POV-Ray : Newsgroups : povray.general : second life conversions Server Time
19 Mar 2026 02:45:32 EDT (-0400)
  second life conversions (Message 1 to 4 of 4)
Subject: second life conversions
Date: 15 Aug 2007 11:25:00
Message: <web.46c31a51a9851309a71cce4c0@news.povray.org>
I decided to re-create an object I own in the game second life to POVray.
The coordinate system and rotations appear to match up more or less. Anyway
one object had three different rotations. I repeated the rotations in povray
and got an entirely diferent final angle. Now each rotation ( along the x,
y, and z axi's)individually, rotated identically.
e.g. a 20 degree angle along the  X axis matched a 20 degree angle in POVray
It was when taken together that they failed to match the expected rotation.
(<20,33,16>)
I then tried three rotations ( each with just one of the rotations)
for example
<20,0,0>
<0,33,0>
<0,0,16>
and still didnt match. I then swapping the three rotations and got different
final angles but none of them matched the expected final angle.
Has anyone tried to re-create secondlife objects in POVray and met the same
problem? Is there a solution?
straight object to object conversion should be possible, you'd think.
Subject: Re: second life conversions
Date: 15 Aug 2007 11:27:46
Message: <46c31b72$1@news.povray.org>
I'm guessing that in SL, after you rotate the object, the axis around
which you rotate is also rotated and in POV it's not, or vice versa.
Try turning on the axes display in SL, rotating a prim, and seeing if
the prim's axis has changed. I believe it *does* change in POV, but not
SL, altho it has been a while.
     The primary use of XML is as a technique
     to avoid documenting your interchange formats.
Date: 16 Aug 2007 18:56:37
Message: <46c4d625@news.povray.org>
Barehunter nous apporta ses lumieres en ce 2007/08/15 11:23:
> (<20,33,16>)
> for example
> <20,0,0>
> <0,33,0>
> <0,0,16>
In POV-Ray, the rotation is applied successively to the 3 axis X, then Y, then
Z. The axis never change during that operation: rotate about X, from where you
ended, rotate around Y, then around Z.
Second Life may use another sequence.
It may use a rotating refference axis set. Rotate around X, and Y and Z change
place, if you then rotate around Y, then X and Z will turn around Y. Same thing
for Z. In that case, after the Y rotation, your X and Z will have changed. You
may try the vreorient() macro from transform.inc. (not sure about the exact
spelling, I've never used that include)
There is also another possibility: The angles are applied all at once in a polar
coordinate system! In that case, a non-rotated object is rotation <0,90,90>.
This mean that a point along the X axis is at 0 degree from the X axis, 90
degree from the Y axis and the Z axis on a polar coordinate system.
Thus, in your case, a rotation of <20,33,16> mean take a vector from the origin
to a point on the X axis, rotate it 20 degrees away rfom the X axis. Keeping
that angle constant, rotate it 33 degrees away from the Y axis and 16 degrees
away from the Z axis.
Using that convention, NOT all combinations of X,Y and Z values are possible:
<10,10,10> is not deffined.
I find that the harder I work, the more luck I seem to have.
Thomas Jefferson
Date: 3 Jan 2008 16:40:01
Message: <web.477d54d1cc9496c559a23b820@news.povray.org>
> (<20,33,16>)
> for example
> <20,0,0>
> <0,33,0>
> <0,0,16>
Did you ever find a solution to this?
Johanna Yascinth can seemingly recreate whole scenes from second life to
POVray..
http://johannahyacinth.blogspot.com/2007/02/weeks-work.html
I would be interested to find more information on this.
