POV-Ray : Newsgroups : povray.general : Availability of older povray 3.7 beta builds? Server Time
30 Sep 2024 10:21:06 EDT (-0400)
  Availability of older povray 3.7 beta builds? (Message 1 to 7 of 7)
Subject: Availability of older povray 3.7 beta builds?
Date: 3 Sep 2011 16:45:00
Message: <web.4e6291a8bb55f64590073930@news.povray.org>
Some major tech sites use povray for their CPU benchmarks. However, they don't
necessarily use the latest builds. For example:
http://www.anandtech.com/bench/CPU/40
This site is using beta 23, and their numbers seem unusually high. For example,
an Athlon II x4 630 is reported on their site to be 2227 pixels/second. However,
when I run RC3 on my computer (same CPU), I only get 706 pixels/second. I just
want to see how accurate their numbers are.
Subject: Re: Availability of older povray 3.7 beta builds?
Date: 3 Sep 2011 17:04:08
Message: <4e629648$1@news.povray.org>
You cannot compare different betas and their results. Use the current
release candidate for comparisons. Old betas are not available.
	Thorsten
Date: 3 Sep 2011 20:38:19
Message: <4e62c87b$1@news.povray.org>
The key question is:
Do they use the same scene as you are? With the same options?
Date: 3 Sep 2011 22:30:01
Message: <web.4e62e1d34c3150f590073930@news.povray.org>
As far as I remember they're using the benchmark menu option.
Date: 4 Sep 2011 03:40:36
Message: <4e632b74$1@news.povray.org>
>> don't
>> example,
>> However,
>> just
No, that question is not relevant. You cannot compare different betas. No
knowledge of any option or scene settings can change this. That is all.
	Thorsten, POV-Team
Date: 4 Sep 2011 03:42:52
Message: <4e632bfc$1@news.povray.org>
Le 04/09/2011 04:26, jhu nous fit lire :
Benchmark was in a somehow-light-version in the previous beta (as some
features were not yet fully implemented), so comparing between beta is
not ok.
Just my 0.02€.
And for added tax-value, they are not specifying the compiler.
I got different result between intel and gnu for my 980X:
icpc around 2016 PPS, g++ around 1691 PPS
(these result are bullshit: with 12 threads, icpc take 2:10, g++ take
2:35, but not all threads are still running near the end)
At least with these data, you can adjust the 6424 (that's 40 seconds,
yes, I got to perform that with gnu on earlier beta, as far as I
remember) { with the 1691.)
So their 2227 should be 2227*1691/6424 == 586.
Which is not your result because *you cannot compare between beta*.
Date: 4 Sep 2011 07:26:15
Message: <4e636057$1@news.povray.org>
>> they don't
>> example,
AFAIK Most folks doing "official" benchmarking use the built-in version
for testing ... a while back (2010/08/26 - 2010/12/20) changes #5105,
#5129, #5255, and #5280 were efforts to synchronize the distribution
scene file and the built-in version. Also (as some others have
mentioned) there are more than several reasons that make comparing
results with "older" versions like comparing apples and oranges ;-)
