POV-Ray : Newsgroups : povray.general : dds and tga in povray Server Time
13 Oct 2025 04:25:12 EDT (-0400)
  dds and tga in povray (Message 1 to 5 of 5)
Subject: dds and tga in povray
Date: 28 Jul 2008 12:15:01
Message: <web.488def156187cac1a911672a0@news.povray.org>
Hi
I have been working with making a spore creature and then export it in .mesh
file. Then I convert it with uu3d to the .obj format.
So I want to render my creature which is named creature a.obj and uses an dds
texture file...
But it writes this to me
//POV-Ray Materials list
//This file has been created by PoseRay v3.11.0.436
//3D model to POV-Ray/Moray Converter.
//Author: FlyerX
//Email: fly### [at] yahoocom
//Web: http://mysite.verizon.net/sfg0000/
//Files needed to run the POV-Ray scene:
//creature_a_POV_main.ini (initialization file - open this to render)
//creature_a_POV_scene.pov (scene setup of cameras, lights and geometry)
//creature_a_POV_geom.inc (geometry mesh)
//creature_a_POV_mat.inc (materials)
//SP-RAST-2F4E681C-40622900-06B77AA1-mm00.dds
#include "stdinc.inc"
//Map definitions
#declare p_map1=pigment {image_map{dds "C:\Documents and
Settings\Administrator\Desktop\WORK
Spore\SP-RAST-2F4E681C-40622900-06B77AA1-mm00.dds" interpolate 2 transmit all 0
filter all 0} }
//Material definitions
#declare creature_texture_=
material{
texture{ pigment{ p_map1}
        finish{specular 0 roughness 0.2401081 ambient rgb <0,0,0> diffuse 0.6
reflection{0 metallic} conserve_energy}}
The #declare part is in yellow. I presume that povray dont like dds texture
files.
I have tried converting the dds to tga but that made the texture all blue and
not colourfull. It did not work.
So I want to hear if there is a way of using .dds texture files in povray. Is
there some plugin or files I can install to make it accept these kind of
texture files.
Hope you can help and please remember I am really a povray newb aswell as within
3d programs.
Subject: Re: dds and tga in povray
Date: 28 Jul 2008 12:38:25
Message: <488df601$1@news.povray.org>
"karmacowboy" <tru### [at] ofirdk> wrote in message
news:web.488def156187cac1a911672a0@news.povray.org...
> Hi
    Hi and welcome
     Are you using DDS Converter 2.1? If not, use this to convert to JPEG
images.
          http://eliteforce2.filefront.com/file/DDS_Converter;29412
        For Crysis?  :)
       ~Steve~
Date: 28 Jul 2008 13:15:00
Message: <web.488dfe81ec1eec60a911672a0@news.povray.org>
Yes, I have tried it but the creature is all blue and not the original colours.
It is a bit special because I use a game editor to design a creature then I use
a program called spview to extract the .mesh ...later on converts it to .obj
along with the .dds which should be able to render in povray.
There are perhaps a problem with the spview program which is not commersial. So
I will contact the maker of it!
Thanks for your help. I was just not sure if it was possible to use .dds files
in povray or I do need tga for it to texture my creature!
J.
Date: 28 Jul 2008 13:31:56
Message: <488e028c$1@news.povray.org>
DDS files are not supported directly AFAIK.  I'm not familiar with the
format myself, but I did run into a GIMP plugin for DDS files you could
try: http://nifelheim.dyndns.org/~cocidius/dds/  If this DDS format
stores more than just a raster image, it may be why you are having trouble.
-The Mildly Infamous Blue Herring
Date: 28 Jul 2008 17:31:53
Message: <488e3ac9$1@news.povray.org>
news:web.488dfe81ec1eec60a911672a0@news.povray.org...
> colours.
   I use CE2(Crytek). Which game editor are you using?
> .obj
    No, I'm sorry, afaik, PoV-Ray doesn't support .dds files. (It would be
cool if it did). :)
> commersial. So
> files
     No probs, (I like to help when and if I can), but why .tga only?
       ~Steve~
       J.
