![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Can I watch variables after parsing for scene debug purposes?
Date: 21 Mar 2007 11:18:04
Message: <46015abc@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi!
Is it possible to get variable content as an output after parsing a
scene for debug purposes?
regards
Hardy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Can I watch variables after parsing for scene debug purposes?
Date: 21 Mar 2007 11:34:21
Message: <46015e8d@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Which variables?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 21 Mar 2007 11:52:15
Message: <460162bf$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> Which variables?
Different identifiers that are changed e.g. in animations of recursive
structures. In most cases I need the current vectors or colors of
certain frames if possible as text output while the scene is rendered...
regards
Hardy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hi!
> regards
> Hardy
I don't know about truely *after* but you can always convert things like
floats to strings and then put your #debug statements where they'll get
parsed right at the end of the parsing stage. Or you can put those strings
into in-scene text objects. Do you need it to be truely after?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Warp wrote:
> > Which variables?
> regards
> Hardy
How about having your scene write the info you want to a text-file. The
file
should be there as soon as the scene has finished parsing and you can read
it while the render takes place
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 21 Mar 2007 17:46:46
Message: <4601b5d6$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> file
Yes, that would be great. As FrogRay wrote I have to convert the
identifier to a string and then write it to the log using #debug. Is
that right?
regards Hardy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > file
> that right?
> regards Hardy
Yes, you'll still want to turn things into floats, (str() vstr() concat()
etc). For file writing I think you can direct the #debug stream to a file,
but I think Frogray was suggesting to use POV-Ray's file-i/o capabilities,
i.e. #fopen and #write instead of #debug.
Charles
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 21 Mar 2007 19:40:31
Message: <4601d07f@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Erhard Ducke nous apporta ses lumieres en ce 21-03-2007 18:46:
>> file
> that right?
> regards Hardy
It can be done that way, or you can create your own file.
Use #open #write and #close to open/create the file, write values and close the
file when you are finished filling it.
A clear conscience is usually the sign of a bad memory.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 23 Mar 2007 06:25:43
Message: <4603b937@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think i'm now able to manage my problem...
Thanks for your time and brain!
regards Hardy
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
