POV-Ray : Newsgroups : povray.general : Problem with pigment_map Server Time
13 Oct 2025 18:49:18 EDT (-0400)
  Problem with pigment_map (Message 1 to 8 of 8)
Subject: Problem with pigment_map
Date: 22 Jul 2007 04:45:02
Message: <web.46a318d48aa1d48566bd28430@news.povray.org>
High!
I'm currently trying to build a gradient y texture to generate a 16 bit
heightfield from an isosurface terrain. Here's the code:
#declare HF16 =
texture
  pigment
    gradient y
    pigment_map
      #declare a=0;
      #while (a<127)
        [a/256
          pigment  // here the error occurs
            gradient y
            color_map
              [0 rgb <a/255, 0, 0>]
              [1 rgb <a/255, 1, 0>]
            scale 1/256
        [(a+1)/256
          pigment
            gradient y
            color_map
            scale 1/256
        #declare a=a+1;
  finish { ambient 1 diffuse 0 }
Everytime I try to start my small test scene, I get the error message "Parse
Error: expected "[", pigment found instead". Why?
See you on www.khyberspace.de !
Yadgar
Subject: Re: Problem with pigment_map
Date: 22 Jul 2007 05:32:42
Message: <46a3243a$1@news.povray.org>
   Curious: I'm just doing the opposite... ;)
   I think you need to get ride of the pigment{} wrapper, IIRC.
   Happy landscaping!
Jaime
Date: 22 Jul 2007 05:44:25
Message: <alb1mDAxbyoGFwj5@econym.demon.co.uk>
Wasn't it Yadgar who wrote:
>High!
I think there's a slight typo in the documentation. Where it says
   each PIGMENT_BODY is anything which can be inside a pigment{...}
   statement. The pigment keyword and {} braces need not be specified.
I think it possibly should say
   statement. The pigment keyword and {} braces must not be specified.
Mike Williams
Gentleman of Leisure
Date: 22 Jul 2007 06:02:32
Message: <46a32b38$1@news.povray.org>
I confess I don't really understand what you are doing. Are you
trying to simulate the freaky TGA red/green 16-bit hack? Why not
just apply gradient y to the isosurface and output a 16-bit PNG
using +FN16 or Bit_Per_Color = 16?
Date: 22 Jul 2007 11:29:32
Message: <46a377dc@news.povray.org>
Yadgar nous apporta ses lumieres en ce 2007/07/22 04:44:
> High!
> #declare HF16 =
> texture
>   pigment
>     gradient y
>     pigment_map
>       #declare a=0;
>       #while (a<127)
>         [a/256
>             gradient y
>             color_map
>             scale 1/256
>         [(a+1)/256
>           pigment
>             gradient y
>             color_map
>             scale 1/256
>         #declare a=a+1;
>       #end
> Yadgar
This look like a case of "Why do simple when you can do overly complicated"
The normal way to do it is to add hf_gray_16 in the global_settings{...} block:
global_settings{hf_gray_16}
Then, you set a simple white to black gradient for your object:
texture{pigment{gradient y scale YourOnjectThickness}finish{ambient 1 diffuse 0}}
Adjust the scaling acording to your object thickness.
Lastly, set your output format to TGA:
Add +ft to the command line.
It will show in black and white in the preview. The output file will be black,
red and green: general hight as red component, high resolution, small scale,
hight as green.
Why do psychics have to ask you for your name?
Date: 22 Jul 2007 12:50:10
Message: <46a38ac2$1@news.povray.org>
46a32b38$1@news.povray.org...
TGA  red/green is actually a 24bits image, your trick couldn't work
Marc
Date: 22 Jul 2007 13:08:30
Message: <46a38f0e$1@news.povray.org>
Yes, but the blue channel is unused when using a TGA height_field,
while a PNG can store the 16-bit in a single channel. But of course
Alain was right in pointing out that hf_gray_16 is the way to go as
it also forces gray output. Not sure what happens when you create a
height_field based on a PNG file with three channels of 16 bit each.
Date: 23 Jul 2007 03:40:38
Message: <46a45b76$1@news.povray.org>
in a pigment_map ..don t use pigment statement ..just write your gradient
and color map ...
in a texture_map   don't use texture statement etc....
web.46a318d48aa1d48566bd28430@news.povray.org...
> High!
> #declare HF16 =
> texture
>   pigment
>     gradient y
>     pigment_map
>       #declare a=0;
>       #while (a<127)
>         [a/256
>             gradient y
>             color_map
>             scale 1/256
>         [(a+1)/256
>           pigment
>             gradient y
>             color_map
>             scale 1/256
>         #declare a=a+1;
>       #end
"Parse
> Yadgar
