POV-Ray : Newsgroups : povray.general : Koordinates Baking part2 Server Time
12 Apr 2026 05:35:54 EDT (-0400)
  Koordinates Baking part2 (Message 1 to 3 of 3)
Subject: Koordinates Baking part2
Date: 5 Mar 2008 10:20:01
Message: <web.47ceb88f1bde76ade410cd5a0@news.povray.org>
Hi people!
Here:
http://news.povray.org/povray.general/thread/%3Cweb.47b9887c93fc6a8bf8a489ba0%40news.povray.org%3E/
I was asking about coordinates baking.
Now I have the problem, that an object will be translated and rotated and this
couple of times:
1.: I rotate an object around <0,0,0>
2.: Then I translate it to <1,0,0>
3.: Now I'm rotating it again (again around <0,0,0>)
If I use vrotate, I need to give at step 3 the new position of my vector:
#declare MyVector_Rotation=vrotate(MyVector_Position,<10,20,30>) for example
but where is my first rotation, assigned at step 1?
How to give the vrotate my Position AND my (older) orientation?
Maybe, I have some confusing how to use the rotation vector, after using
vrotate?
After calkulating the vectors, I would give the objects the following
coordinates like this:
rotate MyVector_Rotation
translate MyVector_Position
Is that right?
Subject: Re: Koordinates Baking part2
Date: 5 Mar 2008 16:01:33
Message: <47cf0a2d$1@news.povray.org>
> this
> couple of times:
> example
> vrotate?
> Is that right?
To rotate around some arbitrary center point instead of <0,0,0>
just translate your point by the assumed center, rotate, then
move it back.
#local Point = <0.5,0.5,0>; // some point
#local CenterPoint = <1,2,3>; // center to rotate around
#local Rotation = <10,20,30>; // rotation angles
#local ResultPoint =  vrotate(Point-CenterPoint,Rotation)+CenterPoint;
Date: 6 Mar 2008 05:10:01
Message: <web.47cfc28f8969e9b3cdff2f210@news.povray.org>
This helps!!
Thanx man!!
