POV-Ray : Newsgroups : povray.general : Generating an objects map along with the image Server Time
17 Mar 2026 18:06:02 EDT (-0400)
  Generating an objects map along with the image (Message 1 to 8 of 8)
Subject: Generating an objects map along with the image
Date: 28 Sep 2010 15:30:00
Message: <web.4ca241bdbc99bf09e42b134d0@news.povray.org>
Hello everybody,
Is there an option (if every object rendered as been given a king of
unique id) to have a x/y map of the first object hits by the ray during the
rendering of each pixel ?
Could be usefull to build a quick modeler, or just having a click-on map
associated with your image.
Subject: Re: Generating an objects map along with the image
Date: 29 Sep 2010 03:19:00
Message: <4ca2e864$1@news.povray.org>
Le 28/09/2010 21:28, Boing3000 a écrit :
> Hello everybody,
Hello,
You might use the quick_color (with a different value for each object)
along with a quality of 0 or 1. ( +Q0 on command line/option)
http://www.povray.org/documentation/view/3.6.1/223/
http://www.povray.org/documentation/view/3.6.1/338/
How you generate the unique id and then encode it as a color is up to you.
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
Date: 29 Sep 2010 06:05:01
Message: <web.4ca30e8566f67193729b5e300@news.povray.org>
> Hello,
Nice trick !
Should work right enough, thank you very much
Date: 29 Sep 2010 06:32:52
Message: <4ca315d4$1@news.povray.org>
FWIW I'd be interested in seeing if anyone would like to try using the new
mesh camera to sub-divide a scene into voxel-like blocks and use that to
get a 3d map. The quick color approach still ought to work provided you set
ambient high enough. Using distribution method 2 along with a max distance
of <= the slice spacing would probably be the best approach (giving a very
wide output image with multiple slices of the scene), combined with a
single planar mesh instantiated multiple times at the locations that you
want to generate the slices.
-- Chris
Date: 29 Sep 2010 15:44:39
Message: <4ca39727$1@news.povray.org>
> of<= the slice spacing would probably be the best approach (giving a very
> -- Chris
If you use +q0 you don't have to bother with setting ambient or any
other finish options. That setting only use full ambient, no reflection,
no light/shadow computation, no highlight and no normals.
Date: 30 Sep 2010 05:55:01
Message: <web.4ca45e0a66f67193125cd7d50@news.povray.org>
> > -- Chris
> Alain
BTW, I try this on the 3.7Beta39(64bit) and quick_color seems to be broken
(simple textured surface are still quite slow in +Q0).
Anyway v3.6 works OK, but quite slow compared to 3.7 (especially on my 4xHT
core).
Concerning performances, I am wondering if there is a stage in the rendering
process where it would be possible to fork many rendering (mainly based output
parameter like resolution). The goal beeing to share (and thus not redo) the
parsing - internal object representation process.
Date: 30 Sep 2010 07:07:18
Message: <4ca46f66$1@news.povray.org>
yes i see that as well ... entered into bug-tracker:
http://bugs.povray.org/task/166?project=2&order=id&sort=desc
Maybe not specific to your stated goal ... performance related settings
that you might use to "share the work-load"
http://wiki.povray.org/content/Documentation:Reference_Section_1.3#Symmetric_MultiProcessing
see are below that "Render Block Size" and further down the page BSP
Bounding
Date: 30 Sep 2010 09:15:01
Message: <web.4ca48c4066f67193729b5e300@news.povray.org>
> Bounding
Thank you, interesting lecture. This project rocks...
