POV-Ray : Newsgroups : povray.general : Another Short Code Competition question: re 'distinctly different' Server Time
28 Feb 2026 00:23:05 EST (-0500)
  Another Short Code Competition question: re 'distinctly different' (Message 1 to 7 of 7)
Subject: Another Short Code Competition question: re 'distinctly different'
Date: 20 Nov 2006 01:55:00
Message: <web.45614fe05424b6c1704594a90@news.povray.org>
Does each entry's needing to be "distictly different" refer more to the code
or the resulting image?  Does the code need to be un-related for multiple
entries?
Thanks,
Charles
Subject: Re: Another Short Code Competition question: re 'distinctly different'
Date: 20 Nov 2006 06:40:00
Message: <web.45619344ae81746a302aaef00@news.povray.org>
> entries?
There are no limitations placed on how you use your multiple entries.
Having said that, I doubt if your fellow judges will view slight variations
on a theme with great interest ... but I may be wrong.
Hmmm I suddenly realise someone may choose to tell a short story with their
4 entries.
P a u l   B o u r k e
http://local.wasp.uwa.edu.au/~pbourke/
Date: 20 Nov 2006 06:54:31
Message: <45619777$1@news.povray.org>
You have defined: "each entry must be distinctly different."
Well, distinctly different really doesn't need to be interpreted
stronger than simply different.
If you take a look at results of Round 3 you can see entries,
which might not be called "distinctly different".
> variations
That should be enough motivation. Do not bore the judges...
> their
> 4 entries.
Yes, that may even go against that rule but nevertheless be interesting.
Bye, Olaf.
Date: 20 Nov 2006 09:02:51
Message: <4561b58b@news.povray.org>
I had the same problem, I wanted to submit 2 images that were day & night
versions of similar scenes, the images were distinctly different but the
code was almost identical! In the end I decided to abandon one of them and
submit 4 completely unrelated images, just to be on the safe side.
Tek
http://evilsuperbrain.com
"Charles C" <nomail@nomail> wrote in message
news:web.45614fe05424b6c1704594a90@news.povray.org...
> code
> entries?
> Thanks,
> Charles
Date: 21 Nov 2006 22:55:01
Message: <web.4563c949ae81746a2869ae640@news.povray.org>
"Do not bore the judges..."  hmmmmmmmmmmmmmmmm  (rubbing my chin) ;-)
Date: 22 Nov 2006 04:29:34
Message: <4564187e$1@news.povray.org>
Matlock, Ally McBeal, L.A. Law
come to my mind.
Bye, Olaf.
Date: 23 Nov 2006 09:55:00
Message: <web.4565b53fae81746ace6810af0@news.povray.org>
I'm not speaking in any official capacity, but if you were able to produce
SDL code which, upon changing a single character, you were able to go from
daylight city scene to desert sunset scene, I'd say more power to ya.
