POV-Ray : Newsgroups : povray.general : bacteriorhodopsin POV file Server Time
28 Jan 2026 07:45:19 EST (-0500)
  bacteriorhodopsin POV file (Message 1 to 7 of 7)
Subject: bacteriorhodopsin POV file
Date: 24 Sep 2010 11:25:00
Message: <web.4c9cc215c1e92843324a5d7d0@news.povray.org>
I need to do an animation about bacteriorhodopsin, and I need to have the 3D
model of the bacteria; before starting do try to build it myself (taking lot of
time), has somebody the POV file or similar (for example mdl file for Moray) to
give me, or knows where I can find it?
Thank you
Subject: Re: bacteriorhodopsin POV file
Date: 24 Sep 2010 13:48:37
Message: <4c9ce475@news.povray.org>
> Thank you
If you have a file containing the location of the various atoms forming
the molecule, you can easily create a blob object representing it. You
can also place spheres to represent those atoms.
Using both aproach, you can color code the various atoms or specific
parts of the model.
Date: 24 Sep 2010 18:41:42
Message: <4C9D2926.60707@gmail.com>
> Thank you
You can find the structure e.g. on
http://www.pdbj.org/emnavi/emnavi_detail.php?id=pdb-1brd
i.e. the position of all atoms (except hydrogen, you are supposed to
figure those out yourself).
Use blobs or ball and stick models to create the protein.
It is a bit of work, but rather straightforward. You can e.g. paste the
relevant portion in a spreadsheet, reorganize it so it only include the
data you need and add pov-sdl in the columns where required. Export it
as a textfile and you have a basic include file. Perhaps you need to
write some macros also to make life easy.
Unless someone wrote a pdb to pov convertor or something similar...
There may be something usefull in
http://www.povray.org/resources/links/3D_Programs/Chemical_Molecular_Modelling_Programs/
For the cell you need other references. but blobs may again be suited to
get a basic shape.
Date: 24 Sep 2010 21:15:00
Message: <web.4c9d4ca475180bfeb92da8ee0@news.povray.org>
> Thank you
You can look for the model as andrel suggested and then you might use
biodesigner:
http://www.pirx.com/biodesigner/index.shtml
which can output a pov-ray scene file which you then can adapt to your needs.
Cheers,
Simone
Date: 26 Sep 2010 11:01:09
Message: <tv04n7-i3v.ln1@badulaque.reducto>
Giuela saw fit to write:
> 3D model of the bacteria; before starting do try to build it myself
> (taking lot of time), has somebody the POV file or similar (for example
> mdl file for Moray) to give me, or knows where I can find it?
Do you mean a model of the bacteriorhodopsin (the protein) or a model of the
bacterium (the organism)? If it's the former, as others have interpreted, my
advice is to use VMD (<http://www.ks.uiuc.edu/Research/vmd/>), which as a
visualization program that can export to POV-Ray. It can also load
structures from the PDB directly, just write "1brd" in the file load dialog,
and it gets fetched from the net.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 26 Sep 2010 13:00:00
Message: <web.4c9f7b8e75180bfea4352cfc0@news.povray.org>
> Thank you
You may want to try the program Mol2mol to convert chemical pdb coordinate files
to POVray format.
The program creates povray input files and you can modify them as you want.
http://www.gunda.hu/mol2mol
You can find several bacteriorhodopsin files from here:
http://www.rcsb.org./pdb/search/advSearch.do
Date: 1 Oct 2010 03:40:01
Message: <web.4ca58f8b75180bfe324a5d7d0@news.povray.org>
> > Thank you
> get a basic shape.
Thank you Andrel for your suggestions.
I found the Pov Ray file of the bacteria at the address
http://www.rcsb.org/pdb/explore/jmol.do?structureId=1BRD&opt=3
Here it's possible to wiev in different ways and to save the image in different
formats, also in .pov.
