![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Can I use a function to create a pigment WITHOUT using a colour_map?
Date: 11 Apr 2010 14:41:56
Message: <4bc217f4$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I just can't get my head around this problem...
I am trying to render a high resolution image of Saturn's rings. I can't use
colour maps for this as they won't have the resolution required (I believe
colour_maps are limited in the number of elements you can have!)
I have written a group of float functions that produce the red, green, blue,
transparency and several various albedo values. I also have a function that
varies between 0 and 1 across the ring plane... OK so far.
My problem is that I cannot seem to combine these to produce a pigment.
The following code fails with a "numeric expression expected" error...
disc
0, z, OuterEdge, InnerEdge
pigment
rgbt<fRingRed(x,y,z), fRingGreen(x,y,z), fRingBlue(x,y,z),
fRingTrans(x,y,z)>
It appears you can't put functions into a rgbt<>.
Can anyone else suggest how to do this?
Rarius
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Can I use a function to create a pigment WITHOUT using a colour_map?
Date: 11 Apr 2010 15:03:55
Message: <4bc21d1b$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes. The limit is 255 entries.
> disc
> pigment
> fRingTrans(x,y,z)>
No, but you can have a function that will return a pigment.
pigment{ rgbt fRingPigment(x,y,z) }
or even
pigment{ fRingPigment(x,y,z) }
You can also use a macro.
> Rarius
Other peoples have used a combination of scattering media with
extinction turned off and absorbing media.
You can also use a disk or a whide, thin cylinder with an image_map.
If you use a disk and also use media elswhere in the scene, such as
saturn's athmosphere, you must add hollow to the disk, as the disk have
an interior and will interfere with nedia.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It is true that maps are limited to 255 entries, but if you use a pigment map
with nested color_maps, the pigment_map may have 255 entries, each with a
color_map containing its own 255 entries.
> disc
> pigment
> fRingTrans(x,y,z)>
I am assuming those are pigment functions, which do not return a single value -
they return a color 3vector. Assuming that they are returning a grayscale
value, you can change that to:
pigment
color rgbt <fRingRed(x,y,z).red,
fRingGreen(x,y,z).red,
fRingBlue(x,y,z).red,
fRingTrans(x,y,z).red>
Note that while I am extracting what would be the red component, this doesn't
have anything to do with the color produced by the pigment. I am just pulling
the first float out of the 3 vector.
HTH
-Reactor
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 12 Apr 2010 04:05:30
Message: <4bc2d44a$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Reactor" <rea### [at] hotmail com> wrote in message
news:web.4bc22e72256a6c956811279d0@news.povray.org...
> value -
> pigment
> doesn't
> pulling
Your assumption is incorrect. The fRingXXX() functions return floats not
vectors.
After searching the archives I came up with the following...
#declare pRingColour=
pigment
average
pigment_map
[1 function { fRingColourRed(x,y,z) } color_map{[0 rgb 0][1 red
3]}]
[1 function { fRingColourGreen(x,y,z) } color_map{ [0 rgb 0][1
green 3]}]
[1 function { fRingColourBlue(x,y,z) } color_map{ [0 rgb 0][1
blue 3]}]
Many thanks to all who helped.
Rarius
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 12 Apr 2010 04:23:11
Message: <4bc2d86f$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> pigment
The problem I am having is that rgbt<> will not accept a function as a
parameter...
rgbt<r,g,b,t> works while rgbt<fRed(x,y,z),fGreen(x,y,z),fBlue(x,y,z)> will
not parse even if the fRed() functions just return 0!
Rarius
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 12 Apr 2010 04:46:02
Message: <4bc2ddca$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> or even
I tried this and the parser fails as soon as it hits the x, saying
"Parse Error: Float
expected but vector or color expression found."
Here is the entire code...
#local InnerEdge=74.510;
#local OuterEdge=140.390;
#local fRingGradient=
function
(sqrt((x*x)+(y*y)+(z*z))-InnerEdge)/(OuterEdge-InnerEdge)
#local fRingColour=
function
pigment
image_map
png "bjj\sat_ring_color.png"
interpolate 4
#local pRingColour=
function
pigment
colour fRingColour(fRingGradient(x, y, 0),0,0)
fRingGradient() returns a value from 0 to 1 depending where on the ring
disk x,y,z is. 0 at inner edge, 1 at outer edge
fRingColour() returns a square pigment loaded with the imagemap file.
This file is 800px wide and 1px high.
pRingColour() should return the colour from the image mapping the square
image onto the ring.
Unfortunately it appears that in pRingColour() the x and y are no longer
the parameters, but have reverted to the standard vectors.
I have tried removing the "colour" keyword, removing the "pigment" all
to no avail.
There is something odd going on here.
Rarius
Download 'iso-8859-1' (4 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think I understand. You are using x, y, and z literally in your code, and not
to represent some value in your post. In that context, x, y, and z are vector
identifiers, not operands. They would have to be enclosed in a function block
to be treated as operands. The average method that you listed is probably the
best way to work around this.
-Reactor
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
