POV-Ray : Newsgroups : povray.general : The seam of two bi-cubic patches isn't smooth when raised Server Time
26 Feb 2026 21:39:16 EST (-0500)
  The seam of two bi-cubic patches isn't smooth when raised (Message 1 to 5 of 5)
Subject: The seam of two bi-cubic patches isn't smooth when raised
Date: 16 May 2009 14:00:01
Message: <web.4a0efdedfe8cf52d4f15b2600@news.povray.org>
I followed the instructions for joining the two (blue and white, red and white)
patches.  I made sure the coordinates for the forth column of the blue patch:
B14
B24
B34
B44
were the same as the coordinates for the first column of the red patch:
R11
R21
R31
R41
and then added:
#declare R12=B14+(B14-B13);
#declare R22=B24+(B24-B23);
#declare R32=B34+(B34-B33);
#declare R42=B44+(B44-B43);
as per the instruction to smooth out the seam, but when I tested a control point
and raised the seam, it appeared as a sharp edge rather than a smooth edge,
which is what it's not suppose to do.  Anyone know why this happened?
Thanks.
Subject: Re: The seam of two bi-cubic patches isn't smooth when raised
Date: 16 May 2009 15:28:43
Message: <4a0f13eb@news.povray.org>
  For two adjacent bicubic patches to form a smooth surface the control
points in the shared edge must be equal, and the closest inner control
points of each patch, along with their correspondent edge control point,
must form a straight line.
Date: 17 May 2009 20:30:55
Message: <4a10ac3f$1@news.povray.org>
> B14
> B24
> B34
> B44
> R11
> R21
> R31
> R41
> and then added:
> Thanks.
You have two patches, sharing control points along the edge where they
meet, as such:
A00---A01---A02---AB0---B01---B02---B03
A10---A11---A12---AB1---B11---B12---B13
A20---A21---A22---AB2---B21---B22---B23
A30---A31---A32---AB3---B31---B32---B33
In order for the patches to meet smoothly, AB0 must mid-way between A02
and B01, AB1 must be mid-way between A12 and B11, AB2 must be mid-way
between A22 and B21, and AB3 must be mid-way between A32 and B31.
Hope this helps,
John
Date: 18 May 2009 10:58:29
Message: <4a117794@news.povray.org>
  They don't have to be mid-way, as long as A02-AB0-B01 forms a straight
line, and likewise for the other trios.
Date: 19 May 2009 19:54:36
Message: <4a1346bc$1@news.povray.org>
These two images might help you see where you can place the control points:
   http://home.online.no/~t-o-k/POV-Ray_Images/Bezier_Patches_Stitched.jpg
   http://home.online.no/~t-o-k/POV-Ray_Images/Bezier_Patches_Stitched_.jpg
You can find some more Bezier patch stitching images here:
Tor Olav
http://subcube.com
