I've created the following parametric object:
#local Wid = 1/2;
#local Hgh = 1/2;
#local Thk = 1/32;
#local Trn = 256/Hgh/64;
parametric
function { (1/2 - v * Thk) * cos(Trn * u * 2 * pi) },
function { 1 * u },
function { (1/2 - v * Thk) * sin(Trn * u * 2 * pi) }
<0,0>, <1,1>
contained_by { box {<-1/2,0,-1/2,>, <1/2,1,1/2,>} }
max_gradient 1/1000
accuracy 1/1000
precompute 20 x,y,z
scale <Wid,Hgh,Wid,>
I was wondering if there were a quicker alternative that I hadn't thought of?
Thanks!
-Mike
I just tested the Helix and Helix_1 shapes in "shapes1.inc", and the result has
a very weird shape, especially when viewed from the top. Is this the way it's
supposed to look? It doesn't look much like a helix.
-Mike
You could always try to create a triangle mesh from those functions.
The code will be quite complicated, but the result will render extremely
fast.
> fast.
> - Warp
Thanks, that's a good idea. I was hoping to avoid doing this though, as it's a
bit more involved.
-Mike
>> >thought of?
>> fast.
>> - Warp
>bit more involved.
There's a macro by Ingo Janssen that creates a mesh2 of smooth triangles
from a set of parametric equations. It's an awful lot faster than
parametric isosurfaces, and you can save the mesh to a file.
See: http://www.econym.demon.co.uk/isotut/param.htm
Mike Williams
Gentleman of Leisure
> Mike Williams
Wow! I completely forgot about that. Thanks for the tip!
Anyway, I ended up doing the mesh by hand. It wasn't that difficult after all.
-Mike
> >> >thought of?
> >> fast.
> >> - Warp
> >bit more involved.
> Mike Williams
The link on that page doesn't work anymore, but I found the files here:
http://code.google.com/p/mmgm/
H
