POV-Ray : Newsgroups : povray.general : How to display text in UNIX (Linux)? Server Time
21 Nov 2025 06:44:30 EST (-0500)
  How to display text in UNIX (Linux)? (Message 1 to 7 of 7)
Subject: How to display text in UNIX (Linux)?
Date: 3 Nov 2006 04:15:01
Message: <web.454b07b17a3ca2b5bb7e57280@news.povray.org>
Hello,
I've tried my best, and I was searching through docs, but it is only
explained for Windows.
1. How to display text in UNIX (Linux)?
   1a. Which naming convention is required for fonts?
   1b. How to use non-ttf fonts and is it possible at all?
2. How to display text on Mac OS X?
3. How to make text display universal, despite the fact that fonts have
different locations and aliases on various systems?
Many thanks in forward,
Marvin
Subject: Re: How to display text in UNIX (Linux)?
Date: 3 Nov 2006 06:50:00
Message: <web.454b2cb25db3633de340b2aa0@news.povray.org>
"Marvin" <mto### [at] grfhr> wrote:
> Hello,
> Marvin
Displaying the text in a textshell, a Windowmanager(fvwm, Blackbox,
Afterstep etc.) or in a Desktop (KDE, Gnome) ?
By a programm(in wich programming language?) or a script(Shellscript
or script languages like Perl, Python etc.) ?
Date: 3 Nov 2006 12:00:01
Message: <web.454b74045db3633d731f01d10@news.povray.org>
If you're talking about rendering text in povray using .ttf files, it should
be the same for all systems. I use Mac OS X, and I just copied all the font
files I wanted to use from the C:Windows/Fonts folder onto my Mac and
referenced them as "xxx.ttf" as I would under Windows. I don't think the
filename matters, so it would probably work fine even without the ttf
extension. I'm sure others can confirm/refute this... :)
(I never thought to look for the Mac fonts... I don't even know how they're
encoded...)
Bill
Date: 3 Nov 2006 13:27:42
Message: <454b8a1e$1@news.povray.org>
> encoded...)
<http://www.povray.org/documentation/view/3.6.1/762/>
	Thorsten
Date: 3 Nov 2006 20:29:44
Message: <pan.2006.11.04.01.26.22.437434@localhost>
On Fri, 03 Nov 2006 04:11:13 -0500, Marvin wrote:
> Hello,
> Marvin
 cat somefile.txt
if it's more than a few lines then
 less somefile.txt
Or did I misunderstand your question entirely?   :o
Date: 3 Nov 2006 23:00:01
Message: <web.454c0f245db3633d27ff4b5f0@news.povray.org>
> > Hello,
> > Marvin
>  cat somefile.txt
>  less somefile.txt
Yes, but due to my fault. I did not specify that I am puzzled with text from
POV-Ray on Linux and Mac.
It turned out that it works, but I only have to copy .ttf file to current
directory, because +L won't include Library_Path with fonts on my machine.
(I don't have admin access currently on all systems where I render.)
Copying font is not elegant, but it seems to be transparent for all three
systems and working.
Thank you all for answers.
Marvin
Date: 3 Nov 2006 23:14:09
Message: <454c1391@news.povray.org>
  You can create soft links instead of copying the files as a "mid-elegant"
solution.
