POV-Ray : Newsgroups : povray.general : Can't get light_source to work properly (extremely simple scene) Server Time
11 Oct 2025 05:45:47 EDT (-0400)
  Can't get light_source to work properly (extremely simple scene) (Message 1 to 4 of 4)
Subject: Can't get light_source to work properly (extremely simple scene)
Date: 23 Apr 2011 07:15:01
Message: <web.4db2b3ebd06940e624c275de0@news.povray.org>
I get nearly the same result regardless of whether I set the cam at z=-35 or
z=-50. Worse, I cannot get the arrows to be illuminated properly, leaving the
arrows as black objects against the white background.
I copied the light source from the woodbox.pov sample scene. There must be
an obvious blunder that I made.
I use PoVRay 3.62
//updownarrows.pov
background { White }
   location <14 0, -35> //-35 or -50, nearly same result (too close)
   direction <14, 0,  2.25>
   right x*1.33
   look_at <0,0,0>
#declare Dist=180.0;
light_source {< 0, 2.5, -10> color White //-50, 25, -50
     fade_distance Dist fade_power 2}
#declare downarrow = union
   cylinder
       <0,0,0>,<0,4,0>,2
       color Green
   cone //hollow?
       <0,0,0>3,<0,-2,0>,0.3
       color Green
object {downarrow
        color Green
object {downarrow
        color Blue
        translate x*6
        rotate x*180
        translate y*2
Subject: Re: Can't get light_source to work properly (extremely simple scene)
Date: 23 Apr 2011 07:39:06
Message: <4db2ba5a@news.povray.org>
On 23/04/2011 12:14 PM, MagicMojo wrote:
Hi, If you look in the message pane you will get a hint to what is
wrong. "color" must be in a pigment which must be in a texture. Sp try this:
//updownarrows.pov
    location <14 0, -235> //-35 or -50, nearly same result (too close)
    right x*1.33
    look_at <0,0,0>
    cylinder
        <0,0,0>,<0,4,0>,2
texture { pigment  {    color Green     } }
    cone //hollow?
object {downarrow
object {downarrow
  texture {   pigment  {       color Blue      }  }
         translate x*6
         rotate x*180
         translate y*2
Regards
Date: 23 Apr 2011 23:36:46
Message: <4db39ace$1@news.povray.org>
> I use PoVRay 3.62
In this case, there is no real difference between version 3.0 and 3.7.
This:
direction<14, 0,  2.25>
can causes some problem.
The direction of your camera is rather large, making it act like a
telephoto with a narrow field of view. You have an horizontal field of
view of 1.33 units (center to right side) at about 14.18 unit from the
camera location. This explains why moving the camera from -35 to -50
don't causes much change.
The use of look_at make the orientation of the direction vector
unimportant, only it's lenght mathers.
Beter to use "direction z" or "direction<0,0,1>". Once everything is
correctly placed, you can zoom by changing the lenght of the direction
vector or by using the "angle" keyword.
As you apply you colours when you use your object, why do you set it to
Green when you declare it? In your original code, both arrows will have
the same colour, that applied in the #declare, not the one applyed in
the object statement.
You don't need to use the keyword "color".
Instead, you should use "pigment{...}"
    cylinder
        <0,0,0>,<0,4,0>,2
    cone
        <0,0,0>3,<0,-2,0>,0.3 pigment{Red}
    }// this makes the tip red independently of the rest
}// NO pigment in the declare itself
object {downarrow
         pigment{ Green}
}//Green shaft and red tip arrow.
When using fading light, you are beter using shorter fade_distance and
increase the intensity of the light correspondingly.
Change Dist to 18 or even 1.
With a Dist = 18, use White*100 in your light_source.
If you use Dist = 1, then you should use White*32400.
Date: 23 Apr 2011 23:45:56
Message: <4db39cf4$1@news.povray.org>
> this:
> //updownarrows.pov
> camera {
> right x*1.33
> look_at <0,0,0>
> cylinder
> <0,0,0>,<0,4,0>,2
> cone //hollow?
And now, the arrows will ALWAYS be green!
> object {downarrow
> object {downarrow
> translate x*6
> rotate x*180
> translate y*2
You should rotate before you relocate. Otherwise, it will orbitate
around the origin.
In this case, I'd rather use this construct:
union{// create a double pointed arrow
object{downarrow pigment{Green}}
oblect{downarrow pigment{Blue} scale<1, -1, 1> //mirror it verticaly
// add some transpate if needed
}// you can move it as one unit
The name and the 180 degree rotation seems to imply that you want a
double pointed arrow.
