POV-Ray : Newsgroups : povray.general : comma separated value file for data input Server Time
18 Feb 2025 17:38:32 EST (-0500)
  comma separated value file for data input (Message 1 to 10 of 11)
Subject: comma separated value file for data input
Date: 10 Feb 2007 02:00:05
Message: <web.45cd67c8a7d38e577fa0baee0@news.povray.org>
Although far from new to POV-Ray (programmed first rendering in about 1996),
I am an infrequent user and thus a novice.  Right now I'm returning to it to
produce some 3D statistical graphs.  It would be really convenient for me
read data in from some sort of two-dimensional data file (a table).  Comma
separated value files (.CSV) are commonly used for this.  Is there any
convenient way to read a CSV file into some sort of data container (an
array of arrays? or can MATRIX be used other than for transforms?)
Thanks!
-Eric
Subject: Re: comma separated value file for data input
Date: 10 Feb 2007 03:25:00
Message: <web.45cd80d8d81812bf7d5894630@news.povray.org>
Yes, and it's pretty much straight-away what you said, minus the arrays of
arrays.  I don't think you can really do arrays of arrays per se where
lengths or types may vary etc, but you can certainly do multi-dimensional
arrays up to 5D.  Here's a 1D example:
#fopen StatsFile "Stats.csv" read
#local Ctr = 0;
#local Limit = 150; //assuming you know how long it is
#declare StatsArray = array[Limit];
#while(Ctr < Limit)
  #read(StatsFile, StatsArray[Ctr])
  #local Ctr = Ctr + 1;
#end //end while
Or something like that....  I didn't test it for mistakes/typos.  Hope it
helps.
Charles
Date: 10 Feb 2007 04:25:42
Message: <45cd8f96$1@news.povray.org>
> 1996),
> to
Pov can #read values from a file delimited by commas, these values
should be valid numbers, vectors, or strings. Strings should be inside
quotes. Vectors should be pov style <#,#,#>. Trailing commas are
expected. Files are opened with #fopen. Reading past the end of a
file automatically closes it, but #fclose them...
(3.2.2.3  File I/O Directives)
>... Is there any convenient way to read a CSV file into some sort of
> data container (an array of arrays? ...
Pov supports multi-dimensional arrays. (3.2.1.8  Array Identifiers)
Also, there are dot operators for vectors in pov, so you might
want to store your point data in an array of vectors?
(3.2.1.4.3  Operators)
In pov "matrix" is a keyword for matrix transforms.
Here's a simple example that reads a list of 10 vectors
(as floats) from a .csv file and makes a graph.
union{
#declare point = array[10];
#fopen handle "data.csv" read
#declare c = 0;
#while (c < 10)
   #read (handle, t1, t2, t3)
   #declare point[c] = <t1, t2, t3>;
   sphere{point[c],0.02}
   #declare c = c + 1;
#fclose handle
#declare c = 1;
#while (c < 10)
   cylinder{point[c-1],point[c],0.02}
   #declare c = c + 1;
pigment{rgb <1,0,0>}
//data.csv
0.0,0.0,0,
0.1,0.01,0,
0.2,0.1,0,
0.3,0.2,0,
0.4,0.25,0,
0.5,0.25,0,
0.6,0.2,0,
0.7,0.1,0,
0.8,0.01,0,
0.9,0.0,0
Date: 10 Feb 2007 07:10:00
Message: <web.45cdb4f0d81812bfd2eafd5e0@news.povray.org>
> Thanks!
> -Eric
Well, it so happens that I've been working on a matrices.inc for statistical
analysis. It can do most of the elementary operations, plus invert any
matrix (compatibly with the, unknwon, maximum number of elements in an
array, and computer memory). It's still beta-ish, but I can upload it if
you are interested.
Date: 10 Feb 2007 07:15:00
Message: <web.45cdb6a8d81812bfd2eafd5e0@news.povray.org>
Right, but vectors in POV are at most 5-dimensional. That can be a little
constraining for statistics.
Likewise, matrix is at most 5*5 (well, 5*4 counting the normalized column).
> union{
> #declare c = 0;
> #while (c < 10)
>    #declare c = c + 1;
> #end
> #fclose handle
> #declare c = 1;
> #while (c < 10)
>    #declare c = c + 1;
> #end
> //data.csv
> 0.0,0.0,0,
> 0.1,0.01,0,
> 0.2,0.1,0,
> 0.3,0.2,0,
> 0.4,0.25,0,
> 0.5,0.25,0,
> 0.6,0.2,0,
> 0.7,0.1,0,
> 0.8,0.01,0,
> 0.9,0.0,0
Nifty! But it seems you have to know beforehand the number of data to be
read, is there some way to have something similar to dimension_size?
And can I use your code in my matrices.inc?
Date: 10 Feb 2007 09:09:42
Message: <45cdd225@news.povray.org>
  It's naturally impossible to know the amount of numbers in the input
file before the file has been parsed.
  There are two possible solutions:
  If you can make the program which creates the data file to store the
amount of values as the first value, that would be the easiest way of
automatically getting this value in the pov file.
  If that's just not possible, then you can simulate dynamic arrays in
povray by first creating an array of certain size, reading data into it,
and if it fills up, create a bigger array, copy the data from the old one
to this new one, and then continue reading values, and so on. In the end,
if an exact array (without unused values at the end) is needed, you can
create an array of that exact size and copy the data there.
Date: 10 Feb 2007 12:05:00
Message: <web.45cdfa7ad81812bf9356f54f0@news.povray.org>
In my original reply I went with the assumption that knowing the amount of
data he'd want to display was something he could do manually.  But the docs
for the "#read" keyword reveal kindof a nifty way to do it.  Just add a(n
initialized) counter where the "..." is below, and then re-open the file
and count/read to that value.
Charles
From the docs:
  #fopen MyFile "mydata.txt" read
  #while (defined(MyFile))
    #read (MyFile,Var1,Var2,Var3)
Date: 10 Feb 2007 15:20:00
Message: <web.45ce27e5d81812bfdbc5fd0e0@news.povray.org>
> Thanks!
> -Eric
Reading the data in one value at a time is unnecessary.
If you can format the text to read like a proper array declaration, then you
can simply #include that file:
// data file, saved as "Myarray.inc"
#declare Myarray = array[5][5]
  (1, 2, 3, 4, 5},
  {5, 4, 3, 2, 1},
  {6, 7, 8, 9, 0},
  {7, 4, 6, 3, 4},
  {9, 4, 2, 5, 7}
// Main POV file
#include "Myarray.inc"
Date: 10 Feb 2007 16:08:10
Message: <45ce343a@news.povray.org>
  The problem is not reading the data until it ends. The problem is
how to create an array which can be used to store those values.
Date: 10 Feb 2007 18:05:00
Message: <web.45ce4e5cd81812bfe94cc5130@news.povray.org>
I thought I answered that.... Here's an automatically created exact-fit
array for 1D (pending mistakes as always).  Hopefully if more than 1D is
needed, the data would be cleanly & predictably divisable quantities of
CSV's, but if not, I guess it's up to Eric to know how the CSV's are
formatted and what assumptions can be made.
#local LengthOfList = 0;
  #local LengthOfList = LengthOfList + 1;
//The file is now closed and undefined but we know how long it is.
#declare MyArray = array[LengthOfList];
#local Ctr = 0;
#while (Ctr < LengthOfList)
  #read (MyFile, MyArray[Ctr])
Charles
