POV-Ray : Newsgroups : povray.general : Modelling Program Server Time
25 Dec 2025 17:37:25 EST (-0500)
  Modelling Program (Message 1 to 4 of 4)
Subject: Modelling Program
Date: 8 Jul 2009 10:25:01
Message: <web.4a54abe6ad6edd2d7c859cee0@news.povray.org>
I was checking out the spline-tutorial on the povray help file and I read
the following quote:
It is quite difficult to come up with a set of points that describe a given
curve without the help of a modeling program supporting POV-Ray's surface of
revolution object. If such a program is available we should take advantage of
it.
Which freely available program allows you to do this?
Thanks
Subject: Re: Modelling Program
Date: 8 Jul 2009 11:10:00
Message: <web.4a54b6a46f5f79235fd99d9e0@news.povray.org>
> it.
> Thanks
Both Moray http://www.stmuc.com/moray/ and Bishop3D http://www.bishop3d.com/
will allow you to do this. Besides giving you an OpenGL preview they will
output SDL to PovRay for your render.
Moray is free but its development has stalled. Bishop3D is still under
development but is at RC2. Bishop3D has a SDL parser so there is a good chance
that you can import your existing code into it.
Date: 8 Jul 2009 13:01:19
Message: <4a54d0df@news.povray.org>
"Stephen" <mcavoys_AT_aolDOT.com> wrote in message
news:web.4a54b6a46f5f79235fd99d9e0@news.povray.org...
>> given
>> of
>> advantage of
>> it.
>> Thanks
> chance
There are also some little dedicated tools that can do this. For example,
I've used the Spilin editor (see
http://news.povray.org/povray.binaries.utilities/thread/%3C48cf4dea@news.povray.org%3E/)
which is for just this sort of thing and can export POV-Ray prisms, lathes
or SoRs.
You can also convert 2D SVG splines into POV-Ray prism objects using the
free InkScape graphics editor. It won't directly generate SoR or lathe
objects, but it's not too difficult to extract the spline data from the
prism and use it in the other object types.
Chris B.
Date: 20 Jul 2009 23:28:44
Message: <4A6535A4.3080307@joplin.com>
I made one for Lathe and SOR for win 98 its at
http://leroywhetstone.s5.com/
