POV-Ray : Newsgroups : povray.general : tree macro question Server Time
19 Mar 2026 20:50:01 EDT (-0400)
  tree macro question (Message 1 to 5 of 5)
Subject: tree macro question
Date: 29 Jul 2005 12:30:01
Message: <web.42ea5964ab8cade7e32e54c40@news.povray.org>
I'm interested at some point in taking on writing a random tree macro.
Probably mesh-based. I would just like to know, from those who have written
them, where do you begin? What's the general theory for going about it? I
assume there is much recursion involved. If you begin with one triangle in
the mesh, how does the macro figure out where to place subsequent vertices
as it builds the tree? Basically, I want to know just how far over my head
just a task would be. ;-)
Subject: Re: tree macro question
Date: 29 Jul 2005 13:15:01
Message: <42ea6415@news.povray.org>
I use a good (and free) tree generator that exports to POV files :
ARBARO (http://arbaro.sourceforge.net/)
If you don't want to use it but you rather want to write your own macro, the
theory is well explained in the PDF file :
http://www.cs.duke.edu/education/courses/fall02/cps124/resources/p119-weber.pdf
If it can help you, as Arbaro is open source you can download the source
code and read it.
Good luck to your project
web.42ea5964ab8cade7e32e54c40@news.povray.org...
> written
Date: 29 Jul 2005 15:55:01
Message: <web.42ea890ee4b425a9e32e54c40@news.povray.org>
Hm, I guess the question I should have asked is more general... Supposing
that I want to create a mesh object which has random factors incorporated
into it's shape (not necessarily that of a tree), and that the mesh is
built at run-time through a loop of some sort, how do I make sure that it
remembers where it left off with previous triangles? How do I make the
vertices coincide if I don't know what they will be?
> code and read it.
> > written
Date: 29 Jul 2005 16:52:12
Message: <42ea96fc$1@news.povray.org>
I cannot answer you because
1) I don't exactly see what you want to do (even if I have a little idea)
2) my POV-level is quite poor
but, just a hint. Maybe the "trace" function could help you
Date: 29 Jul 2005 18:57:04
Message: <42eab440$1@news.povray.org>
>>code and read it.
>>>written
I think your "random factors" will have to be used to define some
general structure which is then subdivided in an organized way.   For
instance suppose you are doing a tree.  Suppose you have a way to
generate a realistic set of node points that mark the advance and
bifurcation of the branches.  These points can then be used to define
vectors which "connect" them.  Points can then be located around and
along these vectors in a regular grid as if the vector formed the axis
of the branch.  It would then be easy to loop through these points and
define a mesh of triangles before moving to the next "axis"
The variety of available splines, they can be curved as well as linear,
might provide an alternative stepping stone between random generated
nodes and a grid of vertices.
You might generate your random nodes in steps or all at once, but no
doubt you will have to store them either temporarily or in total.  You
will almost certainly use a structure such as an array or indexed file
to do this.
