POV-Ray : Newsgroups : povray.general : cannot recognize defined object / help, please Server Time
1 Nov 2024 19:16:14 EDT (-0400)
  cannot recognize defined object / help, please (Message 1 to 10 of 11)
Subject: cannot recognize defined object / help, please
Date: 4 Jan 2011 16:15:01
Message: <web.4d238cfd4caa94dad0ff068b0@news.povray.org>
Partial copies of files:
//                             Tank.POV
//                    z
// y arrow tip------> .-- x
//        NOTE: Change output filename in Tank.INI for output scene name
//              Save change, then run Tank.INI
#include "metals.inc"
global_settings { adc_bailout 0.05 max_trace_level 9 }
// *** does not see Lbar, Scribe, etc as defined objects...  <<<----HELP!
#declare Ulong = 48.0;  #declare ucolor = Blue;
 object {Lbar)
 object {Scribe  pigment {Cyan} rotate < 0, 0,90>}
**** SNIP
//                             Tank.INC
//      Subroutines for making the tank
#declare Lbar=union {   // width X to right, length Y to viewer, left part of
"L" points to Z
  #declare A = 1/8;  #declare B = 1.0;   #declare C = 1.0; // L-BAR chosen
  //  Generic Lbar dimensions defined above
  difference {
  box { <0,0,0>,<C-A/2,Ulong,B-A/2> pigment {ucolor} } // as box, less rounded
ends
  box { <A,-0.001,A+0.16/2>,<C,Ulong+0.002,C> pigment {ucolor} } // left cut
  box { <A+0.16/2,-0.001,A>,<B,Ulong+0.002,B> pigment {ucolor} } // bottom cut
  object { cylinder {<A+0.16/2,-0.001,A+0.16/2>,
<A+0.16/2,Ulong+0.001,A+0.16/2>,0.16/2} // curve cut
          pigment {ucolor} }
  object { cylinder {<C-A/2,-0.001,A/2>, <C-A/2,Ulong+0.001,A/2>,A/2}    // left
curve
          pigment {ucolor} }
  object {cylinder {<A/2,-0.001,B-A/2>, <A/2,Ulong+0.001,B-A/2>,A/2}    // right
curve
          pigment {ucolor} }
#declare Scribe= box {<0,4,0>,<0.03,4.03,1.6> } // for checking only
**** SNIP
;                              Tank.INI
;;file_exists("any.junk")  ; creates file named "true"; impossible to rename any
file
Antialias=On
Width=448  ;Width=640   70% for exact fit in Nerd
Height=336 ;Height=480
;Bits_Per_Color=5  HAS NO EFFECT, still 24 bit color 150DPI
Jitter=Off
Sampling_Method=2
Antialias_Threshold=0.3
Antialias_Depth=1
;;Debug_File=true  ; read "true" for results
Input_File_Name="Tank.pov"
Output_to_File=On
Output_File_Type=N   ; N for PNG files which are the smallest
 Initial_Frame=1
 Final_Frame=12
 Initial_Clock=1
 Final_Clock=12
; clock = 1 (Initial_Clock)
;Make sure this is on if your animation loops:
Cyclic_Animation=off
**** END OF COMPLETE COPY OF FILE
Subject: Re: cannot recognize defined object / help, please
Date: 4 Jan 2011 16:24:57
Message: <4d239029@news.povray.org>
> //                             Tank.POV
> //                    z
you're calling them before they're declared! move the defs to before you
call em!
>  object {Lbar)
> **** SNIP
> //                             Tank.INC
> "L" points to Z
>   difference {
> ends
>           pigment {ucolor} }
> curve
>           pigment {ucolor} }
> curve
>           pigment {ucolor} }
> **** SNIP
> ;                              Tank.INI
> file
> Antialias=On
> Jitter=Off
> Sampling_Method=2
> Antialias_Depth=1
> Output_to_File=On
>  Initial_Frame=1
>  Final_Frame=12
>  Initial_Clock=1
>  Final_Clock=12
Date: 4 Jan 2011 16:51:56
Message: <4d23967c$1@news.povray.org>
Am 04.01.2011 22:11, schrieb Robert Baer:
> //                             Tank.POV
> //                    z
> // *** does not see Lbar, Scribe, etc as defined objects...<<<----HELP!
>   object {Lbar)
>   object {Scribe  pigment {Cyan} rotate<  0, 0,90>}
> **** SNIP
> //                             Tank.INC
I don't see where you include Tank.INC from Tank.POV.
(BTW, it is usually a good idea to place the problem description
/before/ any snippets of source code, because it makes it immediately
obvious for the reader what your problem actually is, and may give
important clues what to keep their eyes peeled for when browsing through
the code.)
Date: 5 Jan 2011 23:50:00
Message: <web.4d25494596c55a409ea184c90@news.povray.org>
> > //                             Tank.POV
> > //                    z
> >   object {Lbar)
> > **** SNIP
> > //                             Tank.INC
> the code.)
  THAT has gotta be the problem; i had a different program set that worked, and
still works despite incorrect library reference in the \renderer\povray.ini (or
whatever the name is, i forget because i almost never have to hunt for it).
  Thanks.
  Will fix it (on different drive not accessible now).
Date: 6 Jan 2011 17:15:01
Message: <web.4d263dc496c55a4046e881bd0@news.povray.org>
> > > //                             Tank.POV
> > > //                    z
> > >   object {Lbar)
> > > **** SNIP
> > > //                             Tank.INC
> > the code.)
>   Thanks.
** Inserting that include made it work; thanks!
  Then i made some changes and it is worse than before.
  Declared variables now do not pass between .ini and .inc; worse a declared
variable gets reset to zero inside the .inc .
//                             Tank.POV
//                    z
#include "Tank.inc"  // <----NOTE!! Do not forget!
// Uses "Tank.inc" for subroutines
// * Ubar         vars: Ulong , ucolor; internal A, B, C dimensions according to
Speedy Metals
// * Lbar         vars: Ulong , ucolor; internal A, B, C dimensions according to
Speedy Metals
// * UpFtBk       observer, at left end "Y", top looking to right Y=0
// * UpLfRt       observer, at left end "Y", top looking to right Y=0
// * Ttop         observer, at left end looking up to right middle of rectangle
#declare PN=3990;   // Chosen "U"  <--NOTE DEFINED!!!!
#declare Ulong = 48.0;  #declare ucolor = Cyan;
// clock 1..9 Make and show tank construction
    #if (clock>=1)
      light_source {<  0, 50,  0> White*9.5}
      light_source {<  0, 10, 20> White*8.5}
      light_source {<  0, 10,-20> White*8.5}
        perspective
        location < 0.5,49,.1>
        look_at  < 0.5, 0,.1>
        angle 0
#declare Ulong = 1.0;
#declare PN=4006;   // Frame "U"  <--NOTE DEFINED!!!!
   object {Ubar} //object {Lbar)
sky_sphere {pigment {rgb <0.859,0.910,0.831>}}
** END FILE
//                             Tank.INC
// (no longer needed) #declare Deg2Rad = 0.0174532925;
// inside flange surfaces of American Standard channels have approximately a
16-2/3% slope
// In radians, arc tan 1/6 = 0.165148677...
//      U-bar end view shape:
//        __ shoulder: "Shl" diameter is wall thickness at top
//      O
//      || /--- wall may have angle; crudely shown here
//      | |   ____strain relief curve:  "Crv" diameter
//      |   O___________
//      |                | C or web/base thickmess
//      +_______________ V
// U-bar modified with look-up table by product number PN
 #declare A=0; #declare B=0; #declare C= 0.; #declare Angle=0;  // default zero
aize
 #declare Shl=0; #declare Crv=0;                                // default zero
aize
  #debug concat("Start search; PN=", str(B,9,3), "\n")
** SNIP
  Debug file "true" (no other name possible) shows that PN=0 !!
  Furthermore POVray barfs on undefined variable Ulong in Tank.inc .
  How can i fix this?
Date: 6 Jan 2011 20:55:08
Message: <4d26727c$1@news.povray.org>
Am 06.01.2011 23:10, schrieb Robert Baer:
>        #declare PN=4006;   // Frame "U"<--NOTE DEFINED!!!!
> aize
> aize
If you want to output PN, then why do you output B ?! ;-)
> ** SNIP
>    How can i fix this?
By defining it /before/ you include the file??
But from the code I guess you'll also want more than one "U-bar" in the
long run anyway, with different lengths - your current code cannot
accomplish that anyway. You should have a look at POV-Ray's macro
mechanism for that. Essentially, macros are the only way in POV-Ray to
"pre-define" anything without specifying all the parameters beforehand.
Date: 7 Jan 2011 02:15:01
Message: <web.4d26bd3f96c55a409ded892d0@news.povray.org>
> > aize
> > aize
> > ** SNIP
> >    How can i fix this?
  I finally discovered that.
  I thought i could be "cute" and include the .inc file right away and thus make
it global.
  So, thanks.
  Now i have an #if..#end problem that is bugging me:
//                             Tank.POV
//                    z
// * Ubar         vars: Ulong , ucolor; declare PN to Speedy Metals part number
// * Lbar         vars: Ulong , ucolor; declare PN to Speedy Metals part number
// object {Scribe  pigment {Cyan} rotate < 0, 0,90>}
// object {Scribe  pigment {Magenta} rotate < 0,90,0>}
// object {Scribe  pigment {Yellow} }
    #if (clock=91)
      light_source {<  0,150,  0> White*100}
        perspective
        location < 0,65,-9>
        look_at  < 0, 0, 0>
        angle 0
#include "Tank.inc"
  object {UpFtBk}
    #if (clock=92)
      light_source {<  0,150,  0> White*5.5}
        perspective
        location < 0, 65,-9>
        look_at  < 0, 0, 0>
        angle 0
#include "Tank.inc"
  object {UpLfRt}
    #if (clock=93)
        perspective
        look_at  < 0, 0, 0>
        angle 0
  object {Ttop rotate < 0, 0,45> translate < 20, 0,  0>}
    #if (clock>3)
        perspective
        location < 0, 5, 0>
        look_at  < 0, 0, 0>
        angle 0
#include "Tank.inc"
                               //    5  10
  object {Ttop rotate < 0, 0,90> translate <-00,-00,  0>}
                    // MATCHED #if..#end recognized to here..
    #if (clock>=1)
        perspective
        angle 0
//#declare PN=3990;   // Chosen "U"
#include "Tank.inc"
                    // but not to here..
// get "Parse Error: End of file reached but #end expected."
*** END FILE ***
Date: 7 Jan 2011 05:52:44
Message: <4d26f07c$1@news.povray.org>
yep ... looked ok to me too (hard to tell messy sytle)
> *** END FILE ***
maybe some thing in the include file is miss-matched ... dunno if the
parser looks at the include as a seperate entity or considers it as part
of the entire scene file when resolving conditional blocks ... /think/
it's the former
Date: 7 Jan 2011 10:14:01
Message: <4d272db9@news.povray.org>
Am 07.01.2011 11:52, schrieb Jim Holsenback:
>> sky_sphere {pigment {rgb<0.859,0.910,0.831>}}
>> *** END FILE ***
> it's the former
No, the parser doesn't systematically check whether the #if and other
blocks of an #include file are fully matched.
An exception is when the parser encounters an #end for a loop it is
currently processing; in that case the #while or #for must reside in the
same file as the terminating #end.
Date: 8 Jan 2011 16:35:00
Message: <web.4d28d75596c55a40e40a58410@news.povray.org>
> >> *** END FILE ***
> > it's the former
  Thanks loads for the patience; learning as i go.
  The business about "subroutines" is something a bit different than in other
languages; quite different than even the 2 ways available in BASIC.
  The above info on #if..#end became pertinent WRT POVray "subroutines".
  Let's see if i can say this correctly.
  Start in .POV and an object is named.
  The program "looks" to see if it is / has been defined in .POV and if not,
scans the .INC files.
  If found in <workingname>.INC then the contents get copied (acts as if one had
a very long file) and then run.
  In my case, the .INC file had an un-matched #if..#end so when the program
continued (effectively "went back" to the .POV file) it did not find a matching
#end and so complained about finding an EOF.
  Now, i think that the program actually does all of the work as it scans thru
all of the pertinent files, and saves the results in some ?hidden? temp area
until done (error or not).
  Then, if error, the appropriate line(s) and file name are used for the message
file - and all results are then scratched / released / erased.
  If no error, one gets all if the neat picture(s), etc.
