POV-Ray : Newsgroups : povray.general : How to "solidify" edge of clipped mesh2 surface? Server Time
25 Dec 2025 01:57:53 EST (-0500)
  How to "solidify" edge of clipped mesh2 surface? (Message 1 to 8 of 8)
Subject: How to "solidify" edge of clipped mesh2 surface?
Date: 30 Jan 2011 00:15:01
Message: <web.4d44f37b6c17394ca1623e690@news.povray.org>
I have a closed mesh2 surface (roughly spherical), clipped by a plane. Viewed
from a bit below the clipping plane, it looks sort of like an open hemisphere.
I would like to make a (CSG-like) solid band, or tube/pipe/cylinder, that runs
along the *edge* where the plane and the mesh2 intersect.
I've been able to get the slab corresponding to the opening (intersection with a
very thin box and the mesh2), and a plane-like slab with the opening hole
cut-out (difference), but I cannot get just the edge (with some thickness, so
you can see it!).
Suggestions? Thanks!
David
Subject: Re: How to "solidify" edge of clipped mesh2 surface?
Date: 30 Jan 2011 16:13:36
Message: <4d45d480@news.povray.org>
> you can see it!).
> David
As your mesh is roughly spherical, you may be able to make a difference
using it this way:
Add an inside vector to the mesh.
Use a difference of the mesh, a slightly scaled down copy of the mesh,
using a scale statement, and a box or plane.
It can work as you seem so have a totaly convexe and relatively simple
overall shape.
Date: 30 Jan 2011 18:20:01
Message: <web.4d45f2139b656e04a1623e690@news.povray.org>
Thanks, Alain.
I do have already an inside vector (<0,0,1>) in my mesh2 declaration. I have
also tried various differences, with the noted results:
// Align clipping box at bottom of cut-off mesh2 surface:
#declare TestBox = box {<0.5,0.5,0.5>, <-0.5,-0.5,-0.5> scale <100,100,0.1>
translate Surface_ClipPlane + <0,0,-0.05>};
// The mesh2, with its bottom clipped off:
#declare test_clipped_surf = object {Committor_50_Volmap clipped_by
{MapBoundsPlane} bounded_by {MapBoundsBoxBig}};
// Texture for all TESTOBJ*
#declare T_TEST = texture { pigment { color rgb <0,0,1>}};
// RESULT: Slab filling just the bottom "opening" of surface:
#declare TESTOBJ = intersection {object {TestBox} object{test_clipped_surf}};
// RESULT: Slab with a hole in middle (inverse of TESTOBJ):
#declare TESTOBJ2 = difference {object {TestBox} object{test_clipped_surf}};
// RESULT: Adds a small ring at bottom edge of cut surface, I guess because
//         the (semi-transparent) surface is duplicated. Attempt to force
//         force the color to opaque dark blue fails (mesh2 has a texture
//         declared in it already).
#declare TESTOBJ3 = object{test_clipped_surf #local T_Committor_50_Surface =
texture { pigment { color rgb <0,0,1>}}; texture {T_Committor_50_Surface}
        clipped_by {TestBox} };
// RESULT: Looks like TESTOBJ2:
#declare TESTOBJ4 = intersection {object {TESTOBJ scale 1.001} object{TESTOBJ
scale 0.999}};
// RESULT: Just wierd edge effects:
#declare TESTOBJ5 = intersection {object {TESTOBJ scale 1.002} object{TESTOBJ2
scale 0.998}};
Am I doing the differencing wrong? Thanks!
Dave
Date: 31 Jan 2011 15:33:30
Message: <4d471c9a@news.povray.org>
>> that runs
> using it this way:
> overall shape.
Although it won't produce a rounded edge, an extension to your idea
could involve an intersection of several offset copies of the mesh,
differenced from the original mesh. This would be similar to the
"thicken" feature of some mesh modelers. Twelve copies could be used in
an icosaherdal offset pattern, or better yet, a geodesic dome with many
vertices. It would be slow, but would probably work even for non-convex
meshes.
Sam
Date: 1 Feb 2011 03:11:56
Message: <4d47c04c@news.povray.org>
"David Borhani" <dav### [at] alummitedu> schreef in bericht
news:web.4d44f37b6c17394ca1623e690@news.povray.org...
>Viewed
> hemisphere.
> runs
Maybe you should have a look at Poseray 3.13.7 beta. There is an
experimental feature in there which does exactly that. Look under
Groups>Lines, and experiment with "Add thickness to free mesh edges"
You can find Poseray at: http://mysite.verizon.net/sfg0000/
Date: 1 Feb 2011 11:56:13
Message: <4d483b2d$1@news.povray.org>
> Thanks, Alain.
> #declare TestBox = box {<0.5,0.5,0.5>,<-0.5,-0.5,-0.5>  scale<100,100,0.1>
> translate Surface_ClipPlane +<0,0,-0.05>};
> #declare T_TEST = texture { pigment { color rgb<0,0,1>}};
> texture { pigment { color rgb<0,0,1>}}; texture {T_Committor_50_Surface}
> scale 0.999}};
> scale 0.998}};
> Dave
difference{
  object {Committor_50_Volmap}
  object {Committor_50_Volmap scale 0.95}
  object{MapBoundsBoxBig}
  texture{Your_texture}
  rotate Some_Rotation
  translate Somewhere
NO clipped_by
NO bounded_by
If you use clipped_by on a sphere, you'll also get an infinitely this
edge, like this:
sphere{0,1 clipped_by{box{0,1}} // extremely thin wall
Cuts a quadrant out of the SURFACE of the sphere leaving the cut open.
Compare to:
difference{ // wall with thickness
  sphere{0,1} // you can replace the sphere by your mesh
  sphere{0,0.9}// ...and your mesh scaled by 0.9
  box{0,1}
  pigment{rgb 1}
Date: 1 Feb 2011 11:58:39
Message: <4d483bbf@news.povray.org>
> "David Borhani"<dav### [at] alummitedu>  schreef in bericht
>> Viewed
>> hemisphere.
>> runs
> Thomas
It seems that the mesh is closed but he was using clipped_by where he
should have used a difference.
Date: 2 Feb 2011 03:28:00
Message: <4d491590$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> schreef in bericht
news:4d483bbf@news.povray.org...
Indeed. I see that now....
