POV-Ray : Newsgroups : povray.general : Help with plotting a parametric equation Server Time
23 Dec 2025 01:05:54 EST (-0500)
  Help with plotting a parametric equation (Message 1 to 10 of 13)
Subject: Help with plotting a parametric equation
Date: 16 Jan 2008 02:45:00
Message: <web.478db59093155640368884fc0@news.povray.org>
I have gotten in a dispute at Wikipedia
(http://en.wikipedia.org/wiki/Talk:HSL_and_HSV#Sphere). I'm trying to plot the
following parametric formula:
http://img252.imageshack.us/img252/1194/parametricformulaqy3.png
Here's what I've got so far:
#local cone_count_h = 0;
#local cone_count_s = 0;
#local cone_count_l = 0;
#local cone_max_h = 12;
#local cone_max_s = 6;
#local cone_max_l = 6;
#local cone_interval_h = 360/cone_max_h;
#local cone_interval_s =   1/cone_max_s;
#local cone_interval_l =   1/cone_max_l;
#local cone_max_i = 1000;
#while (cone_count_h < cone_max_h)
 #local cone_h = cone_count_h * cone_interval_h;
 #while (cone_count_s < cone_max_s)
  #local cone_s = cone_count_s * cone_interval_s;
  #while (cone_count_l < cone_max_l)
   #local cone_l = cone_count_l * cone_interval_l;
   #local new_var = 2 * cone_l - 1;
   #local f_of_new_var = sqrt(1 - pow(new_var, 2));
   #local x_coo = f_of_new_var * cone_s * cosd(cone_h);
   #local y_coo = f_of_new_var * cone_s * sind(cone_h);
   #local z_coo = new_var;
   sphere
    < x_coo, z_coo, y_coo>, 0.05
    texture
     pigment {rgb <1,0,0>}
     pigment {rgb CHSL2RGB(<cone_h/360, cone_s, cone_l>)}
   #local cone_count_l = cone_count_l + 1;
  #local cone_count_s = cone_count_s + 1;
 #local cone_count_h = cone_count_h + 1;
What am I doing wrong?
Subject: Re: Help with plotting a parametric equation
Date: 16 Jan 2008 06:58:16
Message: <478df158$1@news.povray.org>
> the
>   sphere
>    texture
>  #end
> #end
> #end
The z coordinates are just sqrt(1 - pow(new_var, 2))...
as stated by the parametric you linked, but that is just a
single cone, not a double cone.
Date: 16 Jan 2008 13:40:00
Message: <web.478e4f713284050c368884fc0@news.povray.org>
I've replaced the z coordinate of the parametric equation with sqrt(1 -
pow(new_var, 2)) in place of new_var as you said, and I can't perceive an
improvement. Maybe I'm misunderstanding the instructions you gave me. Would you
mind posting a fixed version of the code, instead? Thank you very much.
Date: 16 Jan 2008 13:45:00
Message: <web.478e4fc03284050c368884fc0@news.povray.org>
By the way, here's my camera code. Maybe that is the problem?
camera
 #local CameraDistance = 10;
 #local ScreenArea = 5;
 #local AspectRatio = image_width/image_height;
// orthographic
 location -z*CameraDistance
 direction z*CameraDistance
 right     x*ScreenArea*AspectRatio
 up        y*ScreenArea
// rotate x*asind(tand(30))
// rotate y*225
Date: 16 Jan 2008 17:04:37
Message: <478e7f75$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.478e4fc03284050c368884fc0@news.povray.org...
>> Would you
> camera
> // orthographic
> up        y*ScreenArea
> // rotate y*225
This is a single cone, not a double one...
#include "math.inc"
   location  <0.5, 0.5, -4.0>
   direction 1.5*z
   look_at   <0.5, 0.0,  0.0>
background {Gray50}
// helper function
#declare f_of_z = function(z) {sqrt(1-(z*z))};
// parametric functions as described in post
// x = hue [0..360), y = saturation [0..1], z = luminance [0..1]
#declare x_value = function(x,y,z) {f_of_z(z)*y*cosd(x)};
#declare y_value = function(x,y,z) {f_of_z(z)*y*sind(x)};
#declare z_value = function(x,y,z) {f_of_z(z)};
union {
#declare Hue_Count = 0;
#while (Hue_Count < 360)
   #declare Sat_Count = 0;
   #while (Sat_Count <= 1)
      #declare Lum_Count = 0;
      #while (Lum_Count <= 1)
         #local HSLLOC = <x_value(Hue_Count,Sat_Count,Lum_Count),
                          y_value(Hue_Count,Sat_Count,Lum_Count),
                          z_value(Hue_Count,Sat_Count,Lum_Count)>;
         #local C = CHSL2RGB(<Hue_Count,Sat_Count,Lum_Count>);
         sphere {HSLLOC,0.05
            pigment{color C}
            finish {ambient 1}
         #declare Lum_Count=Lum_Count+0.05;
      #declare Sat_Count=Sat_Count+0.1;
   #declare Hue_Count=Hue_Count+6;
  rotate <0,45,0>
Date: 16 Jan 2008 22:55:00
Message: <web.478ed1803284050c368884fc0@news.povray.org>
> <code>
Your code results in a crash and the following error:
"POV-Ray dore rendering code threw an unhandled exception."
Anyway, nevermind. I was able to input the values into another software and plot
the points that way. I'll go back and check later to see what I did wrong when I
have the time.
Also, it's not a cone, it's a sphere.
Date: 17 Jan 2008 05:36:58
Message: <478f2fca$1@news.povray.org>
> and plot
> when I
> have the time.
I didn't have any crashes... oddness....
It looks like a cone to me.
http://s201.photobucket.com/albums/aa280/Zakardis/?action=view&current=color_sphere3.jpg
Date: 17 Jan 2008 16:15:00
Message: <web.478fc4263284050c7ba03b340@news.povray.org>
You have to look at the *entire* area of text I circled in the image. Beneath
the big, bold parametric equation are variable definitions, where additional
equations are used.
As for the crashes, I don't know what is causing them. Usually, if there's a
typo or some error in copying and pasting text into the edit window, the
program will simply quit parsing and give a minor error in the status bar or
"Messages" tab.
Date: 17 Jan 2008 18:35:01
Message: <web.478fe5243284050c7ba03b340@news.povray.org>
> equations are used.
> "Messages" tab.
Due to the server formatting news posts in the web interface of the newsgroup,
it appears as if I added the above URL to an image. Just to clear things up,
the image I am referring to is the image I linked to in my first post.
Date: 17 Jan 2008 20:05:01
Message: <web.478ffb303284050c7ba03b340@news.povray.org>
> equations are used.
Looking at your code again, I see that you did, in fact, notice this. I assumed
this was not the case since you said the shape was that of a cone (which the
bold lettering is the parametric formula of). However, in your equation you set
z to equal L instead of 2L - 1, resulting in the (rounded) conical shape.
