POV-Ray : Newsgroups : povray.general : A Question regarding output Server Time
17 Mar 2026 16:36:48 EDT (-0400)
  A Question regarding output (Message 1 to 4 of 4)
Subject: A Question regarding output
Date: 14 Jan 2011 02:40:01
Message: <web.4d2ffd01e15d90971a86e02e0@news.povray.org>
Often I find it more convenient to scale by a single vector component (e.g.
scale 4.0*x)
the problem is that when I go to render, I get massive numbers of parse
warnings, especially if I do this in a loop.
Is it really necessary to warn the user that scale assumes a value of 1 for any
undefined component?
A.D.B.
Subject: Re: A Question regarding output
Date: 14 Jan 2011 04:18:20
Message: <4d3014dc$1@news.povray.org>
> scale 4.0*x)
> Regards,
> A.D.B.
you could turn off the warnings stream:
http://wiki.povray.org/content/Documentation:Reference_Section_1.3#Text_Streams
or a macro:
#macro SFx (SF)
  #local SF = <SF,0,0> + <0,1,1>;
  scale SF
box {<-1,-1,-1>, <1,1,1>
  pigment {rgb <1,0,0>}
  SFx (4)
Date: 14 Jan 2011 04:34:16
Message: <4d301898$1@news.povray.org>
What makes you think they are undefined?  4*x means <4,0,0> throughout
POV (anything else doesn't make sense).  If you don't like using a
vector for the scale function then you can always set up macros as
already suggested.
Date: 14 Jan 2011 05:05:29
Message: <4d301fe9$1@news.povray.org>
> scale 4.0*x)
it's not undefined, it's 0.
"scale 4.0*x" is exactly the same as "scale 4.0*<1,0,0>" or "scale
<4.0,0,0>", so you're actively telling pov-ray to scale it infinitely
thin in the y- and z-direction. It just assumes you meant to keep the
dimensions in those directions, but it could just have assumed you
really meant 0 and scale it as small as computationally possible.
At least, that's how I understand it :)
