc).
Best,
Steve
> Adrian
> #!/usr/bin/python
> import numpy as np
> import sys
> infile = "wmap.ppm"
>       self.func = func
>       self.cache = {}
>       try:
>       except KeyError:
>          return value
> def theta(phi):
>     xn = 0
>     old = xn + 1.
>         old = xn
>     return xn / 2.
>     th = theta(y)
>     sys.stdout.flush()
Date: 22 Apr 2013 16:20:05
Message: <web.51759aac5ab24bf3c83525700@news.povray.org>
The problem is, the python script does not work on my PC. Is there anything I
need to modify in the source code, for example, if the width is 2000px and the
height 1000px, or is the code ready to use? I get a synatx error when I run the
script 1 to 1: http://img28.imageshack.us/img28/1204/screenshotj.gif
Date: 22 Apr 2013 17:59:44
Message: <5175b2d0$1@news.povray.org>
hing I
and the
 run the
	That's a Python 2 script and you're trying to run it on a Python 3
install. They are not compatible...
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 23 Apr 2013 15:00:01
Message: <web.5176d9135ab24bf3593487030@news.povray.org>
I now installed Python 2.6 and the numpy, scipy and imread modules from
http://www.lfd.uci.edu/~gohlke/pythonlibs
but it still says
Traceback (most recent call last):
  File "C:\Users\Yukterez\Documents\pythonscriptcmb.py", line 9, in <module>
AttributeError: 'module' object has no attribute 'imread'
why?
