POV-Ray : Newsgroups : povray.general : normal indices in mesh2 Server Time
28 Feb 2026 21:06:55 EST (-0500)
  normal indices in mesh2 (Message 1 to 5 of 5)
Subject: normal indices in mesh2
Date: 3 Aug 2005 14:25:00
Message: <web.42f10b6bc12bd03c1068d2140@news.povray.org>
can anyone explain to me how the normal indices work in mesh2? i have 2
normals for each of my vertex vectors, and i cant find a good documentation
of how the normal_indices are supposed to be set up. I know that if i have
the same number of normals and vertexs, then the indices are the same. but
if i have more normals, how do i tell povray which normals go with which
vertex? or does the normal_indice only work if you have less normals than
vertexs?
Subject: Re: normal indices in mesh2
Date: 3 Aug 2005 14:48:54
Message: <42f11196$1@news.povray.org>
>  but
> vertexs?
The reason for having more normals than vertices is so that adjacent faces
can use different normals on the same vertices, creating sharp transitions
between them (like at sharp edges of an object).
If you're generating the mesh yourself, and you have more normals than
vertices and you don't know how to use them, then it sounds like you don't
understand what you made the extra normals for (which would be weird since
you wrote the code yourself).
If your mesh is coming from an external program, I would have expected the
normal indices to be set up automatically.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 3 Aug 2005 15:35:00
Message: <web.42f11b35a43a55f01068d2140@news.povray.org>
yes, i knew this. sorry, i think my question was phrased poorly. i know that
i have twice as many normals because im generating a square
ribbon(molecular modeling) and thus have sharp corners on the ribbon. my
question was actually regarding the format of povray's normal indices. i
have been trying to figure out how to write the code itself. i have the
normals and vertexs calculated correctly, but i need to figure out how to
lay out the index correctly. I know that if you dont specify a normal
index, it just takes the index from your faces. but when i specify a
seperate normal index, what is the format? for example, if i have 2 vertex
points and 4 normals, how do i tell povray that the first two normals go
with the first vertex, and the second two with the second vertex? what
would that index look like? (obviously this isnt the best example since its
not a triangle, but it illustrates my question). Thanks!
Ben
Date: 3 Aug 2005 16:02:48
Message: <gGyL+BAFhR8CFwnS@econym.demon.co.uk>
>vertexs?
Place two vertices at the same point in space, and apply the different
normals to them. A polygon that needs the first normal uses the first
copy of that vertex and a polygon that needs the second normal uses the
second copy of that vertex.
Mike Williams
Gentleman of Leisure
Date: 4 Aug 2005 01:04:54
Message: <42f1a1f6@news.povray.org>
  Perhaps a well-commented example could help:
camera { location <0, 1.5, -3> look_at 0 angle 35 }
light_source { <5, 10, -1>, 1 }
mesh2
{ vertex_vectors
  { 4,
    <-1, -.5, 0>, // 0: leftmost vertex
    <0, 0, -1>,   // 1: mid vertex, closer to camera
    <0, 0, 1>,    // 2: mid vertex, farther from camera
    <1, -.5, 0>   // 3: rightmost vertex
  normal_vectors
  { 6,             // Normal vectors for:
    <-1, .5, 0>,   // 0: leftmost vertex
    <-.5, 1, -.5>, // 1: mid vertex (closer to camera) for left triangle
    <-.5, 1, .5>,  // 2: mid vertex (farther from camera) for left triangle
    <.5, 1, -.5>,  // 3: mid vertex (closer to camera) for right triangle
    <.5, 1, .5>,   // 4: mid vertex (farther from camera) for right triangle
    <1, .5, 0>     // 5: rightmost vertex
  face_indices
  { 2,
    <0, 1, 2>, // left triangle
    <1, 2, 3>, // right triangle
  normal_indices
  { 2,
    <0, 1, 2>, // normals for left triangle
    <3, 4, 5>  // normals for right triangle
  pigment { rgb 1 } finish { specular .5 }
