POV-Ray : Newsgroups : povray.general : request for pigment help Server Time
18 Mar 2026 12:43:22 EDT (-0400)
  request for pigment help (Message 1 to 10 of 12)
Subject: request for pigment help
Date: 26 Oct 2008 15:00:01
Message: <web.4904bd7445e043c998cd18890@news.povray.org>
I want to apply a color map to a torus so that the maps are applied as wedges
when viewing a cross-section of the torus.
(I think this would be radially, but I am unsure.)
Can some give me a simple example of this?
Thanks in advance.
Leef_me
Subject: Re: request for pigment help
Date: 26 Oct 2008 16:52:08
Message: <4904d878$1@news.povray.org>
"Leef_me" <nomail@nomail> wrote in message
news:web.4904bd7445e043c998cd18890@news.povray.org...
> wedges
> Thanks in advance.
> Leef_me
Do you mean something like:
camera {location <0,2,-4> look_at 0}
light_source {<-1,50,10>, rgb 0.4}
torus { 1, 0.1
    radial
    color_map {
      [0.0  color rgb <1,0,0>]
      [0.3  color rgb <1,0,0>]
      [0.3  color rgb <0,1,0>]
      [0.6  color rgb <0,1,0>]
      [0.6  color rgb <0,0,1>]
      [1.0  color rgb <0,0,1>]
Date: 26 Oct 2008 18:54:36
Message: <zGPz2+HvTPBJFwAz@econym.demon.co.uk>
Use map_type 5.
Create your torus with major axis equal to 1, because that's where the
map_type 5 pigment radiates from, then scale it to the size you require
after applying the pigment.
difference {
   torus {1, 0.6}
   box {<0,-1,-2> <2,1,0>}
     image_map {jpeg "test.jpg" map_type 5}
   scale 4
Mike Williams
Gentleman of Leisure
Date: 26 Oct 2008 19:20:26
Message: <4904fb3a@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4904d878$1@news.povray.org...
>> wedges
>> Thanks in advance.
>> Leef_me
Or. To give you a pattern like a pie chart on the twin circular sections
through the torus, the only way I can think of is to build it up using cone
objects for textures rather than a color map. (I tried experimenting with
toroidal warp of a gradient and a radial texture, but failed to get anything
that mapped a color map in that way).
The following example builds a layered texture using planes and cones that
follows the circular path around the torus.
light_source {<-1,5,-50>, rgb 1}
difference {
  torus { 1, 0.4}
  plane {z,0}
  texture {pigment {rgb <1,1,1>}}
      object {
        plane {y,0}
        color rgb <1,1,0>
        color rgbt 1
      object {
        difference {
          cone {0,1,y,1.5}
          cone {0,1,y,0.5}
        color rgbt 1
        color rgb <1,0,0>
      object {
        cone {0,1,-y,0.5}
        color rgbt 1
        color rgb <0,1,0>
Date: 26 Oct 2008 20:08:00
Message: <49050660$1@news.povray.org>
news:4904fb3a@news.povray.org...
>>> wedges
> cone objects for textures rather than a color map. (I tried experimenting
> with toroidal warp of a gradient and a radial texture, but failed to get
> anything that mapped a color map in that way).
Interesting solution, if this is the thing being asked for.
Yeah, when I saw this message post I was going to try radial, then warp it,
just to see if it could be done the way I figured would work right and it
only gets nearly there:
// BEGIN wedges in torus cutaway
 location -3*z
 look_at 0
 rotate <30,0,0>
light_source {
 -99*z,
 1
 rotate <60,45,0>
difference {
 torus {
  1,0.5
 plane {
  x,0
  rotate -90*y
   radial frequency 40
   color_map {
    [0.5 rgb 0.1]
    [0.5 rgb 0.9]
   rotate 90*z
   warp {
    toroidal orientation y dist_exp 1 major_radius 1
  } // pigment
// END
For reasons unknown to me the pattern doesn't have the symmetry I expected.
Maybe somebody out there understands why not...?
Bob H.
Date: 26 Oct 2008 22:05:00
Message: <web.49052186d757dcd7892adb1d0@news.povray.org>
> >>> wedges
> camera {
>  location -3*z
>  look_at 0
>  rotate <30,0,0>
> light_source {
>  -99*z,
>  1
>  rotate <60,45,0>
> difference {
>  torus {
>   1,0.5
>  plane {
>   x,0
>   rotate -90*y
>  texture {
>   pigment {
>    radial frequency 40
>    color_map {
>     [0.5 rgb 0.1]
>     [0.5 rgb 0.9]
>    rotate 90*z
>    warp {
>   } // pigment
> // END
> Bob H.
Hi Guys,
So far, Bob got the idea of what I was looking for, but I still have one
concern.
I want to control how many sections there are, it seems to be related to
"radial frequency 30" and maybe the number of entries in the color_map.
Any suggestions on understanding this?
FYI,
I want to make some areas of the cross-section transparent (hence the rgbt).
I want to be able to animate the rotation of the colors around the section. That
seems controllable e.g. "rotate x * frame_number"
Fwiw Here's my version based on Bob's code:
 location -3*z
 look_at 0
// rotate <30,0,0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
 -10*z,
 1
 //rotate <60,45,0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
difference {
 torus {
  1,0.5
 torus {
  1,0.45
 plane {
  x,0
  rotate -90*y
   radial frequency 30
   color_map {
      [0.25  color rgb <1,0,0>]
      [0.50 color rgb <0,1,0>]
//      [0.50 color rgbt <0,0,1>]
      [0.75 color rgbt <0,0,1,1>]
      [1.00 color rgbt <1,1,1>]
   rotate 90*z
   warp {
  } // pigment
// END
Date: 27 Oct 2008 00:25:43
Message: <490542c7@news.povray.org>
news:web.49052186d757dcd7892adb1d0@news.povray.org...
> concern.
Well, Chris was onto something good there first. And when I saw Mike's image
map idea that seemed easiest, I'm just not sure if a single image with
horizontal lines can be changed (increasing/decreasing number of wedges)
within POV alone by scaling for example since I also can't remember that
about map_type 5.
That's part of what confused me. I must admit I haven't used the toroidal
warp in what's probably been years. Maybe never with radial pattern. I
thought it would take one slice of radial pattern and wrap it using the
exact number of iterations from frequency. Of course, I could still be doing
something wrong.
> FYI,
> rgbt).
> section. That
You have the right iea there, I believe, yes. Although, a quick check on
that shows once again something isn't right about my using frequency 30 to
get the much fewer wedges than expected and how it rotates. For instance,
using rotate x*48*clock with that and your color_map seems to complete
approx. one revolution, so the usual x*360*clock is far too much (360 being
degrees, of course) instead of going one time around. Due to the multiples
caused by 30 in frequency, perhaps, yet that still doesn't match up. A
frequency 1 and a color map list of a specific number of entries seems to
not be right either for whatever reason.
So unless something can be done about figuring the correct way to get a
singular radial pattern mapped into the torus it won't be simple to animate.
Which is why I'm thinking Mike has the best solution using image_map and
map_type 5, if you just give it a palletted image to work with the colors
and transparency.
But I can't help wonder what's going on with radial pattern being warp'd and
not adhereing to its original pattern, distorting in a somewhat non-toroidal
way or imperfectly anyhow. Maybe...
See previous message...
/*bob hughes*/
Date: 27 Oct 2008 08:37:12
Message: <4905b5f8$1@news.povray.org>
Frequency makes different sections indistinguishable.
To make the segments different colors, you need to use the map.
For example, if the map is from 0 to 1 around the circle, and you want 12 equal
segments, you:
[1/12 pigment1]
[1/12 pigment2]
[2/12 pigment2]
[2/12 pigment3]
[3/12 pigment3]
[3/12 pigment4]
etc.
Dan
Date: 27 Oct 2008 11:01:10
Message: <4905d7b6$1@news.povray.org>
Leef_me nous illumina en ce 2008-10-26 22:03 -->
> Hi Guys,
> concern.
> FYI,
> camera {
>  location -3*z
>  look_at 0
> // rotate <30,0,0>
> sky_sphere {
>   pigment {
>     gradient y
>     color_map {
> light_source {
>  -10*z,
>  1
>  //rotate <60,45,0>
> light_source {
> difference {
>  torus {
>   1,0.5
>  torus {
>   1,0.45
>  plane {
>   x,0
>   rotate -90*y
>  texture {
>   pigment {
>    radial frequency 30
>    color_map {
>    rotate 90*z
>    warp {
>   } // pigment
> // END
Instead of using a rotation, why not use phase?
It becomes:
    radial frequency 30
    color_map {
    } phase clock //added
    rotate 90*z
    //rotate x * frame_number commented out
    warp {
That way, it work for any frequency, and for an animation with any number of
frames. If you add +kc in the command line options or the ini file, you'll get a
smooth continuous rotation.
I believe that banking institutions are more dangerous to our liberties than
standing armies. Already they have raised up a monied aristocracy that has
set the government at defiance. The issuing power should be taken from the
banks and restored to the people to whom it properly belongs.
Thomas Jefferson
Date: 27 Oct 2008 14:15:31
Message: <49060543$1@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:4905d7b6$1@news.povray.org...
> It becomes:
> texture {
>   pigment {
>    radial frequency 30
>    color_map {
Forgot to mention before about this last color map entry not being needed.
>    rotate 90*z
>    warp {
> of frames. If you add +kc in the command line options or the ini file,
> you'll get a smooth continuous rotation.
Good idea, but in this case it might not be able to do what's wanted if a
frequency number is used.
I found that frequency 8 is what creates one complete color map for this.
Multiples of 8 make duplicates, so 32 creates 4 instances of color map.
It's a strange thing that might be a bug in how this particular warp gets
applied to radial pattern, along with the curious shrinking from zero to one
for the color entries and any duplicates of the whole.
For a better look at it try this:
 location -3*z
 look_at 0
 angle 50
 translate -x
difference {
 torus {
  1,0.5
 plane {
  x,0
  rotate -90*y
   radial frequency 8 // 8 creates a complete circuit of radial, use
multiples for more
   color_map {
    [0 blue 1] // make beginning more visible
    [0.1 rgb 0.1]
    [0.9 rgb 0.9]
    [1 red 1] // make ending more visible
   //triangle_wave // use frequency 4, or half number when not ramp_wave
form
   //phase clock
   rotate -90*z
   warp {
    toroidal orientation <0,1,0> dist_exp 1 major_radius 1
  finish {
   ambient 1 diffuse 0
You will notice how the pigment pattern apparently compresses as it wraps
around the torus in a CC direction.
Bob H
