POV-Ray : Newsgroups : povray.general : Memory.log Server Time
27 Feb 2026 21:07:29 EST (-0500)
  Memory.log (Message 1 to 10 of 21)
Subject: Memory.log
Date: 17 Jan 2007 11:25:00
Message: <web.45ae4c622a91ee4540d56c170@news.povray.org>
I've been working on a large animation project (4320 frames), where I'm
rendering a 160x120 draft every night.
One thing I've noticed is that povray is generating a memory.log file, and
it's getting up to a GB in size each time!  I have seen on two different
versions of povray (for linux, from debian repositories) that my code is
generating error messages about memory leaks.   I've been ignoring them
until now I see my log getting to be a GB.
Questions:
1) Could I just turn this off somehow?  ("RTFM" with citation of chapter and
subsection is appreciated).
2)  If I'm getting a memory leak error/ a memory log generation:
a) Is my code riddled with errors that will fundamentally slow up my
render speed, OR
b) Is this the price to pay for using all the advanced features in the book
(splines, blobs, etc.,etc.)?  I have been in the habit of ignoring error
codes as my SDL's have been generating several view screens of them every
time, even in cases where I think there's no bug, per se.   OR
c) A bug in the debian-repository versions of povray that has been
demonstrated not to be in the version from the povray site?   (Followup Q:
if I were to get this official version one time, would I be screwed as far
as future updates? There's too many manual things to set up.)
thanks.
Greg M. Johnson
Subject: Re: Memory.log
Date: 17 Jan 2007 11:35:54
Message: <45ae506a$1@news.povray.org>
Yes, complain to the Debian maintainers.
The official version builds easily from source. Using the unofficial and
usually (some are worse than others) badly broken Debian-supplied packages
is not recommended. Debian developers haver successfully ignored all advice
from the POV-Team for years, as can be seen in the bug report logs of Debian
for POV-Ray :-(
	Thorsten, POV-Team
Date: 17 Jan 2007 12:00:56
Message: <45ae5648$1@news.povray.org>
	No, this is a build-time choice only.  It seems the Debian guys decided
to compile their binary using an option that turns debug on (which is bad as
it will slow down rendering speed).  I'll have a look at it and bug them.
	So for now you have 3 choices, ordered from most simple to most efficient:
1) make Memory.log a symbolic link to /dev/null
2) use the official binary
3) build your own from sources
> render speed, OR
	IIRC memory leaks in 3.6.x may result from parsing/rendering error
or with some scenes using blobs.
	Most likely what I've written above -- to be checked though.
	Which things?
	- NC
Date: 17 Jan 2007 12:02:13
Message: <45ae5695$1@news.povray.org>
	Well, not lately at least  :-)
	- NC
Date: 17 Jan 2007 12:20:01
Message: <web.45ae59cab59bc83b40d56c170@news.povray.org>
Okay, thanks all.
I think I may have the option of trying out the official version on a new
box. I'm unfortunately in the middle of a project where I might be able to
afford continued slow renders, but not risk a major fuddle.
Q: How would I put the official version "on top of" the old one?  Last time
I tried that make-install stuff, I think I ended up with povray executable
in a weird directory under /home/greg/ ,  not in the sensible place the
package management system puts it. (Hence the joy of using package
management.)
But Nicolas, could you keystroke-out the advice for doing the thing with
/dev/null.
Date: 17 Jan 2007 12:21:13
Message: <45ae5b09$1@news.povray.org>
	Indeed this is what they do in the latest 1:3.6.1-6 release
(i.e. in the testing and unstable distributions).  I'll submit a bug
report soon.
	- NC
Date: 17 Jan 2007 12:31:06
Message: <45ae5d5a$1@news.povray.org>
	As root, use the install script that comes with the official
PC-Linux distribution of POV (i.e. do not install as regular user).
> /dev/null.
	Why?  I haven't tested it right now but I don't see what evil
could burn you doing so.
	- NC
Date: 17 Jan 2007 12:40:01
Message: <45ae5f71$1@news.povray.org>
>> /dev/null.
I'm guessing he means "can you tell me exactly what to type to implement
your suggestion"?
     Scruffitarianism - Where T-shirt, jeans,
     and a three-day beard are "Sunday Best."
Date: 17 Jan 2007 12:45:00
Message: <web.45ae608bb59bc83b40d56c170@news.povray.org>
How does one do that?
And I can see how that might save HDD space.  But does it also solve the
resource use issue (render speed), or am I better off getting an official
version?
Date: 17 Jan 2007 13:08:04
Message: <45ae6604$1@news.povray.org>
> your suggestion"?
	Ah okay, I first thought this too, but then I got the (wrong) feeling
that it might be some sort of criticism  :-p
	- NC
