POV-Ray : Newsgroups : povray.general : Callling all Earth renderers - Blue Marble "next generation" Server Time
19 Mar 2026 16:55:10 EDT (-0400)
  Callling all Earth renderers - Blue Marble "next generation" (Message 1 to 9 of 9)
Subject: Callling all Earth renderers - Blue Marble "next generation"
Date: 14 Oct 2005 03:20:00
Message: <web.434f5bb0b8731679e7014cf00@news.povray.org>
Apologies if this has been posted already.
NASA has released the "next generation" of their Blue Marble image maps of
the earth: http://earthobservatory.nasa.gov/Newsroom/BlueMarble/
The images are higher quality that the previous versions, cover topography,
bathymetry and the cloudless surface (one for each month of the year).
Resolutions are 5400 by 2700 (8km per pixel) and 21600 by 10800 (2km per
pixel) and, as usual, are free.
Very nice. :)
Subject: Re: Callling all Earth renderers - Blue Marble "next generation"
Date: 14 Oct 2005 04:05:47
Message: <434f66db@news.povray.org>
"Alan Holding" <nomail@nomail> schrieb im Newsbeitrag
news:web.434f5bb0b8731679e7014cf00@news.povray.org...
> topography,
> Very nice. :)
Thank you for the nice news!
Now we're able to do animations that show the yearly cycle of the seasons.
Let's see who is the first one who does it :)
Thies
Date: 14 Oct 2005 06:30:02
Message: <dio16t$4s6$1@chho.imagico.de>
Actually for this you would need shorter intervals - half a second of
animation for a whole year is not exactly very useful...
The processing used for generating these looks quite impressive, i first
wondered how they managed to generate a more or less cloud free image
from only a month of data - the usual 32day composites contain
significant cloud cover esp. in tropical regions.  You can find details
on this and other processing aspects on:
http://snowy.arsc.alaska.edu/nasa/bmng/bmng.pdf
BTW an early test render (using the 2km variant) can be found on:
http://www.imagico.de/files/bmng1.jpg
(physically impossible BTW - notice the lighting combined with the
january image...)
http://www.imagico.de/ (Last updated 07 Oct. 2005)
Date: 14 Oct 2005 09:25:36
Message: <434fb1d0$1@news.povray.org>
> january image...)
Are you talking about the fact that the Sun shouldn't be above the
equator, or something else?
Date: 15 Oct 2005 13:05:25
Message: <435136d5@news.povray.org>
Well, you could interpolate between the images creating in total
360 images. Using a morphing program or something.
Date: 17 Oct 2005 10:15:21
Message: <4353b1f9$1@news.povray.org>
Christoph,
I've found your gallery of planet renderings quite interesting and useful.
I building up a scene showing the early stage of re-entry of John
Glenn's "Friendship 7" Mercury spacecraft. I've been working on modeling
the earth as it would be seen from about 90 miles (145 km) altitude,
probably somewhere over Texas.  The 8 km/pixel BlueMarble map is
obviously too coarse, and the 2 km/pixel map is two big to render in my
machine (3/4 GiB RAM).
You have some very nice renderings which seem to be a a fairly low
altitude, but I can't seem to find a description on your web site of how
you did it (or just what the altitude is).
Any tips?  I've thought of trying to slice up the whole earth image
somehow, is this what you did?  My thought is to process the image with
the convert tool from ImageMagick.  If you are doing a "close-up" like
this do you switch from a spherical to a planar projection on the image
map or do you use some other tricks?
Any advices would be welcome.
Date: 17 Oct 2005 11:30:02
Message: <dj0fok$8mv$1@chho.imagico.de>
Well - the technique is outlined on:
http://www.imagico.de/pov/planets.html
When you use an isosurface for the geometry you are completely free to
define the height function - you can combine a low detail basis with a
higher detail region.  To define the areas the boxed pattern is well
suited (for faster results i also recently used an object pattern when
the transit region is not visible).  Mapping this to the sphere can be
done using mapping warps or f_th/f_ph functions.
Most renders on http://www.imagico.de/pov/earth.html are from an
altitude of about 200-500km.  The ones on
http://www.imagico.de/pov/earth2.html are about 50-150km.
To extract an area from a very large image you need a tool that is able
to do this without loading the whole image into memory.  The GDAL
library can do this (specifically the gdal_translate program):
http://www.gdal.org/
Date: 17 Oct 2005 13:37:57
Message: <4353e175$1@news.povray.org>
I've managed to render the 2 km/pixel map on 512 MB RAM, haven't tried
it lately 'cuz bogged down in just playing with positioning of various
elements using the 8 km version to decide that it's ready for a 'final'
render pass.  I tried, but failed, to combine the two 1 km hemispheres
into a 43200x21600 map, partly due to insufficient system resources,
partly due to the fact that I don't have an image editing program that
can handle that large of an image.  I need a special app that'll splice
them without needing to load the entire file into memory first.
Tim Cook
Version: 3.12
Date: 22 Oct 2005 04:45:00
Message: <web.4359fb3adfb2e4261ae306d60@news.povray.org>
The NetPBM programs (which are the basis of ImageMagick) may be able to what
you want, since they are designed to run in pipes. I'm pretty sure that
pnmcat can join .ppm files, line by line. The .ppm format is very simple,
and these conversion & transformation utilities have been around for well
over a decade.
