POV-Ray : Newsgroups : povray.general : Farm Tower Project Server Time
18 Feb 2025 17:18:32 EST (-0500)
  Farm Tower Project (Message 1 to 4 of 4)
Subject: Farm Tower Project
Date: 22 Jul 2009 18:20:00
Message: <web.4a678fef2558df7b5d6f23280@news.povray.org>
Hello
I'm creating a farm tower for a project for a povray class. There are different
crops on each floor of the tower.
However, my tower looks weird. Is it because the crops are too big or is the
tower too small? What can I do to make it look more realistic?
Should I change the shape of my tower?
Here is my current code..
thank you!
light_source {<20,10,20> color rgb <1,1,1>}
camera {location <10,5,10> look_at <0,0,0>}
background {color rgb <1,1,1>}
include "textures.inc"
include "glass.inc"
include "glass_old.inc"
#declare floors=
union{
//the bottom of floor
lathe {
linear_spline
6,
<0,-.5>
<2.04,-.5>
<2.04,0>
<1.99,0>
<1.99,.001>
<1.99,-.3>
texture{pigment{color rgb <1,1,1>}}
difference{
cylinder { <0,-.5,0><0,-.6,0>,1.9
texture{pigment{color rgb <1,.7,.3>}}
finish{
ambient 2.5}
union{
box{<1,-.7,0><4,-.5,.1>
texture{pigment{color rgb <1,1,1>}}}
rotate y*90
translate <0,0,.2>}
rotate y*180
rotate y*270
translate <0,0,-.2>
//glass covering
cylinder {<0,0,0><0,1.5,0>,2
texture{pigment{Col_Glass_Green} }
rotate x*180
translate <0,1.5,0> hollow}
scale <1.5,0,1>}
floors
object {floors translate <0,2,0>}
object {floors translate <0,4,0>}
//the roof
cylinder {<0,0,0><0,.5,0>,2
texture {pigment{color rgb <1,1,1>}}
scale <1.5,0,1>
translate <0,5.5,0>
difference{
texture{pigment{color rgb <1,.7,.3>} }
finish{
ambient 2.5}
translate <0,6,0>
scale <1.5,0,1>}
union{
texture{pigment{color rgb <1,1,1>}}translate <0,6,0>}
rotate y*90
translate <0,6,.2>}
rotate y*180
translate <0,6,0>}
rotate y*270
translate <0,6,-.2>
//end of roof
//the twin tower
//object {floors translate <-6.5,0,.5>}
//object {floors translate <-6.5,2,.5>}
//object {floors translate <-6.5,4,.5>}
//floor
plane {y,-.6
texture {pigment{color rgb <1,1,1>}}}
//sky
plane {y, 20
texture{ Shadow_Clouds}}
//silicon plate
#declare siliconplate=
union{
union{
box {<0,0,-2><5,.2,3>
 texture{pigment{White}}}
#declare slit=
box {<0,.1,0><5,.3,.1>
slit  }
object{slit translate <0,0,1>}
object {slit translate <0,0,2>}
object{slit translate <0,0,3>}
object {slit translate <0,0,-1>}
object {slit translate <0,0,-2>}
object {slit rotate y*90 translate <1,0,3>}
object {slit rotate y*90 translate <2,0,3>}
object {slit rotate y*90 translate <3,0,3>}
object {slit rotate y*90 translate <4,0,3>}
scale <.4,.4,.4>
rotate x*65
translate <-2,6.5,1>}
siliconplate
//end of silicon plate
object{siliconplate translate <2,0,0>}
//THE BEGINNING OF THE CORN LOOP
//the soil
cylinder {<0,-.4,0><0,-.3,0>,2
texture{pigment{color DarkBrown}
normal{wrinkles 5}}
scale <1.5,0,1>}
//green corn, the crop on the bottom
#declare greencorn=
lathe {
5,
<0,0>
<.05,0>
<.07,.25>
<.05,.5>
<0,1>
texture{pigment{color Violet}}scale <.5,.5,.5>}
greencorn
//yellow corn, the crop on the bottom
#declare yellowcorn=
lathe {
5,
<0,0>
<.05,0>
<.07,.25>
<.05,.5>
<0,1>
texture{pigment{color Yellow}
normal{wrinkles 5}}
translate <1,0,0>
scale <.5,.5,.5>}
yellowcorn
lathe {
linear_spline
6,
<0,-.5>
<2.0,-.5>
<2.0,0>
<1.95,0>
<1.95,.001>
<1.95,-.3>
scale <1.5,0,1> }
#declare ctr=0;
#while (ctr <= 5.5)
object {greencorn translate <ctr-2.5 , -.5 ,0>}
#declare ctr = ctr +.1;
#declare ctr=0;
#while (ctr <= 5.5)
object {yellowcorn translate <ctr-3.1 , -.5 ,.25>}
#declare ctr=0;
#while (ctr <= 5.5)
object {greencorn translate <ctr-2.8 , -.5 ,.5>}
#declare ctr=0;
#while (ctr <= 5.5)
object {yellowcorn translate <ctr-3.2 , -.5 ,.75>}
#declare ctr=0;
#while (ctr <= 5)
object {greencorn translate <ctr-2.5 , -.5 ,1>}
#declare ctr=0;
#while (ctr <= 4.3)
object {yellowcorn translate <ctr-2.5 , -.5 ,1.25>}
#declare ctr=0;
#while (ctr <= 4)
object {greencorn translate <ctr-2.0 , -.5 ,1.5>}
#declare ctr=0;
#while (ctr <= 5.5)
object {yellowcorn translate <ctr-3.2 , -.5 ,-.5>}
#declare ctr=0;
#while (ctr <= 5.4)
object {greencorn translate <ctr-2.7 , -.5 ,-.75>}
#declare ctr=0;
#while (ctr <= 5)
object {yellowcorn translate <ctr-3, -.5 ,-1>}
#declare ctr=0;
#while (ctr <= 4.4)
object {greencorn translate <ctr-2.2, -.5 ,-1.25>}
#declare ctr=0;
#while (ctr <= 3.5)
object {yellowcorn translate <ctr-2.2, -.5 ,-1.5>}
//THE END OF CORN LOOP
//START OF TOMATO FARM
//tomato plant, toppest floor
#declare tomatoplant=
union{
union{
union{
union{
union{
union{
union{
union{
#declare tomato=
torus {.1,.2
texture{pigment{color Red}}
scale <.75,.86,.75>}
tomato
#declare fullvine=
union{
difference{
torus{.5,.05
texture{pigment{color Green}}
rotate x*90
box{ <-.2,-.8,-.8><.8,.8,.5>
texture{pigment{color Green}}}
difference{
torus{.5,.05
rotate x*90
translate <-.5,.85,0>
box{ <-.2,-.8,-.8><.7,.8,.5>
translate <-1,.9,0>}
fullvine
#declare stem=
union{
difference{
torus{.5,.05
rotate x*90}
sphere{ <-.2,0,0>,.7
translate <-.4,.5,0>}
stem
object{stem
rotate y*180
scale <.75,.75,.75>
translate <-.3,.6,0>}
object{tomato
scale <.75,.75,.75>
translate <-.4,.7,0>
object {stem
rotate y*90
rotate x*180
scale <.75,.75,.75>
translate <0,.5,-.1>}
object{stem
rotate y*180
rotate x*120
scale <.25,.25,.25>
translate <-.1,1.2,0>
scale <.4,.4,.4>
translate <0,1.9,0>}
tomatoplant
//end of tomato plant
//soil
cylinder{<0,1.5,0><0,1.6,0>,2
normal{wrinkles 5}}
scale <1.5,0,1>}
#declare ctr=0;
#while (ctr <= 5)
object {tomatoplant translate <ctr-2.5 , 0 ,0>}
#declare ctr = ctr +.5;
#declare ctr=0;
#while (ctr <= 5)
object {tomatoplant translate <ctr-2.5 , 0 ,.5>}
#declare ctr=0;
#while (ctr <= 4)
object {tomatoplant translate <ctr-2 , 0 ,1>}
#declare ctr=0;
#while (ctr <= 3)
object {tomatoplant translate <ctr-1.5 , 0 ,1.5>}
#declare ctr=0;
#while (ctr <= 5)
object {tomatoplant translate <ctr-2.5 , 0 ,-.5>}
#declare ctr=0;
#while (ctr <= 4)
object {tomatoplant translate <ctr-2 , 0 ,-1>}
#declare ctr=0;
#while (ctr <= 3)
object {tomatoplant translate <ctr-1.5 , 0 ,-1.5>}
//END OF TOMATO FARM
#declare bokchoy=
union{
union{
union{
union{
union{
union{
//white part of bokchoy
sphere{<0,0,0>,.1
cylinder{<0,0,0> <0,.4,0>,.1
//bokchoy leaves
cylinder{<0,0,0><0,0,.001>,.1
texture{pigment{color rgb <0,1,0>}} scale <0,2.5,0>
translate <0,.4,.09>}
translate <0,.4,-.09>
rotate y*90}
rotate y*-90}
translate <0,.4,-.045>
rotate y*-45}
rotate y*45}
translate <0,7,0>
scale <.5,.5,.5>
bokchoy
lathe {
linear_spline
6,
<0,-.5>
<2.04,-.5>
<2.04,0>
<1.99,0>
<1.99,.001>
<1.99,-.3>
 scale <1.5,0,1>
 translate <0,4,0>}
//START OF BOKCHOY FARM
#declare ctr=0;
#while (ctr <= 5.9)
object {bokchoy translate <ctr-2.9 , 0 ,0>}
#declare ctr = ctr +.25;
#declare ctr=0;
#while (ctr <= 5.7)
object {bokchoy translate <ctr-2.9 , 0 ,.25>}
#declare ctr=0;
#while (ctr <= 5.4)
object {bokchoy translate <ctr-2.7 , 0 ,.5>}
#declare ctr=0;
#while (ctr <= 5)
object {bokchoy translate <ctr-2.7 , 0 ,1>}
#declare ctr=0;
#while (ctr <= 4.3)
object {bokchoy translate <ctr-2.1 , 0 ,1.25>}
#declare ctr=0;
#while (ctr <= 3.7)
object {bokchoy translate <ctr-1.7 , 0 ,1.5>}
#declare ctr=0;
#while (ctr <= 2.2)
object {bokchoy translate <ctr-1 , 0 ,1.75>}
#declare ctr=0;
#while (ctr <= 5.7)
object {bokchoy translate <ctr-2.7 , 0 ,-.5>}
#declare ctr=0;
#while (ctr <= 5.2)
object {bokchoy translate <ctr-2.5 , 0 ,-.75>}
#declare ctr=0;
#while (ctr <= 5)
object {bokchoy translate <ctr-2.7 , 0 ,-1>}
#declare ctr=0;
#while (ctr <= 4.3)
object {bokchoy translate <ctr-2.1 , 0 ,-1.25>}
#declare ctr=0;
#while (ctr <= 3.7)
object {bokchoy translate <ctr-1.7 , 0 ,-1.5>}
#declare ctr=0;
#while (ctr <= 2.2)
object {bokchoy translate <ctr-1 , 0 ,-1.75>}
cylinder{<0,3.5,0><0,3.65,0>,2
texture{pigment{color DarkBrown} normal{wrinkles 10 scale <.25,.25,.25>}}scale
<1.5,0,1>}
//END OF BOKCHOY FARM
Subject: Re: Farm Tower Project
Date: 23 Jul 2009 02:38:01
Message: <4a680549$1@news.povray.org>
Le 23/07/2009 00:17, wildpenguin17 nous fit lire :
> Hello
> thank you!
Need some scale-reference for the human eyes. so far, impossible to know if it is 1
meter
large with small plants, or a 100 m large with normal plants.
I rendered with default 4:3 ratio (as default camera is used), but 3:4 (more vertical)
is
probably better.
There is a lack of internal circulation for human access to the plants (fields of
tomato
need some alleys, hence the hint about actual size of the tower).
also, how to you reach the upper level ? there is no stairway, no elevator columns...
and
no storage for the collected grain/fruit/vegetable. Intensive production calls for a
storage facility... with easy access.
Environment: a grey plane is unrealistic. Why is there a tower ? maybe it's in a sand
desert ? or a sea-emerging tower providing food to a sub-marine complex ? What about
resisting to adverse weather conditions ?
view point: the tower is skewed too much, and from an unrealistic point of view. It's
not
seen from a far away pedestrian, and it's neither seen from an airplane (would be too
low). The view point is also too near the tower, as we see both the floor of the first
level and the top of the last level.
why make a tower with only 3 levels ? that's a complex structure to build, the effort
might be more effective with at least 8 levels. short of that, why not use a simple
ground
culture ? (credibility is a big part of realistic)
Typical hydroponic tomato field raises up to 4 or 5 meters, with suspending horizontal
lines/support. Once reached 6 meters, a level is wasting space for that culture. Waste
is
money!
glass structure: there is no movable protection against too much sun's radiations.
There is no entry to your tower (at least a road access ? would give some hints about
scale)
Textures of solar panel... a single panel, less than the size of a level, seems
unrealistic to power the lighting of many levels. (energy conservation... why convert
to
electrical the light to convert it back to light ?). A field of solar panel around the
tower might provide more credibility (thinks "radio-telescope")
Plants' variation: introduce a bit of "non-repetition" for plants. Also, keep the same
scale for the plants between levels.
Only my 0.02€!
Date: 23 Jul 2009 14:15:00
Message: <web.4a68a7a7c222c3d8b2ea70df0@news.povray.org>
> > Hello
> > thank you!
meter
vertical) is
> probably better.
tomato
columns... and
sand
It's not
too
first
effort
ground
horizontal
Waste is
> money!
about scale)
convert to
the
same
> Only my 0.02€!
Thanks for your opinion! I think it will help me a lot with my project.
I'll take your advice on the solar panels, environment, viewpoint, the number of
tower levels and adding of elevators or something to access the plants on higher
floors.
I also decided to make my tower wider and just show the crop zoomed in on the
side of it, so you actually won't see the plants in the tower, but it will be a
separate image zoomed in.
Thanks a lot, i appreciate it a lot!
Date: 29 Jul 2009 16:15:49
Message: <4a70adf5@news.povray.org>
Hi
I see what you mean.
I think Le_Forgeron has said it pretty well.
I had similar problem with a space station. It was resolved as soon as I put
a space shuttle next to it to give a sense of scale.
Cheers Bob
"wildpenguin17" <nomail@nomail> wrote in message
news:web.4a678fef2558df7b5d6f23280@news.povray.org...
> Hello
> different
> the
> thank you!
> include "glass.inc"
> #declare floors=
> union{
> lathe {
> linear_spline
> 6,
> <0,-.5>
> <2.04,-.5>
> <2.04,0>
> <1.99,0>
> <1.99,.001>
> <1.99,-.3>
> difference{
> finish{
> ambient 2.5}
> union{
> rotate y*90
> translate <0,0,.2>}
> rotate y*180
> rotate y*270
> translate <0,0,-.2>
> //glass covering
> rotate x*180
> scale <1.5,0,1>}
> floors
> //the roof
> scale <1.5,0,1>
> translate <0,5.5,0>
> difference{
> finish{
> ambient 2.5}
> translate <0,6,0>
> scale <1.5,0,1>}
> union{
> rotate y*90
> translate <0,6,.2>}
> rotate y*180
> translate <0,6,0>}
> rotate y*270
> translate <0,6,-.2>
> //end of roof
> //the twin tower
> //floor
> plane {y,-.6
> //sky
> plane {y, 20
> //silicon plate
> union{
> union{
> #declare slit=
> slit  }
> scale <.4,.4,.4>
> rotate x*65
> siliconplate
> //the soil
> normal{wrinkles 5}}
> scale <1.5,0,1>}
> #declare greencorn=
> lathe {
> 5,
> <0,0>
> <.05,0>
> <.07,.25>
> <.05,.5>
> <0,1>
> greencorn
> lathe {
> 5,
> <0,0>
> <.05,0>
> <.07,.25>
> <.05,.5>
> <0,1>
> normal{wrinkles 5}}
> translate <1,0,0>
> scale <.5,.5,.5>}
> yellowcorn
> lathe {
> linear_spline
> 6,
> <0,-.5>
> <2.0,-.5>
> <2.0,0>
> <1.95,0>
> <1.95,.001>
> <1.95,-.3>
> scale <1.5,0,1> }
> #declare ctr=0;
> #while (ctr <= 5.5)
> #end
> #declare ctr=0;
> #while (ctr <= 5.5)
> #end
> #declare ctr=0;
> #while (ctr <= 5.5)
> #end
> #declare ctr=0;
> #while (ctr <= 5.5)
> #end
> #declare ctr=0;
> #while (ctr <= 5)
> #end
> #declare ctr=0;
> #while (ctr <= 4.3)
> #end
> #declare ctr=0;
> #while (ctr <= 4)
> #end
> #declare ctr=0;
> #while (ctr <= 5.5)
> #end
> #declare ctr=0;
> #while (ctr <= 5.4)
> #end
> #declare ctr=0;
> #while (ctr <= 5)
> #end
> #declare ctr=0;
> #while (ctr <= 4.4)
> #end
> #declare ctr=0;
> #while (ctr <= 3.5)
> #end
> union{
> union{
> union{
> union{
> union{
> union{
> union{
> union{
> #declare tomato=
> torus {.1,.2
> tomato
> #declare fullvine=
> union{
> difference{
> torus{.5,.05
> rotate x*90
> difference{
> torus{.5,.05
> rotate x*90
> fullvine
> #declare stem=
> union{
> difference{
> torus{.5,.05
> rotate x*90}
> stem
> object{stem
> rotate y*180
> scale <.75,.75,.75>
> object{tomato
> scale <.75,.75,.75>
> object {stem
> rotate y*90
> rotate x*180
> scale <.75,.75,.75>
> object{stem
> rotate y*180
> rotate x*120
> scale <.25,.25,.25>
> scale <.4,.4,.4>
> tomatoplant
> //soil
> normal{wrinkles 5}}
> scale <1.5,0,1>}
> #declare ctr=0;
> #while (ctr <= 5)
> #end
> #declare ctr=0;
> #while (ctr <= 5)
> #end
> #declare ctr=0;
> #while (ctr <= 4)
> #end
> #declare ctr=0;
> #while (ctr <= 3)
> #end
> #declare ctr=0;
> #while (ctr <= 5)
> #end
> #declare ctr=0;
> #while (ctr <= 4)
> #end
> #declare ctr=0;
> #while (ctr <= 3)
> #end
> #declare bokchoy=
> union{
> union{
> union{
> union{
> union{
> union{
> sphere{<0,0,0>,.1
> //bokchoy leaves
> rotate y*90}
> rotate y*-90}
> rotate y*-45}
> rotate y*45}
> translate <0,7,0>
> scale <.5,.5,.5>
> bokchoy
> lathe {
> linear_spline
> 6,
> <0,-.5>
> <2.04,-.5>
> <2.04,0>
> <1.99,0>
> <1.99,.001>
> <1.99,-.3>
> scale <1.5,0,1>
> translate <0,4,0>}
> #declare ctr=0;
> #while (ctr <= 5.9)
> #end
> #declare ctr=0;
> #while (ctr <= 5.7)
> #end
> #declare ctr=0;
> #while (ctr <= 5.4)
> #end
> #declare ctr=0;
> #while (ctr <= 5)
> #end
> #declare ctr=0;
> #while (ctr <= 4.3)
> #end
> #declare ctr=0;
> #while (ctr <= 3.7)
> #end
> #declare ctr=0;
> #while (ctr <= 2.2)
> #end
> #declare ctr=0;
> #while (ctr <= 5.7)
> #end
> #declare ctr=0;
> #while (ctr <= 5.2)
> #end
> #declare ctr=0;
> #while (ctr <= 5)
> #end
> #declare ctr=0;
> #while (ctr <= 4.3)
> #end
> #declare ctr=0;
> #while (ctr <= 3.7)
> #end
> #declare ctr=0;
> #while (ctr <= 2.2)
> #end
> <1.5,0,1>}
