POV-Ray : Newsgroups : povray.general : Transparent 'mist' Server Time
13 Jan 2025 00:14:38 EST (-0500)
  Transparent 'mist' (Message 1 to 8 of 8)
Subject: Transparent 'mist'
Date: 24 May 2007 09:25:02
Message: <web.465591f08831d8d748edb2090@news.povray.org>
I'm trying to use povray to display some scientific data. I have the
concentration of a drug (as its released from a nanoparticle) as a function
of x,y and z coordinates. I was trying to display it as a kind of mist. I
originally tried to have lots of transparent boxes (for each grid point)
and make them absorb light depending on the concentration. However, I
seemed to be getting diffraction-like patterns emerging, presumably from
the edges of all the boxes stacked together (although I don't know how as
povray doesn't include diffraction). So I tried to use merge to collect all
the boxes together, but now povrays ground to a halt.
Am I trying to display this data in a really stupid way? Does anyone know a
better way of doing this?
Subject: Re: Transparent 'mist'
Date: 24 May 2007 09:45:02
Message: <web.4655967a6f4bc474c4e49fa40@news.povray.org>
"Gavin" <gav### [at] gmailcom> wrote:
> Hi,
I think that media and a df3 density file might be one of the ways you could
do this.
Section 3.5.11.11  Density_File
Date: 24 May 2007 10:02:49
Message: <46559b09$1@news.povray.org>
Gavin wrote:
> However, I
Are you sure you did not just exceed the max_trace_level?
	Thorsten
Date: 24 May 2007 11:17:08
Message: <4655ac74$1@news.povray.org>
web.465591f08831d8d748edb2090@news.povray.org...
> Hi,
> function
Why not an objet the shape and the size that fits to your function display
(a box, a sphere...) with a material of that kind :
material{
   texture
            pigment
               color rgbt 1 // transparent object surface
         interior
            media
               emission rgb 1// any color you want
               density
                  function{max(0,1-(x*x+y*y+z*z))} // your function as a
density pattern here (the example is a spherical pattern)
Marc
Date: 24 May 2007 12:13:25
Message: <4655b9a5@news.povray.org>
4655ac74$1@news.povray.org...
an obect with the keyword 'hollow' of course
Marc
Date: 24 May 2007 18:36:01
Message: <46561351$1@news.povray.org>
Gavin nous apporta ses lumieres en ce 24 / 05 / 2007 09:24:
> Hi,
Have a box or sphere just large enough to completely contain your points.
Make it hollow to enable it to contain a media.
Add an interior{...} block and a media.
Use your function to modulate the dencity of that media.
Make the media emissive so that it's visible without an external light source.
	You could also use scatering media and have some light shine on your media.
Emissive media will render faster, scatering media is slower, but more realist
and will cast shadows.
When using media, the default sampling method is 3, never increase intervals,
increase samples. It's much faster, and increasing intervals can cause nasty
artefacts.
I couldn't repair your brakes, so I made your horn louder.
Date: 25 May 2007 05:05:01
Message: <web.4656a67f6f4bc47448edb2090@news.povray.org>
> do this.
Thanks alot for everyones suggestions! The df3 ensity file sounds like a
really good way of doing it, and I've found this helpful website which says
how to create the df3 files....
http://local.wasp.uwa.edu.au/~pbourke/modelling_rendering/df3/
Thanks again!
Date: 25 May 2007 09:16:13
Message: <4656e19d@news.povray.org>
web.4656a67f6f4bc47448edb2090@news.povray.org...
>> could
>> do this.
> says
> Thanks again!
It looks like emitting media is what you need.
I keep thinking if you have a function describing the density, you may skip
the df3 file step by implementing your function in SDL (Scene Description
Language, the POV-Ray script language).
It is more versatile.
Marc
