Hello, how can I remove artifacts in the shadow of an isosurface?
For exemple, I will compare the image of a sphere and the image of a sphere
created with isosurface.
This code give a good smoothed shadow :
camera {location <0,0,-4> look_at 0}
light_source {<-100,200,-100> color rgb 1}
sphere {0 1 pigment {rgb .9} }
But if I try the same with an isosurface, this code give artifacts :
isosurface {
function{x*x+y*y+z*z-1}
max_gradient 4
contained_by{sphere{0,1.1}} open
pigment {rgb .9}
Please see the pictures that illustrate this here :
http://quark67.free.fr/isosurface.html
Thanks for your help.
Sorry for bad english, this is not my first language.
>isosurface {
> max_gradient 4
> pigment {rgb .9}
You can decrease the accuracy. In this case try
accuracy 0.00001
The downside is that as the accuracy gets smaller, the render time
increases.
Mike Williams
Gentleman of Leisure
> accuracy 0.00001
> increases.
> Mike Williams
Hello, you can see in the web page http://quark67.free.fr/isosurface.html what
an
accuracy 1e-6
get after "code 4" on the page (1e-6=0.000001).
This is not better :(
>> accuracy 0.00001
>> increases.
>> Mike Williams
>an
>accuracy 1e-6
It looks better than that for me. What anti-aliassing are you using?
Mike Williams
> Mike Williams
Sampling Method : Adaptive
Threshold:0.3
Recursion depth:3
Jitter:1.0
Have you a different setting?
Can I see what you obtain please? (and your code and setting).
Thanks.
Ooops! I just read your mail adress and I see that I'm speak with the author of
a very good isosurface tutorial ;) Thanks for your work!
