POV-Ray : Newsgroups : povray.general : Media help Server Time
12 Jan 2025 20:23:41 EST (-0500)
  Media help (Message 1 to 8 of 8)
Subject: Media help
Date: 20 Jun 2007 23:50:02
Message: <web.4679f544ff1ff7b14c561030@news.povray.org>
Can someone please tell me why the following sphere is not showing up in my
scene?
 sphere
  0,1
  scale <1/16,1/4,1/16,>
  hollow
  material
   interior
    media
     intervals 1 //5  higher slows it up and gives smoother images
     samples 1 //5  lower = more blocky
     emission .300 //1    brightness of glowing media
     density
      spherical scale <1/16,1/4,1/16,>
      warp {turbulence <.8,.07,.05>}
      density_map
       [0 rgb 0]
       [.6 rgb 0]
       [.7 color Yellow]
       [.8 color Yellow]
       [.9 color White]
       [1 color White]
   texture {pigment {Clear}}
Subject: Re: Media help
Date: 21 Jun 2007 00:00:01
Message: <web.4679f7756015d1cf4c561030@news.povray.org>
I forgot to add that the same media works fine in this scene:
http://news.povray.org/povray.text.scene-files/thread/%3C4464397b@news.povray.org%3E/
Date: 21 Jun 2007 01:36:05
Message: <467a0e45$1@news.povray.org>
Your sphere is really small and you're applying turbulence - it might be
moving the only part of the spherical pattern that has a value greater than
zero outside of the sphere itself. Does it work if you remove the warp? If
so, try reducing the turbulence or move the scale to after the warp.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Jun 2007 03:50:02
Message: <web.467a2ca66015d1cf96f3cfc0@news.povray.org>
>  - Slime
It still won't show up :(
Removing the warp makes it partially visible, but it's not dense enough in
the center of the shape.
Date: 21 Jun 2007 07:40:44
Message: <467a63bc$1@news.povray.org>
Well, how about increasing emission strength and adjusting the density
map instead of applying a warp? BTW, does it make sense to use "Yellow"
in a density map? Maybe you want to use a color_map instead.
Date: 21 Jun 2007 15:20:01
Message: <web.467acf286015d1cfd919ca980@news.povray.org>
Thanks! Adjusting the emission strength did the trick. There's a formula in
the docs on how to do it properly.
Date: 21 Jun 2007 19:17:42
Message: <467b0716$1@news.povray.org>
SharkD nous apporta ses lumieres en ce 2007/06/20 23:49:
> scene?
>  sphere
>   0,1
>   hollow
>   material
>    interior
>     media
By default using method 3, this should stay at 1.
Raise this instead, samples 25 interval 1 is MUCH faster than intervals 5
samples 5 for the same final number of samples.
>      density
>       density_map
>        [0 rgb 0]
>        [.6 rgb 0]
>        [.7 color Yellow]
>        [.8 color Yellow]
>        [.9 color White]
>        [1 color White]
Your media is prety faint, try raysing emission some.
Only 40% of your radius emit, the rest been density 0, combined with the low
emission makes it hard to see, especialy if the background is light.
'hAS ANYONE SEEN MY cAPSLOCK KEY?'
Date: 21 Jun 2007 19:20:14
Message: <467b07ae$1@news.povray.org>
SharkD nous apporta ses lumieres en ce 2007/06/21 15:19:
There is no set formula that can work in every cases. As a rule, if you double
the thickness of your media, you should halve it's density, or emission, to keep
the same aspect/brightness.
Wouldn't it be nice if whenever we messed up our life we could simply press
'Ctrl Alt Delete' and start all over?
