POV-Ray : Newsgroups : povray.general : How would I do this in POV-Ray? Server Time
13 Jan 2025 09:37:04 EST (-0500)
  How would I do this in POV-Ray? (Message 1 to 6 of 6)
Subject: How would I do this in POV-Ray?
Date: 29 Dec 2006 00:10:01
Message: <web.4594a231626f25417a9334df0@news.povray.org>
I've known of POV-Ray for years but just getting around to having time to
use it for anything. Here's the general idea of something I need to do, can
I do it in POV-Ray?
I want to create a set of images, each on a virtual "sheet of glass", and
stack them together so that you see them as though looking straight through
the glass.
How would I do this? My (naive?) thought process is to define each sheet as
a "box" with dimensions proportional to how a sheet of glass is (thin
front-to-back, rectangular), then create images in the plane of one side of
the box. Boxes to be placed in space such that each one is exactly next to
the other.
Make sense?
Subject: Re: How would I do this in POV-Ray?
Date: 29 Dec 2006 01:29:09
Message: <4594b5b5$1@news.povray.org>
> I do it in POV-Ray?
> the glass.
> the other.
> Make sense?
Sort of.  The quick answer, in the usual spirit of enterprise around
here, is try it and see if you get what you want.
In a sense, POV is more articulate than your description of what you
want to do.  There are quite a few different and subtle possibilities
along the lines you describe.
You can use a thin box and give it a material definition to simulate
glass with the pigment definition based on the image.  You can even
create the effect of stained class complete with caustics, reflections
refractions and all.
You can also use a box with 0 thickness in one dimension if all you want
is a surface to carry the image.  You could also use two triangles, a
bicubic patch or a clipped plane or even disc to get an infinitely thin
surface.
The image itself can be created in several ways but probably you mean an
image_map.  An image_map can be used to control any of the texture
elements but probably you mean the pigment.  Such a pigment could be
give degrees of transparency overall, or be used with a mask to create
areas of absolute transparency.  You may also be able to use a image_map
to color media filling a thin box with the image you want.
You should be aware also that an image_map, as a pattern, extends
infinitely in the z direction.
Date: 29 Dec 2006 02:50:00
Message: <web.4594c87bc109b6fd430b33a0@news.povray.org>
> the other.
That seems the simplest & most logical approach, but if you do that you're
going to get 3 problems:
1. Coincident surfaces - if you stack one box *exactly* next to the other
then Povray won't know which surface to render.  Sometimes it will render
'Box A' and sometimes it will render 'Box B'.  This isn't a problem if the
textures on 'Box A' & 'Box B' are exactly the same, but if they are
different you will get random per-pixel speckling where the surfaces
overlap.  Simple solution is to leave a very small gap between the two
objects.
2. max_trace_level - if this is set too low (the default is 5) then most of
your glass sheets will end up black.  Read the docs to find out why...
3. "My image_map appears on both sides of the box" - as Jim wrote, the
image_map extends infinitely along the Z axis (with planar mapping anyway).
 This means it will appear on both the front & the back of your glass sheet,
which I'm guessing isn't what you want...
After experimenting with a few alternatives, the simplest solution to this
is to create a plain glass sheet, and put the image on a seperate
2-dimensional object placed very slightly in front of the glass sheet
(coincident surfaces again).  The simplest way to make a 2-dimensional
square is with a polygon.
Do not regard this as the ONLY way to solve the problem.  This is Povray and
there are many more ways to skin a cat (or render a skinned one).  Read the
documentation, use the newsgroups & experiment with different techniques.
Date: 29 Dec 2006 06:53:01
Message: <4595019d@news.povray.org>
> objects.
  This might actually not be the case with axis-oriented boxes because
the math involved is very straightforward and predictable.
  It's still safer to leave the gap, though.
Date: 30 Dec 2006 19:29:33
Message: <4597046d$1@news.povray.org>
news:4595019d@news.povray.org...
>> the
>> objects.
If all you want is a stack of images you could use a stack of plane{}
instead of box{}... they would be quicker to render (ie less surfaces) and
you'd only have one face per pane to worry about when it comes to
image_map{} them.
You'll have fun getting all the alpha channel or transparency working right
though!
And as someone else said, you'll have to up the max_trace_level...
Rarius
Date: 30 Dec 2006 23:35:00
Message: <web.45973d66c109b6f7a9334df0@news.povray.org>
> image_map{} them.
> though!
> Rarius
Well, I'm trying to simulate opaque painting or pasting of paper on one side
of a piece of glass, and then stacking them together so I think thin boxes
are better.
I will do some experimenting and see what's what.  Thanks all for your help.
