POV-Ray : Newsgroups : povray.general : projector Server Time
20 Nov 2025 09:34:54 EST (-0500)
  projector (Message 1 to 6 of 6)
Subject: projector
Date: 27 Oct 2008 12:40:00
Message: <web.4905eeb55b9956825c2817dc0@news.povray.org>
hello!
i am thinking about generating a synthetic ground-truth benchmark image for a 3d
scanner using povray. therefore i would like to know if and how it is possible
to simulate a video projector in povray.
it should be possible to simulate each projector pixel using a spotlight and
place a lens in front of the array, but that would be extremely tedious and
probably inaccurate.
is there a way to project a bitmap onto a scene, ideally with finite
depth-of-field? after all, a projector is just a reverse camera ...
thank you
Subject: Re: projector
Date: 27 Oct 2008 13:15:15
Message: <4905f723@news.povray.org>
  Simply put the image onto a plane, apply filter 1 to it and put a
light source behind it. All the lighting from that light source on the
other side of the plane will be filtered by the image map, so it effectively
projects the image.
Date: 27 Oct 2008 13:24:31
Message: <4905f94f@news.povray.org>
"Christoph" <nomail@nomail> wrote in message
news:web.4905eeb55b9956825c2817dc0@news.povray.org...
> hello!
> for a 3d
> possible
> and
> and
Yes. You may find the following example helpful. It projects a bitmap onto
the scene, which, in this case is just a plane.
The bitmap is projected by placing it in front of a light source and adding
a filter filtering all of the colours in the image at their full intensity
('filter all 1'). I'm not sure how you'd go about adding a depth of field.
Chris B.
camera {location <-0.4,0.4,-1.4> look_at 0}
global_settings {ambient_light 0.05}
// Image to project
plane {z,-0.9
    image_map {
      sys "gear00.bmp"
      once
      filter all 1
    scale 0.1
    translate -0.05
// Projector
light_source {<0,0,-1>, rgb 1}
cone {<0,0,-1>,0,<0,0,-0.97>,0.02
  no_shadow
    pigment {rgb <1,0,0>}
    finish {ambient 10}
// Screen
box {<-0.5,-0.5,0>,<0.5,0.5,0.01> pigment {rgb 1}}
Date: 27 Oct 2008 19:05:00
Message: <4906491c@news.povray.org>
If you want to simulate a real projector, you probably need to
model the lens. Of course, you can project the image just using
a point light source (basically an inverse pinhole camera model).
To get your image through the lens, you need to use photons (or
radiosity, but I think that would be painful to use here).
I once tried something like that, maybe it helps you get started:
http://news.povray.org/povray.general/attachment/%3C486aa74c@news.povray.org%3E/us-ascii
You should get depth-of-field when you model the lens.
Date: 27 Oct 2008 20:34:50
Message: <49065e2a@news.povray.org>
> for a 3d scanner using povray. therefore i would like to know if and how
> it is possible to simulate a video projector in povray.
> and place a lens in front of the array, but that would be extremely
> tedious and probably inaccurate.
Depends on what you want. If you want it to look like a reallife projector,
you should probably use one of the suggestions you already got (using a
light and a texture acting as a filter).
If you really want a "reverse camera", use Rune's "illusion" include file:
http://runevision.com/3d/include/illusion.zip
Date: 28 Oct 2008 05:50:00
Message: <web.4906dfc2ee5b8dc45c2817dc0@news.povray.org>
thank you very much, this looks promising!
