POV-Ray : Newsgroups : povray.general : How to store/read the results of rotating a point in space in SDL Server Time
25 Feb 2025 01:32:31 EST (-0500)
  How to store/read the results of rotating a point in space in SDL (Message 1 to 5 of 5)
Subject: How to store/read the results of rotating a point in space in SDL
Date: 31 Oct 2008 08:20:00
Message: <web.490af6c6e21271d2ad9dd8b40@news.povray.org>
Hi folks.  After having been away from the group for a while, I was hoping to
return by posting a really neat image... However, it turns out that I could use
a bit of help producing that image.
I get the feeling that I'm missing something pretty basic in SDL.  Given the
basic nature of what it does, it SEEMS like it should be pretty easy to apply a
rotation to a point in space and get back the result as a standard vector value.
Here's an easy example:
If the point <0,10,3> is rotated 90 degrees about the y axis, the result is
<3,10,0>.
Now, I can store the value of the starting point like this:
#declare POINT1 = <0,10,3>;
....and I can use POINT1 as a value for placing objects, but...
HOW do I code:  #declare POINT2 = ???? //POINT1 rotated in a given way
I could, eventually, accomplish the rotations with a "do-it-yourself" method
based upon basic trig functions, but that seems an awful lot like re-inventing
the wheel in the middle of a wheel factory.  I'm thinking that there's GOT to
be a simple way to do this and that I'm just having an "elder moment".
Thanks in advance for all replies.
Best Regards,
Mike C.
Subject: Re: How to store/read the results of rotating a point in space in SDL
Date: 31 Oct 2008 08:36:35
Message: <490afbd3@news.povray.org>
> <3,10,0>.
#declare POINT2 = vrotate(POINT1, y*90);
Date: 31 Oct 2008 08:50:00
Message: <web.490afe28ceeff6f3ad9dd8b40@news.povray.org>
> > <3,10,0>.
That's what I kept missing (kept searching docs under "rotate").
Thanks!
Date: 31 Oct 2008 11:11:15
Message: <490b2013$1@news.povray.org>
Mike the Elder escreveu:
>>> <3,10,0>.
>>                                                           - Warp
> Thanks!
Povray has many handy functions in the standard include files.  They are
documented too.
Date: 31 Oct 2008 16:18:18
Message: <490b680a@news.povray.org>
> documented too.
vrotate isn't even in include files, but built-in :)
