POV-Ray : Newsgroups : povray.general : Sky_sphere and HDRi Server Time
27 Dec 2025 17:46:19 EST (-0500)
  Sky_sphere and HDRi (Message 1 to 10 of 10)
Subject: Sky_sphere and HDRi
Date: 11 Jan 2006 20:00:01
Message: <web.43c5a940743b370581cca5e40@news.povray.org>
Hello,
I'm wondering: Would it be feasable to use radiosity with a sky sphere to
generate HDR-ish effects from within Pov-ray?
Since sky_spheres only take pigments, not full textures, I can't see how to
do it directly with a sky_sphere. If I simply apply a sky_sphere pigment to
a scaled up sphere, the pigment gets all messed up, because sky_spheres map
pigments differently than a normal sphere.
I've doodled with running an empty scene (nothing inside but a camera and a
sky_sphere) with a spherical projection, outputting to hdr, then mapping
that to a giant sphere inside the final scene. This doesn't work right at
all unless you use uv mapping on the sphere ;-) but even then I can never
get the textures to look the same as they did originally.
Any chance I piqued the curiousity of someone who knows more about the topic
than I do? :-)
FWIW, this was all prompted by a sunset scene that I'm working on that I
just can't get the lighting right in. :-P
William
Subject: Re: Sky_sphere and HDRi
Date: 11 Jan 2006 21:09:40
Message: <43c5ba64$1@news.povray.org>
"Afishionado" <afi### [at] gmailcom> wrote in message
news:web.43c5a940743b370581cca5e40@news.povray.org...
> to
> to
> map
sky_sphere {
  pigment {image_map {hdr MAP once interpolate 2 map_type 1}}
Sky_sphere shouldn't map different then a sphere, but what does happen is
that a sky_sphere is infinite, whereas a sphere isn't, so depending upon the
size of the sphere and the location of your camera, the scene can look
different because of perspective.  Try using a larger sphere to minimize
this.
One advantage that a sphere has over a sky_sphere is that it has a finish
block so you can increase the ambient value to increase the radiosity
influence of the HDR, whereas with sky_sphere, it is much more difficult to
do.
Hope that helps a little.
-tgq
Date: 12 Jan 2006 01:50:00
Message: <web.43c5fbfc3b03bf4b42e720ce0@news.povray.org>
"Afishionado" <afi### [at] gmailcom> wrote:
> Hello,
Why use a sky_sphere? A regular sphere works ok. Have a look at Jaime Vives
Piqueres' web page for a simple way to do pseudo-HDRI lighting in standard
POV.
http://www.ignorancia.org/tips.php
Date: 12 Jan 2006 03:20:32
Message: <43c6114f@news.povray.org>
  Why not? Can you give some reasons?
  For one, sky_sphere is faster than a regular sphere.
Date: 12 Jan 2006 15:30:00
Message: <web.43c6baf93b03bf4bac1be28a0@news.povray.org>
OK, I have a sky texture made in Pov-Ray (bozo clouds, etc.) that works fine
on a standard sky_sphere. I'm just wondering if I can light the scene using
radiosity from it.
I can't figure out how to "bump up" the radiosity of it with a sky_sphere.
That's really all there is to it.
The radiosity bit from the Pov-Ray tutorial seems to show blue light from a
sky, so maybe there's something really simple here that I'm just too
thick-headed to see. Maybe I just need to stare at the docs longer. :-P
William
Date: 12 Jan 2006 15:43:47
Message: <43c6bf83@news.povray.org>
> radiosity from it.
  Yes.
  You can increase the 'brightness' value of radiosity, if that helps.
  Of course if you really want to brighten up the sky texture and nothing
else, then you'll have to use a real sphere with a proper 'finish'.
Date: 12 Jan 2006 16:16:13
Message: <43c6c71d$1@news.povray.org>
news:43c6bf83@news.povray.org...
works fine
scene using
> > radiosity from it.
>   Yes.
sky_sphere.
nothing
Not necesseaeraely (I really hate that word :-/)
You can use the transmit-brighten/darken-trick:
-- start code --
#version unofficial MegaPov 1.1;
sky_sphere {
  image_map {
   hdr "rnl_probe.hdr"
   map_type 7
 pigment {rgb 0 transmit .5}
-- end code --
The transmit-value acts like an ambient-value: transmit 0 gives total
blackness, transmit 1 gives standard brightness, transmit 2 gives double
brightness and so on.
cu!
Date: 12 Jan 2006 18:55:00
Message: <web.43c6e82f3b03bf4bc5653ea60@news.povray.org>
Or, I could use:
color rgb <r, b, b> * n
in my pigment definitions. :-P
My bad.
William
Date: 12 Jan 2006 19:02:29
Message: <43c6ee15$1@news.povray.org>
news:web.43c6e82f3b03bf4bc5653ea60@news.povray.org...
> Or, I could use:
yes, but that won't work with image_map's
cu!
Date: 12 Jan 2006 21:00:01
Message: <web.43c708b83b03bf4ba7c5de080@news.povray.org>
Which I'm not working with right now. :-P
William
