POV-Ray : Newsgroups : povray.general : Text array problem Server Time
25 Dec 2025 03:48:33 EST (-0500)
  Text array problem (Message 1 to 3 of 3)
Subject: Text array problem
Date: 8 Nov 2010 13:50:01
Message: <web.4cd84567fe65f852a0f4ab460@news.povray.org>
I was going through some old files, and ran into a problem parsing the
following:
#declare firenice =
 array[9] {
    "SOME SAY THE WORLD WILL END IN FIRE",
    "SOME SAY IN ICE",
    "FROM WHAT I'VE TASTED OF DESIRE,",
    "I HOLD WITH THOSE WHO FAVOR FIRE;",
    "BUT SHOULD IT HAVE TO PERISH TWICE,",
    "I THINK I KNOW ENOUGH OF HATE,",
    "TO SAY THAT FOR DESTRUCTION, ICE -",
    "IS ALSO GREAT -",
    "AND WOULD SUFFICE."
I get the error "Could not convert System Specific Text format to Unicode"
I've tried re-typing the text to remove non-system characters, but it has no
effect.  I've rendered this before, so I know it works.  Was there some change
to the text handling in the beta?
thanks in advance
A.D.B.
Subject: Re: Text array problem
Date: 8 Nov 2010 14:15:01
Message: <web.4cd84bfe191fe4f1a0f4ab460@news.povray.org>
Well, I feel foolish... For some reason I had charset sys in global settings...
On another note, I was under the impression that pov auto-detected system fonts
since version 3.1 or something...  I keep having to specify a directory and an
exact file name...
am I doing something wrong?
I currently do all my rendering in Ubuntu.
A.D.B.
Date: 9 Nov 2010 03:49:47
Message: <4cd90b2b$1@news.povray.org>
> exact file name...
Nothing wrong from your part.
Povray starts with a few default fonts' directories, according to the
system you are on, in the system & user default configuration files or
registry....
On Windows, all installed fonts in the system are in a single directory
(something like c:\WINDOWS\Fonts, but location can vary), so a single +L
in the configuration file is enough. (it's just a big mess to manage:
here just 612 files in that one!)
And Windows had an history of ignoring case of filename (fat32 did not
support them, and default to NTFS is only a recent move in term of
casual user's windows' generation), so most opening routine files in
windows will try to ignore the case of the characters in a file name.
On Ubuntu, the truetype fonts are in /usr/share/fonts/truetype and
usually then in a subdirectory (so each package does not have to resolve
conflict when it installs a set of fonts).
And to make things less easier, whereas in Windows install the
pvengine.ini has a %FONTDIR% in the input paths, there is no such
provision during the povray installation
(/usr/local/etc/povray/3.7/povray.ini for 3.7beta), so a Unix
installation ends up without any path to fonts by default.
(Ubuntu puts fonts in /usr/share/fonts, but that's not yet universal for
all unix)
And unix has a tradition of distinguishing case in filename (due to the
various filesystems doing that from a long time), so the name must match.
Best fix for you: add the many fonts directory in your povray.ini (as
+L= .... ) (either at the system level, or in $HOME/.povray/... ), and
take care of the case of font's filename in your script.
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
