POV-Ray : Newsgroups : povray.general : piles of gold coins Server Time
19 Mar 2026 18:59:40 EDT (-0400)
  piles of gold coins (Message 1 to 7 of 7)
Subject: piles of gold coins
Date: 4 Sep 2005 15:10:01
Message: <web.431b464b2d8da3f37e0a37430@news.povray.org>
Ok I am doing a series of pic involving dragons. Now I came to the part in
the script when I need to do a dragon den with piles of gold coins
everywhere. Obviously making a coin is easy. but is there an easier way to
make piles of coins without typing out a thousand cylinders?
Subject: Re: piles of gold coins
Date: 4 Sep 2005 18:08:40
Message: <431b7068$1@news.povray.org>
There are two possible solutions to calculate the placement of the coins:
1. A simulation system (e.g. MechSim): Could be hard to setup, could
take long to calculate, but will give you very good results, even for
close-ups.
2. Some sort of distribution algorithm. Difficulty goes from very easy
to almost impossible, I guess, same goes for calculation time and
quality of the result. If you don't need close-ups, you're probably
better off with this solution, because you won't see the intersections then.
HTH,
Florian
Date: 4 Sep 2005 18:31:46
Message: <431b75d2$1@news.povray.org>
web.431b464b2d8da3f37e0a37430@news.povray.org...
Look for the demo files in the "advanced/blocks" directory in the
distribution. There's code to do that with cubes but it could be adapted to
cylinders.
G.
Date: 4 Sep 2005 20:45:00
Message: <web.431b948f62b52bbd553c29380@news.povray.org>
> cylinders.
> G.
possibly. I look ed the files and my eyes crossed. They are way too advanced
for me to figure out let alone tinker with.
Date: 4 Sep 2005 21:05:01
Message: <web.431b98c462b52bbd553c29380@news.povray.org>
I think I found a way to do it. I made a series of the following,
successvely narrowing the outer radius as it went up in increments of the
thickness of the coin.
#declare coincount =0;
#while(coincount < 50)
cylinder{<0,0,0>,<0,0,-0.125>,.4375
 texture{T_Gold_4E}
 translate<0,7,0>
 rotate<0,0,3.583322>
 rotate<0,0,-(coincount * 7.166644)>
 #declare coincount = coincount +1;
ending up with a single coin on top. then I threw a cone underneath it all
to catch the gaps.( heh this is my very first use of #while :)  )
Date: 18 Sep 2005 15:56:12
Message: <432dc65c@news.povray.org>
I assume you are using many while loops, one for each layer?  You could
embed another while loop so that the entire pile is made.  A little more
math for you to figure out, but it still shouldn't be as complicated as
the advanced macros the others have suggested.
You could also make some tall vertical stacks of coins too.  Throw in
another while with your cylinders and just translate them up with the
count variable.  You could also add a random translate in the x and z
directions so they don't perfectly line up as they go up too.  Crazy,
leaning stacks of coins with pyramid piles would look pretty neat.
Skip
Date: 4 Oct 2005 14:10:01
Message: <web.4342c54662b52bbd55cad30e0@news.povray.org>
You might also use the TRACE operation (which happens to be one of my own
favorite POV features.)  You could randomly place thousands of coins on,
for example, a little heightfield "mound," while using the NORMALS that are
found during the trace operation to tilt the coins so that they follow the
contours of the mound. ( I'm simplyfying a somewhat complex
process...sorry!) With enough overlapping coins, the mound shape itself
would not be visible. This probably wouldn't work for closeups, though,
without some kind of "collision detection" to keep coins from simply
"melting into" each other. But I've used just the technique described here
to cover a treetrunk with lots of overlapping ivy leaves, and it looks
QUITE good, even in closeup.
