POV-Ray : Newsgroups : povray.general : Bricked vault Server Time
27 Dec 2025 04:33:31 EST (-0500)
  Bricked vault (Message 1 to 6 of 6)
Subject: Bricked vault
Date: 10 Nov 2006 15:30:00
Message: <web.4554e04ace7089d1f6a4e110@news.povray.org>
I am creating a vaulted aisle (like in a gothic cathedral). The shape of the
vault is not a sphere or a cylinder, it is a complex mathematic surface
function. I need to make it look like made of bricks using the 'brick'
pigment but I can not find the way to make the bricks to appear correctly.
I build the surface with a mesh made of triangles calculated on the fly
using the 3D function (much faster than the corresponding isosurface).
To apply the bricks, I am using uv_mapping and uv_vectors but always the
bricks appear well on the upper side (almost horizontal) but highly
distorted in the almost or completely vertical surfaces in the lower part.
If I try to calculate the uv_vectors to take the appropriate portion of the
brick pigment, then the pigments on each triangle doesn't match with their
neighbours.
I feel that I'm walking in the wrong direction. Any lights?
Thanks,
Zoly
Subject: Re: Bricked vault
Date: 11 Nov 2006 01:16:06
Message: <ujqal2p9hvo7o2c5s9cf1bhcsgldj5b4fj@4ax.com>
Maybe some code and/or a sample image might help...
Kyle
Date: 11 Nov 2006 01:37:46
Message: <45556fba$1@news.povray.org>
"Zoly" <nomail@nomail> wrote in message
news:web.4554e04ace7089d1f6a4e110@news.povray.org...
> the
> neighbours.
If your uv's don't match up between faces then you're going to see
discontinuities, but for what you want it might be easier to switch off
uv_mapping and just line the pattern up as best you can using scale &
rotate.
Tek
http://evilsuperbrain.com
Date: 11 Nov 2006 03:45:01
Message: <web.45558b98718327621f6a4e110@news.povray.org>
> Kyle
I'm posting a small scene that reproduces the problem. It is not very
easibly readable but you can cut and paste and have a look at the image.
Thanks,
Zoly
//--- VAULT CONSTRUCTION
#macro Vault(P01,r1,a1,n1,P02,r2,a2,n2,h)
   #local dd=0.00001;
   #local dl=0.1;
   #local h1=r1*sqrt(2*n1-1);
   #local h2=r2*sqrt(2*n2-1);
   #local x01=P01.x;
   #local x02=P02.x;
   #local z01=P01.z;
   #local z02=P02.z;
   #local fr1=function(y) {
(y>h-h1)*(-r1*(n1-1)+sqrt(pow(r1*n1,2)-(y>h-h1)*pow(y-(h-h1),2)))+(y<=h-h1)*r1
   #local fr2=function(y) {
      (y>=h-h2)*(-r2*(n2-1)+sqrt(pow(r2*n2,2)-pow(y-(h-h2),2)))+(y<=h-h2)*r2
   #local x1=function(y) {x01+fr1(y)*cos(radians(a1))}
   #local x2=function(y) {x02+fr2(y)*cos(radians(a2))}
   #local z1=function(y) {z01-fr1(y)*sin(radians(a1))}
   #local z2=function(y) {z02-fr2(y)*sin(radians(a2))}
   mesh {
      #local i=h;
      #while (i>0)
         #local a_i=i;
         #local i=i-dl/sqrt(1+pow((fr1(i)-fr1(i-dd))/dd,2));
         triangle {
            <x1(a_i),a_i,z1(a_i)> <x2(a_i),a_i,z2(a_i)> <x1(i),i,z1(i)>
            uv_vectors <x1(a_i),z1(a_i)> <x2(a_i),z2(a_i)> <x1(i),z1(a_i)>
         triangle {
            <x2(a_i),a_i,z2(a_i)> <x1(i),i,z1(i)> <x2(i),i,z2(i)>
            uv_vectors <x2(a_i),z2(a_i)> <x1(i),z1(i)> <x2(i),z2(i)>
         uv_mapping
            brick rgb 0.15 rgb 0.2
            scale 0.08
            rotate 90*z
//--- MAIN OBJECT
object {Vault(<0,5,-3.59>,3.555,0,1.2,<0,5,0>,5,40,1,5)}
object {Vault(<0,5,-3.59>,3.555,0,1.2,<0,5,0>,5,40,1,5) scale <-1,1,1>}
//--- SECONDARY STAFF
light_source {<0,0,0> 2}
light_source {<50,50,-50> 5}
camera {location <4,2,-10> look_at <0,2,1> rotate <0,-10,0>}
plane {y, 0 pigment {rgb <0.08,0.02,0>}}
sky_sphere {pigment {rgb <0.04,0.04,0.2>}}
Date: 11 Nov 2006 23:51:03
Message: <nv9dl21dumsfa4dle33l7avrc6jfu67iap@4ax.com>
Zoly,
Here's my suggestion:
>>> snip >>>
   #local U = 0;
   mesh {
      #local i=h;
      #while (i>0)
         #local a_i=i;
         #local Uinc = abs(vlength(<x2(a_i),a_i,z2(a_i)>-<x2(i),i,z2(i)>));
         triangle {
            uv_vectors <U,z1(a_i)> <U,z2(a_i)> <U+Uinc,z1(i)>
         #debug concat("T1: ",vstr(3,<x1(a_i),a_i,z1(a_i)>,",",0,5))
         #debug concat(" - ",vstr(3,<x2(a_i),a_i,z2(a_i)>,",",0,5))
         #debug concat(" - ",vstr(3,<x1(i),i,z1(i)>,",",0,5),"\r")
         triangle {
            uv_vectors <U,z2(a_i)> <U+Uinc,z1(i)> <U+Uinc,z2(i)>
         #debug concat("T2: ",vstr(3,<x2(a_i),a_i,z2(a_i)>,",",0,5))
         #debug concat(" - ",vstr(3,<x1(i),i,z1(i)>,",",0,5))
         #debug concat(" - ",vstr(3,<x2(i),i,z2(i)>,",",0,5),"\r\r")
         #local U = U + Uinc;
         uv_mapping
            scale 0.04
            rotate 90*z
>>> snip >>>
I hope this helps, or at least gets you going in the right direction.
Kyle
Date: 12 Nov 2006 07:20:00
Message: <web.45571062718327621f6a4e110@news.povray.org>
My hat is absolutely off to you, Kyle. Thank you for your help and your
understanding of my code.
I have posted in povray.binaries.images how looks your solution in my (still
beta) Chartres Cathedral 'stone by stone' reproduction. There are still
pending the textures, ornaments ambient and lighting.
Rgds,
Zoly
> Zoly,
> >>> snip >>>
>    #local U = 0;
>    mesh {
>       #local i=h;
>       #while (i>0)
>          #local a_i=i;
>          triangle {
>          #debug concat(" - ",vstr(3,<x1(i),i,z1(i)>,",",0,5),"r")
>          triangle {
>          #debug concat(" - ",vstr(3,<x2(i),i,z2(i)>,",",0,5),"rr")
>       #end
>       texture {
>          uv_mapping
>          pigment {
>             scale 0.04
>             rotate 90*z
> >>> snip >>>
> Kyle
