POV-Ray : Newsgroups : povray.general : which mathematics does POV-Ray use? Server Time
25 Dec 2025 13:56:58 EST (-0500)
  which mathematics does POV-Ray use? (Message 1 to 10 of 11)
Subject: which mathematics does POV-Ray use?
Date: 16 Nov 2009 12:45:01
Message: <web.4b018f1fd5612874d4c5ca190@news.povray.org>
Hi everyone,
I am looking but can not find, what kind of mathematics does POV-Ray use.
He is primarily Ray tracer but he also uses radiocsity algorithm. Am
I right?
Please give me some links to some theoretical part of POV-Ray. Thank you!
Subject: Re: which mathematics does POV-Ray use?
Date: 16 Nov 2009 13:10:57
Message: <4b0195b1$1@news.povray.org>
> I right?
At its origin and core, POV-Ray is indeed a classic (backward)
raytracing software. There should be ample information out on the net
about the mathematical details.
As for what POV-Ray calls radiosity, the algorithm is based on the 1988
paper "A Ray Tracing Solution for Diffuse Interreflection" by Greg
(Gregory J.) Ward et al.
A PDF version can be found at
http://www.cs.virginia.edu/~gfx/Courses/2003/ImageSynthesis/papers/Monte%20Carlo/Ray%20Tracing%20Solution%20for%20Diffuse%20Interreflection.pdf,
but it lacks the figures.
http://radsite.lbl.gov/radiance/papers/sg88/paper.html has .gif and
.tiff files scanned from a paper copy, which do include the figures.
There are other sites showing up on google which charge money for a PDF
version of the paper, but I don't know whether it is any different from
the one fount on virginia.edu.
Another algorithm used in POV-Ray that deserves mention is photon
mapping, but I can't give any pointers on that one.
Date: 16 Nov 2009 14:10:01
Message: <web.4b01a31358e10a05d4c5ca190@news.povray.org>
thank you, great!!!
what I need are differential equations that POV-Ray uses.
Can you send me some link. Thanks!
Date: 16 Nov 2009 15:29:39
Message: <4b01b633$1@news.povray.org>
Could you be somewhat more specific?
At its core, raytracing is about vector math, not differential
equations. There are pretty likely some underlying differential
equations involved for stuff like the fresnel formula used in
refraction, or the phong / blinn-phong highlights, but someone else
wrecked their brains earlier to come up with quite simple equations,
with all integrals or derivatives either solved or approximated already.
As for radiosity, it does perform some integration, but it does so
numerically using a monte-carlo-like approach.
I really wouldn't know off the top of my head where you expect to be
differential equations involved.
Date: 17 Nov 2009 05:50:00
Message: <web.4b027fcf58e10a053a7b232a0@news.povray.org>
Clipka thank you very much for your cooperation. ;)
I am trying to figure out what mathematics does POV-Ray use.
Does it use more Raytracing or Radiosity or it combines both?
How does it make shadows (isn't it with radiosity)?
So I need some formulas, integrals and derivatives so I can
better understand how it works.
Thanks
Date: 17 Nov 2009 16:04:24
Message: <4b030fd8$1@news.povray.org>
"marky.addison" <mar### [at] gmailcom> wrote in message
news:web.4b027fcf58e10a053a7b232a0@news.povray.org...
> Thanks
What is going on is that a ray is being represented as a formula...
location = point + time * direction (where time > 0)
and an object is being represented by it's geometric formula,
for example a sphere...
X^2+Y^2+Z^2 = radius^2
and then the ray formula is being substituted into the objects'
formula ...
(point_x + time*direction_x)^2 +
(point_y + time*direction_y)^2 +
(point_z + time*direction_z)^2 = radius^2
and then this formula is solved for time, (in the sphere case using
the quadratic formula). From there you substitute the time back
into the ray formula to find the location of the intersects.
To calculate shadows another ray is cast from the intersection
point (A) at the light locations, if some other scene object has an
insection (B) with that shadow ray closer than the light then the
intersection point (A) is not illuminated by the light, so it's a darker
pixel.
Here's some links...
http://www.siggraph.org/education/materials/HyperGraph/raytrace/rtinter0.htm
http://www.cl.cam.ac.uk/teaching/1999/AGraphHCI/SMAG/node2.html
Some college math and programming classes assign a toy ray-tracer as
a programming project, is that what you are doing?
Date: 17 Nov 2009 21:37:30
Message: <4b035dea$1@news.povray.org>
Normally it uses raytracing, unless you explicitly tell it to also
include radiosity (note that the term may be ambiguous; a more fitting
term would have been "ambient illumination", but that term was already
occupied in POV-Ray for a quite cheap approximation thereof).
No, ambient illumination kicks in regardless of whether a surface is
exposed to direct light or not (although its effect is most obvious in
shadows).
If you want to know how it /works/, you should ask for algorithms. I
guess what you want to know is what these algorithms /represent/ in
mathematical terms.
Unfortunately I'm more the practical guy, who broods over a mathematical
formula with integrals and stuff, thinking "man, can't somebody just
give me an algorithm so I can better understand what these integrals
really mean?!"... well, anyway, I'll try to give it a shot (but you'll
have to transpose my prose it into formal mathematical notation yourself).
Expressing all the mathematical stuff that POV-Ray tries to compute
numerically wold probably fill a book, and it would probably take
decades to write (at least if I ware to write it), so I'll concentrate
on the one concrete thing you mentioned: Shadows. Or, more precisely,
computing incident illumination for the sake of the diffuse reflection term.
Mathematically speaking, POV-Ray numerically (and approximately)
computes the total incident illumination at a point P as the sum of
three hemispherical integrals, each of: Incident light, matching certain
category, from any direction, multiplied by the cosine of the angle of
incidence.
(Note that while mathematically this could be simplified to a single
hemispherical integral, the implementation computes/approximates the
integrals separately for optimization.)
The three categories are:
(A) Direct incident illumination via light paths that don't involve any
reflection or refraction. ("Direct light")
(B) Indirect incident illumination via light paths that involve only
specular reflection/refraction, and no scattering. ("Caustics")
(C) Indirect indicent illumination via light paths that involve diffuse
reflection/refraction, and/or media scattering. ("Ambient illumination")
(Transmittance through an interface between media with identical
refractive indices are not considered refraction in this sense.)
For the sake of category (A), light sources are considered to be either
point light sources, or arrays of point light sources. Incident light is
computed only for vectors from any such point light source to P, for
probably obvious reasons. The algorithm basically uses simple
intersection testing, and some formula for light attenuation based on
distance, media and surface properties; mathematically, this is probably
best represented as the product of the light source brightness and a
term representing attenuation.
For the sake of category (B), photon mapping is used. Basically, this
uses forward-raytracing and monte-carlo integration to approximate the
corresponding term for any point on any surface (and also for any point
in any scattering media).
For the sake of category (C), the approach as described by Greg Ward
(aka "radiosity" in POV-Ray) is used, and as the original paper is much
more mathematical than I could ever rephrase it, you'd best look the
details up there.
Alternatively, to speed up rendering, photon and/or radiosity mapping
may be turned off. In this case, (B) is approximated by presuming that
(for the sake of illumination computation) refractive indices of all
media are identical and ignoring any light paths that include specular
reflection, while (C) is approximated by a constant term (which may vary
from surface to surface) specified by the scene designer.
The full incident illumination term is in turn used to compute the
diffuse reflective term, but there's not much special in POV-Ray about
this (nor the specular reflective or refractive terms) - we're talking
about a quite straightforward BRDF illumination model here.
Date: 18 Nov 2009 04:30:29
Message: <4b03beb5@news.povray.org>
> shadows).
> mathematical terms.
The answer probably should be that anybody who wants to know how ray-tracing
works should take a good look at the available literature. And that really
is not hard to find thanks to the documentation:
<http://www.povray.org/documentation/view/3.6.1/211/>
Plus Andrew Glassner's Principles of Digital Image Synthesis,
Morgan-Kaufmann Publishers, San Francisco, 1995, which has a lot of formulas
inside and is way more theoretical than useful :-)
	Thorsten
Date: 18 Nov 2009 05:30:33
Message: <4b03ccc9$1@news.povray.org>
>> shadows).
>> mathematical terms.
> ray-tracing works should take a good look at the available literature.
> And that really is not hard to find thanks to the documentation:
> formulas inside and is way more theoretical than useful :-)
>     Thorsten
Physically Based Rendering by Pharr and Humphreys is the other standard
book I have seen mentioned. As recommended reading for ray-tracing, not
specifically in regards to how POV-Ray works.
Date: 18 Nov 2009 05:54:36
Message: <4b03d26c$1@news.povray.org>
It is certainly very good, but also very practical, which does not seem to
be what the original poster is looking for.
	Thorsten
