POV-Ray : Newsgroups : povray.general : Feature I missed in old versions. Implemented now? Server Time
19 Mar 2026 11:43:47 EDT (-0400)
  Feature I missed in old versions. Implemented now? (Message 1 to 5 of 5)
Subject: Feature I missed in old versions. Implemented now?
Date: 24 Oct 2006 16:15:00
Message: <web.453e7358c633d40d52eeaae0@news.povray.org>
Hello everybody,
from time to time I use povray, but did not bother to ask, but now:
Is it possible to include materials with gain = laser medium = absorption
> 1 ?
Is it possible to use photon mapping to simulate optical pumping of the
gain medium
Is there any tool to render the raytraced image onto a polygonal
representation of the scene (unlit texture maps) for simple fly-throughs
and scene debugging?
Is it possible to use a fine representation of the spectrum for better
simulation of chromatic errors in lenses, or for simulation of a
spectrometer
Is it possible to use a wide spectrum with near infrared for simulation of
heat transfere in big glas blocks of telescopes primary mirros and UV for
simulation of
fluorescence
Is it possible to use PovRay as a design tool for lens systems (or Beamer
optics) and if not why not?
Have you integrated FreeSnell to simulate multilayer optics?
Arne Rosenfeldt
Subject: Re: Feature I missed in old versions. Implemented now?
Date: 24 Oct 2006 16:53:40
Message: <453e7d54@news.povray.org>
> gain medium
  You could try to give the object (which the photons are passing through)
a color higher than 1, but I have never tested whether that works in
practice.
> spectrometer
  You can fake the look of chromatic dispersion by using the 'dispersion'
feature in POV-Ray (see the documentation), but it's probably not even
close to the physically correct dispersion of real lenses.
  Only if you are not going to simulate chromatic aberration. If you need
to simulate that, then I don't think POV-Ray can do a physically correct
job in that field.
  (Ok, it may be possible to approximate reality by using trickery,
perhaps by using several light sources in the same place, each colored
differently and each in a light_group with a copy of the object otherwise
identical but with different IORs. However, I have never tried this kind
of thing, so I can't say for sure.)
  Some kind of frensell reflection is supported in POV-Ray, but once again
I can't assure how physically correct it is.
Date: 24 Oct 2006 21:20:53
Message: <453ebbf5$1@news.povray.org>
Warp nous apporta ses lumieres en ce 24/10/2006 16:53:
>> gain medium
> practice.
I have and it work. It was a prism with rgbt 2, it effectively multiplied the
light by 16!
>> spectrometer
Ok if you want a continuous spectrum.
> job in that field.
It's usualy "close enough", you need the correct dispersion for the material you
want. You can increase the dispersion_samples to get smoother results.
The real problem is that you can't simulate birefringense.
Drive A: not responding.. .Formating C: instead
Date: 25 Oct 2006 23:25:01
Message: <web.454028fbc1cccb6899f929260@news.povray.org>
>practice.
That gave an error at parsing.
The dispersion feature looks good, I will have to try it with a series of
two prisms.
Birefringence is hard to code at the beginning but easy to inlude into a
raytracer, why is it not implemented?
It does not support soap-bubbles or AR-coated eyeglasses.
I do not want to learn two programs if I think a single raytracer will give
me nice pictures for presentations and correct simulations of my optics. Or
am I the only one, who "builds" (simple) optical devices and knows PovRay?
Date: 26 Oct 2006 05:30:01
Message: <web.45407f0cc1cccb6899f929260@news.povray.org>
> >practice.
Sorry I overlooked the above answere
