POV-Ray : Newsgroups : povray.general : stripes in my color map Server Time
11 Oct 2025 15:07:32 EDT (-0400)
  stripes in my color map (Message 1 to 10 of 15)
Subject: stripes in my color map
Date: 3 Dec 2010 07:40:01
Message: <web.4cf8dbabf79e8097dfff491b0@news.povray.org>
I was wondering if I am doing something wrong. I am seeing stripes in my air (a
color map), as if the gradient isn't correct: gets a bit darker than lighter,
than darker etc. in stead of a smooth transition form light blue to dark blue).
A higher resolution (12000x8000) hasn't helped.
 #declare T_Sky_G2 = texture {
      gradient y
      color_map {
      [0.0 color  rgb < 212, 233, 255>/255  ]
      [1.0 color  rgb < 98, 136, 251>/255]
     scale y*290 }
     finish {
     ambient 0.65 }
Thanks very much.
Joost
Subject: Re: stripes in my color map
Date: 3 Dec 2010 07:46:20
Message: <4cf8e69c@news.povray.org>
  Sounds like the scaling of the texture doesn't match the scaling of the
object you are applying it to.
Date: 3 Dec 2010 08:10:00
Message: <web.4cf8ebbbba37d98edfff491b0@news.povray.org>
I've already tried changing that; making a box <1, 1, 1> without scaling the
color_map, and than scaling the object, but that didn't change the result. The
total transition is correct, it's just not a smooth transition but a stripy one
if you look closer.
Date: 3 Dec 2010 08:19:09
Message: <4cf8ee4c@news.povray.org>
> if you look closer.
  It would help identifying the issue if you posted a complete but minimal
scene that demonstrates the problem.
Date: 3 Dec 2010 09:09:25
Message: <4cf8fa15$1@news.povray.org>
Am 03.12.2010 13:36, schrieb Joost:
> Hi,
These are probably color-encoding artifacts: With 8 bit depth per color
channel you can display only so many different colors, and this gives
you banding in very smooth gradients which may still be noticeable.
Did you try a higher-quality output image format, such as OpenEXR or
16-bit PNG?
My favorite way of getting rid of these artifacts is to render to
OpenEXR, and then use IC to convert to the target 8-bit image format. As
IC uses dithering for such conversions, instead of the banding you'll
get 1-bit noise, which the human eye does not notice anymore.
(I already pondered adding native dithered output to POV-Ray, but
implementation will have to wait due to other priorities.)
Date: 3 Dec 2010 09:20:00
Message: <web.4cf8fa69ba37d98edfff491b0@news.povray.org>
Ah yes: http://www.joostdevries.nl/sky.jpg
I noticed it at the printshop (as did the shop) when I printed a 60x90 cm print.
It's not a major flaw but annoying when printed. I first thought it was in the
conversion tot JPEG, bur found it also present in the BMP and PNG from povray
render.
Thanks for your time.
Date: 3 Dec 2010 09:22:12
Message: <4cf8fd14@news.povray.org>
> >                                                           - Warp
  I was referring to a POV-Ray scene, rather than an image.
Date: 3 Dec 2010 10:05:01
Message: <web.4cf906e4ba37d98edfff491b0@news.povray.org>
That would just be:
 #declare T_Sky_G = texture {
     pigment { gradient y color_map {
      [1.0 color  rgb < 98, 136, 251>/255]  }         }
     finish { ambient 0.2 }       }
camera { orthographic location <300, 169, -300> look_at  <300, 172, 0> right
<590, 0, 0> up <0, 271.4, 0> }
light_source {< -1500, 2200, -2500> rgb < 1, 1, 1> parallel}
light_source {<  0, 2000, -3000> color Gray35 parallel shadowless}
light_source {< 2000, 1000, -500> color Gray20 parallel shadowless}
#declare skybox = box { < 0, 0, 0>, < 1, 1, 1> texture {T_Sky_G} }
object { skybox scale < 750, 234, 1> translate < -50, 97.5, 2000> }
Date: 3 Dec 2010 10:10:01
Message: <web.4cf904bcba37d98edfff491b0@news.povray.org>
> 16-bit PNG?
I just tried Bits_Per_Color=16, but at least my eye can't spot the difference. I
cound't find OpenEXR in the POVray documentation. Do I need to install 3.7 for
that?
Ah, you could be speaking chinese to me with the same effect ;-) If you could
spare some time to translate that to layman terms, I would very much appriciate
it.
Thanks, Joost
Date: 3 Dec 2010 10:19:44
Message: <4cf90a90@news.povray.org>
  Your screen is probably not configured to show 48-bit colors, only 24-bit
ones.
