Can some one help me on the povray code to make the following solid:
A rectangle defined on the xz plane (with two opposite corners <-h,0,-m> and
<h,0,m>)
is sweeped (by a thickness e) and rotated (by an angle a) along the y axis.
Paulo Mota
> <h,0,m>)
> Regards,
> Paulo Mota
You could use an isosurface to get what you are looking for...
I wrote a little scene code that does exactly that:
location <0.75, 0.5, -1>*7
up y
right 4/3*x
look_at 0
angle 27
light_source {<1, 2.5, -2>*10 color rgb 1}
#declare x_h = 0.75; // half of width
#declare y_e = 1.25; // height
#declare z_m = 0.25; // half of length
#declare r_a = 135; // rotation angle (degrees)
#declare func_box = function {max (abs (x) - x_h, abs (y - y_e/2) - y_e/2, abs
(z) - z_m)}
#declare r_a_rad_y = radians (r_a)/y_e;
#declare func_twist = function {func_box (x*cos (y*r_a_rad_y) - z*sin
(y*r_a_rad_y), y, x*sin (y*r_a_rad_y) + z*cos (y*r_a_rad_y))}
#declare twisted_box_iso =
isosurface {
function {func_twist (x, y, z)}
contained_by {box {-2, 2}}
max_gradient 3
object {
twisted_box_iso
wrinkles
color_map {
[0 color rgb y]
[1 color rgb z]
finish {phong 0.5}
plane {
y, 0
pigment {checker color rgb <0.8, 0.2, 0.1> color rgb <1, 0.3, 0.1>}
finish {diffuse 0.25 reflection {0.3}}
Florian
> A rectangle defined on the xz plane (with two opposite corners<-h,0,-m> and
> <h,0,m>)
> Regards,
> Paulo Mota
As ther is no twisted primitive and no twisting transformation, you
ether need to use an isosurface as Florian mentioned, or use some
external modeler to create a mesh of your twisted prism.
You can also do an approximation by stacking many very thin normal
prisms, each slightly rotated relative to the one under it.
Wouldn't a box be more efficient?
Dear Florian:
Thank you for your help.
My first attempt was to stack small parallelepipeds rotated by small angles.
Your solution gives a much better rendering.
I am new to pov-ray; so I still have a question: is your object solid? That is,
can it be subject to the difference operator?
Regards
Paulo Mota
> > <h,0,m>)
> > Regards,
> > Paulo Mota
> camera {
> up y
> right 4/3*x
> look_at 0
> angle 27
> (z) - z_m)}
> isosurface {
> max_gradient 3
> object {
> twisted_box_iso
> pigment {
> wrinkles
> color_map {
> [0 color rgb y]
> [1 color rgb z]
> finish {phong 0.5}
> plane {
> y, 0
> Regards,
> Florian
> Dear Florian:
> Regards
> Paulo Mota
Yes, isosurfaces are solids that have a defined in- and outside.
But for being able to use an isosurface inside a CSG operation you have to add
"max_trace" followed by an integer or the keyword "all_intersections" to the
isosurface statement. You can read the documentation for details, if you like.
Florian
It would for a rectangular section. If the section is not rectangular,
or you have more sides, then using stacked boxes won't do.
