POV-Ray : Newsgroups : povray.general : Engine heat Server Time
11 Jan 2025 12:37:32 EST (-0500)
  Engine heat (Message 1 to 10 of 11)
Subject: Engine heat
Date: 23 Dec 2008 07:45:00
Message: <web.4950dc7b2d61d8ce4a212ac50@news.povray.org>
I've created an aircraft engine and would like to create an area behind it that
is distorted due to the heat from the exhaust. What's a good way of achieving
this?
-Mike
Subject: Re: Engine heat
Date: 23 Dec 2008 08:32:01
Message: <4950e851@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.4950dc7b2d61d8ce4a212ac50@news.povray.org...
> that
> achieving
> this?
waves/ripples patterned density map applied to scattering media? .... almost
completely transparent. between the camera and object to distort the view. I
also just recalled that you may be able to apply a distortion to the camera,
not 100% sure! The former idea seems like it would be a localized effect,
while the later would have a gloabal effect. Hope that gets some ideas
flowing .....
Jim
Date: 23 Dec 2008 10:17:57
Message: <49510125$1@news.povray.org>
> this?
Maybe try adding random transparent spheres with varying ior.
Date: 23 Dec 2008 13:55:01
Message: <web.495133629a438ed39927d5630@news.povray.org>
> this?
> -Mike
That's a tricky one.
A naive attempt would be to create a transparent cylinder or cone with a
slightly different ior and a disturbed normal. But then you'd get total
reflections at the outline of that object, which will be a mess if the surface
is turbulent enough to be noticeable at all.
An approach I did was to put a plane (no, not the aircraft :)) parallel to the
"screen", using a slightly different IOR for the "rear" side, and setting up a
function to be turbulent only in those areas where the exhaust should be
visible.
Drawback with this one, though, was that I found it to create artifacts when
combined with media, which you may possibly want to use for some engine smoke.
So if you find some solution that really works, please by all means post it here
Date: 23 Dec 2008 14:45:45
Message: <49513fe9$1@news.povray.org>
Jim Holsenback nous illumina en ce 2008-12-23 08:32 -->
>> that
>> achieving
>> this?
> flowing .....
> Jim
A media won't distort anything.
A distortion applied to the camera will tent to affect the whole scene. It you
manage to restrict it to a given location, you'll have to change it if you
change anything. It won't work if there is anything between the camera the the
parts that you want perturbed.
Some emissive media can be used to make the flame of the exaust visible.
My take would be to place a long cylinder or a cone with pigment rgbt 1 give it
an ior around 0.99 and use a slight normal perturbation: normal{bozo 0.1
scale<100,1,1>} for a jet along the x axis. Rotate as needed.
Don't waste your time on a man/woman, who isn't willing to waste their time on you.
Date: 23 Dec 2008 14:52:33
Message: <49514181@news.povray.org>
clipka nous illumina en ce 2008-12-23 13:52 -->
>> this?
>> -Mike
With an ior just very slightly less than 1, as the heated air should be, that
effect will only affect a very narrow area and may not be noticeable.
You can use 2 cylinders or cones, or a cylinder and a cone. The outer one get an
ior around 0.999 and the inner one about ior 0.99.
You can also flatten those: scale<0.5,1,0.5>. This will make the areas where the
problem may occurs even smaller.
> visible.
   I knew a girl so ugly that she was known as a two-bagger. That's When you put
a bag over your head in case the bag over her head comes Off.
	Rodney Dangerfield
Date: 23 Dec 2008 17:10:00
Message: <web.495161b19a438ed39927d5630@news.povray.org>
Hah! Jim's idea is not so stupid after all; you're only correct as long as you
use "standard" Type 1 (isotropic) scattering. But if you use Type 2 (Mie haze)
or, probably better yet, Type 3 (Mie murky) scattering, this might actually get
you somewhere...
It's definitely not an exact model of what is really happening with hot air, but
still it's definitely worth a try.
Tried that. My experience is that if you pertube it strongly enough to get any
noticeable effect, you get ugly outlines due to total reflections.
Date: 23 Dec 2008 20:05:00
Message: <web.495189e19a438ed3289e01370@news.povray.org>
> > this?
That sounds like a good idea. I tried nesting a series of cones, but it didn't
look so hot.
-Mike
Date: 24 Dec 2008 06:38:55
Message: <49521f4f@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:49513fe9$1@news.povray.org...
> give it an ior around 0.99 and use a slight normal perturbation:
> normal{bozo 0.1 scale<100,1,1>} for a jet along the x axis. Rotate as
> needed.
Expanding on the cone idea .... rib the cone with tori. Afterburning engines
gable the exhaust nozzle from cylinder to cone-ish shape, and the exhaust
plume has these bright rings along it's length.
Jim
Date: 24 Dec 2008 09:03:32
Message: <49524134@news.povray.org>
"Jim Holsenback" <jho### [at] hotmailcom> wrote in message
news:49521f4f@news.povray.org...
>> needed.
> engines gable the exhaust nozzle from cylinder to cone-ish shape, and the
> exhaust
meant to say gimble
