POV-Ray : Newsgroups : povray.general : How to quick filling an array Server Time
11 Oct 2025 00:57:20 EDT (-0400)
  How to quick filling an array (Message 1 to 4 of 4)
Subject: How to quick filling an array
Date: 6 Oct 2011 19:30:00
Message: <web.4e8e3901b22b0664a3bfeb720@news.povray.org>
Hi people,
I've defined an array, like this:
#declare Detail=40;
#declare VoxelSpace=array[Detail+1][Detail+1][Detail+1];
to fill it, I did this:
#debug "Filling...\n"
#declare YI=0;
 #while (YI<Detail)
 #declare ZI=0;
 #while (ZI<Detail)
  #declare XI=0;
   #while (XI<Detail)
     #declare VoxelSpace[XI][YI][ZI]=0;
   #declare XI=XI+1;
  #declare ZI=ZI+1;
 #declare YI=YI+1;
to fill an array on initialising-time, using "Array Initializers" the docs give
me something like this:
#declare Digits =
 array[4][10]
  {7,6,7,0,2,1,6,5,5,0},
  {1,2,3,4,5,6,7,8,9,0},
  {0,9,8,7,6,5,4,3,2,1},
  {1,1,2,2,3,3,4,4,5,5}
Is there a way to fill an array, using only ONE line, saying that ALL values are
=0?
Best rgds,
Holger
Subject: Re: How to quick filling an array
Date: 7 Oct 2011 16:07:38
Message: <4e8f5c0a@news.povray.org>
> Hi people,
> #declare Detail=40;
> #declare YI=0;
>   #while (YI<Detail)
>   #declare ZI=0;
>   #while (ZI<Detail)
>    #declare XI=0;
>     #while (XI<Detail)
>     #declare XI=XI+1;
>     #end
>    #declare ZI=ZI+1;
>    #end
>   #declare YI=YI+1;
>   #end
> #declare Digits =
>   array[4][10]
This can be writen on one long line.
> =0?
> Best rgds,
> Holger
You can't quick fill all element of an array using only one instruction.
Any element must be explicitely given a content before you can get it's
content.
As you probably don't need the indexing variables outside the
initialisation, and you surely don't need to keep the final values, you
can use #local.
That way, the variables will not exist once the loops are terminated.
Date: 7 Oct 2011 17:00:00
Message: <web.4e8f6738bbede7878641e0c0@news.povray.org>
> can use #local.
This is true of macros and include files.  It does not apply to loops.
Try this scene file:
_________________________________________
#declare MyArray = array[5][10];
#local I = 0;
#while (I < 5)
   #local J = 0;
   #while (J < 10)
      #declare MyArray[I][J] = 0;
      #local J = J + 1;
   #local I = I + 1;
text
{  ttf "cyrvetic.ttf" str(I,0,1) 0.001, 0
   translate <-1, 0.2, 2>
   pigment { rgb 1 }
   finish { ambient 1 }
text
{  ttf "cyrvetic.ttf" str(J,0,1) 0.001, 0
   translate <-1, -0.8, 2>
   pigment { rgb 1 }
The identifiers I and J can be referenced even after the loops are closed.  J
can be referenced even though it's declared only inside the I loop.
Date: 9 Oct 2011 18:30:01
Message: <web.4e921fecbbede78ce9345340@news.povray.org>
Wow, that's surprising. How would #declare and #local be different in "keeping
things around"?
