POV-Ray : Newsgroups : povray.general : How to print a CSG Server Time
18 Feb 2025 17:23:04 EST (-0500)
  How to print a CSG (Message 1 to 7 of 7)
Subject: How to print a CSG
Date: 14 Jul 2010 22:15:01
Message: <web.4c3e6e413ead8315a78d16e60@news.povray.org>
Anyone familiar with?
http://www.shapeways.com/
I've made a CSG that I'd like to have printed.  Check out the image area to see
what it is.  What is the easiest way to turn a CSG into a format I could upload
at Shapeways?
Is this the right section to ask this question in?
Thanks,
Carl
Subject: Re: How to print a CSG
Date: 15 Jul 2010 06:03:11
Message: <4c3edcdf$1@news.povray.org>
> at Shapeways?
> Thanks,
> Carl
http://wiki.povray.org/content/Documentation:Reference_Section_1.1#Output_File_Type
Date: 15 Jul 2010 06:55:11
Message: <4c3ee90f@news.povray.org>
No, but I've used similar services before for rapid prototyping.
> to see
> upload
> at Shapeways?
Unfortunately there is no easy way to do this, as they will be expecting a
triangle mesh.  There are macros for POV lying around that will convert your
CSG into a mesh, you might then want to import into a mesh modeller to check
and tidy up any items.
I would also ask (or maybe it's on their website?) what resolution they work
at.  This will determine the resolution of triangle mesh you want to
generate from the CSG.
Given the simplicity of the model (and that several parts seem to be
repeated), it might turn out faster in the end (and provide higher quality
results) if you start again in a mesh modeller (or CAD software if you have
access) rather than POV.
Date: 15 Jul 2010 07:07:51
Message: <4c3eec07$1@news.povray.org>
ha-ha ... guess i missed the boat entirely on this one. saw "print" and
just didn't associate it with producing a physical object :-(
Date: 17 Jul 2010 21:25:01
Message: <web.4c425721d9d79fb6a78d16e60@news.povray.org>
Any specific macros you'd recommend? Links?
POV-Ray is the only 3D modeller I've taught myself how to use.  I tend to think
in terms of CSG; intersections, unions, differences, of spheres, cones, planes,
boxes, etc.  Any modellers that would be easy to learn how to use that would
allow me to work in the same terms but which would create a triangle mesh?  Any
that are free?
Thanks,
Carl
Date: 23 Jul 2010 02:44:29
Message: <4c493a4d$1@news.povray.org>
>> a
>> your
>> check
I've never personally used any, but I remember seeing references somewhere
on this forum.
> think
> planes,
> would
Pretty much any 3D CAD software would fit the bill perfectly, but...
> Any
> that are free?
...they tend not to be free.  I'm not sure how well the likes of Blender
handle CSG, but you could give it a shot, and it's not very parametric, so
you can't easily go back and change the radius of stuff after you've made
the model (like you can in POV and CAD software).
Another idea I had: When they receive a 3D mesh they must render it to a
load of 2D bitmap slices at some point to feed to the machine.  I wonder if
you contacted them, you could supply them with a load of monochrome bitmaps
for each slice instead of the 3D data.  This would be easy to render in one
go with POV.
Date: 23 Jul 2010 14:43:51
Message: <4c49e2e7$1@news.povray.org>
>> to think
>> cones, planes,
>> would
>> mesh?
>> Any
>> that are free?
r
> so you can't easily go back and change the radius of stuff after you've
> made the model (like you can in POV and CAD software).
a
r
> if you contacted them, you could supply them with a load of monochrome
> bitmaps for each slice instead of the 3D data.  This would be easy to
> render in one go with POV.
	I've never tried it, but you might want to take a look at BRL-CAD:
http://brlcad.org/
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
