I am new to POV-Ray. In the example below, I am trying to merge two boxes
together. But when I render the image, the boxes disappear at the sections
where they intersect. Is this correct?
How do I get my two boxes to merge into one uniform 'T' shape. This does not
happen with a 'union'. But I can't use 'union' because I want to render the
'T' as a 'glass like' object. Any suggestions?
#include "textures.inc"
global_settings
max_trace_level 10
ambient_light White
background { color Gray }
camera
location <0, 153, -320>
look_at <0, 153, 0>
merge
box{<0,233,0>, <233-16,197,36>}
box{<197,/*233-16*/300,0>, <233,107,36>}
// Tinted blue crystal
pigment { rgbf<0.8,0.8,1,0.9> }
material { M_Glass3 }
interior { Glass_Interior }
finish { Glass_Finish }
translate <-143,10,-18>
rotate <0,clock,0>
POV-Ray is a bit weak when dealing with coincident surfaces.
Try translating one of the boxes by a very tiny amount, e.g.
merge
box{<197,/*233-16*/300,0>, <233,107,36> translate <0,0,0.001>}
> global_settings
> max_trace_level 10
> ambient_light White
> camera
> look_at <0, 153, 0>
> merge
> rotate <0,clock,0>
You have surfaces that are at exactly the same location. When you
encounter such a case, you can't tell whitch surface to use. In your
case, you end up missing both most of the time, with some pixels that
catch one or the other.
The solution from clipka is one that you can reliably use (you can use a
much smaller value, like 0.00000001). Another way would be to scale one
of the component by something like 0.999999 or 1.000001 along the z axis.
this should also work:
difference{
box{<0,107,0>,<233,300,36> }
box{<-100,233,-100>,<197,500,100>}
box{<-100, 0,-100>,<197,197,100>}
rotate <0,clock,0>
> global_settings
> max_trace_level 10
> ambient_light White
> camera
> look_at <0, 153, 0>
> merge
> rotate <0,clock,0>
