POV-Ray : Newsgroups : povray.general : Ambiant Occlusion "grey-scaled" image Server Time
11 Oct 2025 10:31:44 EDT (-0400)
  Ambiant Occlusion "grey-scaled" image (Message 1 to 5 of 5)
Subject: Ambiant Occlusion "grey-scaled" image
Date: 29 Jan 2011 15:05:01
Message: <web.4d4471a16e6947bc4c19492e0@news.povray.org>
Hi there,
I'd like to know if it's possible to make a render like what an "Ambient
Occlusion" pass could give.
See the left part of this picture :
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.48f739123ce46002bd1b3ad10%40news.povray.org%3E/ambiento
I'd like to find a way to do that from an already textured and colored scene
which is quite huge. It is only because I like this gray scaled effect.
So if some of you could give me some help, I'd very appreciated it.
Thanks in advance.
Subject: Re: Ambiant Occlusion "grey-scaled" image
Date: 29 Jan 2011 16:28:28
Message: <4d44867c@news.povray.org>
> Hi there,
> Thanks in advance.
Usualy, those who do ambient occlusion start with a scene that use only
white as a pigment.
As ambient occlusion is a kludge approximating a part of what radiosity
does, and you only want a gray scale image. You can:
- make a copy of your scene.
using search and replace...
- Remove all pigment and replace them with a plain white one, or light gray.
- Do the same to remove all finishes.
- Do a normal radiosity render.
You may add gray_thresshold 1 to force the radiosity to ignore the
colours effect.
Another option:
Do a radiosity render of your scene and prost process it to convert it
to gray scale.
Date: 30 Jan 2011 09:20:00
Message: <web.4d45734b8d2dc36f4c19492e0@news.povray.org>
> white as a pigment.
> colours effect.
> Another option:
> to gray scale.
> Alain
Thank you, I did it by changing all my materials to a white pigment without
finishes.
But this was a bit boring to change it manually.
Is there something like a "change all materials to a white pigment" command I
can write in order to avoid manual changing of all the object's material ?
Date: 31 Jan 2011 09:23:05
Message: <4d46c5c9$1@news.povray.org>
Not really. The best you could do is to enclose all your texture
statements in an #if (!USE_DEFAULT_TEXTURE) ... #end block and set
the variable to on for plain renders. Something like this might
actually be handy to have built-in, not just for ambient
occlusion but also, e.g., for creating a depth image
based on a gray gradient.
Date: 31 Jan 2011 13:35:07
Message: <4d4700db$1@news.povray.org>
> actually be handy to have built-in, not just for ambient occlusion
> but also, e.g., for creating a depth image based on a gray gradient.
   Yes, it would be also very handy for baking lightmaps from existing
scenes not designed for that purpose. Something like #default{} but for
overriding would be great... but I don't know if it would be easy to
implement.
Jaime Vives Piqueres
http://www.ignorancia.org
