POV-Ray : Newsgroups : povray.general : input/output file Server Time
11 Apr 2026 12:48:41 EDT (-0400)
  input/output file (Message 1 to 10 of 10)
Subject: input/output file
Date: 16 Oct 2009 09:20:01
Message: <web.4ad872742aad556549aa3f520@news.povray.org>
I would like to read data (float or vectors of float) from an ascii file and use
the data as coordinates for the geometry in the scene: some spheres connected by
cylinders.
I tried with the following code and an input file with a sequence of floats.
The problem is that some data in the input file are not read (I checked with the
#write): sometimes every second float is read, sometimes there is no regular
pattern. Moreover, sometimes the minus sign is not read.
(I got a similar error with vectors of floats)
Am I doing something wrong or is there a bug in the I/O functions?
I'm using povray-3.6.1-12 on ubuntu 9.04 but I get the same error in windows
both with 3.6.1 and 3.6.2.
Thanks
Ester
#fopen inputfile "in.dat" read
//#fopen outputfile "out.dat" write
  #if (defined(inputfile))
    #read (inputfile, y1, y2, y3)
  #while (defined(inputfile))
    #declare x1 = y1;
    #declare x2 = y2;
    #declare x3 = y3;
    #read (inputfile, y1,y2,y3)
    sphere { <x1,x2,x3>, 0.3  pigment {color Green}}
    #if (!(x1 = y1 & x2 = y2 & x3 = y3))
      cylinder { <x1,x2,x3>, <y1,y2,y3>, 0.1 pigment {color Red}}
//    #write (outputfile, x1, " ", x2, " ", x3, "\n")
#fclose inputfile
//#fclose outputfile
Subject: Re: input/output file
Date: 16 Oct 2009 10:13:23
Message: <4ad87f83$1@news.povray.org>
"esterichia" <est### [at] gmailcom> schreef in bericht
news:web.4ad872742aad556549aa3f520@news.povray.org...
>and use
> connected by
> cylinders.
> floats.
> with the
> regular
> windows
> Thanks
> Ester
>  #end
>    #declare x1 = y1;
>    #declare x2 = y2;
>    #declare x3 = y3;
>    #end
>  #end
> #fclose inputfile
I think commas are missing in the write statement because they are needed to
separate the written parameters in the file in order to be read correctly.
Check that your input file has commas too between parametersAlso you can
simplify your define as you do not need the #if statement. Just write:
  #declare x1 = y1;
  #declare x2 = y2;
  #declare x3 = y3;
  #write (outputfile, x1,", ", x2,", ", x3,",","\n")
Hope this helps.
Date: 16 Oct 2009 10:14:42
Message: <4ad87fd2$1@news.povray.org>
See section 3.2.2.3.4 "The #write Directive" of the POV-Ray inbuilt help:
"Note: data read by the #read directive must have comma delimiters
between values and quotes around string data but the #write directive
does not automatically output commas or quotes."
It appears that in the absence of a separating comma, POV-Ray will
instead "eat" the next number entirely if it is positive, OR its minus
sign if it is negative.
Date: 16 Oct 2009 10:20:21
Message: <4ad88125$1@news.povray.org>
Thomas de Groot schrieb:
> Also you can
>   #declare x1 = y1;
>   #declare x2 = y2;
>   #declare x3 = y3;
> #end
I guess without the pre-read this will cause a parse error, as y1,y2,y3
will be undefined at this point.
Date: 16 Oct 2009 10:34:51
Message: <4ad8848b$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4ad88125$1@news.povray.org...
Aaah... yes, indeed. In this case that is required. But then, why not put
the #read as the first line in the #while loop? Then the #if statement could
be omitted.
Date: 16 Oct 2009 15:59:22
Message: <4ad8d09a$1@news.povray.org>
> cylinders.
> Thanks
> Ester
>   #end
>     #declare x1 = y1;
>     #declare x2 = y2;
>     #declare x3 = y3;
>     #end
>   #end
> #fclose inputfile
Make sure that your file is comma separated. You don't always need the
comma if all the values are positive, but you absolutely need them
before any negative value.
Whenever you get a negative value preceded by a float or a vector, the
negative value get substracted from the preceding one.
Normaly, <1 2 3><4 5 6, 7> is read correctly as a 3D and a 4D vectors,<1
2 3>4.56 as a 3D vector and a float and 1.23 4.56 as two floats.
BUT!
17    -5 becomes 12
<12, 5, 9>    -8 becomes <4, -3, 1>
100	-5	-33 becomes 62
Date: 17 Oct 2009 12:32:58
Message: <4ad9f1ba$1@news.povray.org>
That's actually the case only when you #include the file. If you #read
it, no arithmetics are done - but then lack of commas is problematic
even with positive values.
Date: 18 Oct 2009 05:30:00
Message: <web.4adadf7ee89cf16bfc1bd5380@news.povray.org>
Thank you, this works. It was my mistake.
> Also you can
>   #declare x1 = y1;
>   #declare x2 = y2;
>   #declare x3 = y3;
> #end
> be omitted.
I need two points to draw the cylinder, that is the first time I have to read 2
points and then only one for each cycle.
Date: 5 Feb 2010 19:25:01
Message: <web.4b6cb5cce89cf16be5b492130@news.povray.org>
> > Also you can
> >   #declare x1 = y1;
> >   #declare x2 = y2;
> >   #declare x3 = y3;
> > #end
> > be omitted.
Esterichia-
What is the range of data points you are having povray run through? Any idea how
to make it run through a couple thousand points?
-Thanks
--Addison
Date: 5 Feb 2010 19:50:01
Message: <web.4b6cbc62e89cf16be5b492130@news.povray.org>
> > > Also you can
> > >   #declare x1 = y1;
> > >   #declare x2 = y2;
> > >   #declare x3 = y3;
> > > #end
> > > be omitted.
> Esterichia-
> -Thanks
> --Addison
Nevermind. Got it. My mistake.
-Addison
