POV-Ray : Newsgroups : povray.general : hi~, everybody, how to modulate two bmp files with the third bmp file? Server Time
10 Sep 2025 14:38:27 EDT (-0400)
  hi~, everybody, how to modulate two bmp files with the third bmp file? (Message 1 to 8 of 8)
Subject: hi~, everybody, how to modulate two bmp files with the third bmp file?
Date: 10 Mar 2005 03:45:00
Message: <web.42300839aa72325b598059850@news.povray.org>
For instance, I.ve got two files "wet.bmp" and "dry.bmp", and the third
file's name is "factor.bmp". All of them are of the same resolution,
256*128 for example.
Now, I want to use them to generate a new pigment. I've got the following:
#declare Wetting=function{ pigment {image_map{sys "wet.bmp"} }}
#declare Drying=function{ pigment {image_map{sys "dry.bmp"} }}
#declare Factor=function{ pigment {image_map{sys "factor.bmp"} }}
plane{z,-0.00001
    image_map {
      function 256 128 { pigment {
        color (1-Factor(x,y,z).gray)*Wetting(x,y,z) +
Drying(x,y,z)*Factor(x,y,z).gray     (*)
But when parsing, error message appears at line (*):
   Parse Error: Float expected but vector or color expression found.
It seems that (x,y,z), I use to locate the pixel, does not work. Maybe i am
still not familiar enough with the syntex of how to use
user-defined-fuction, and maybe there is an other way to implement what i
want to do.
So any advice will be deeply appreciated!
Subject: Re: hi~, everybody, how to modulate two bmp files with the third bmp file?
Date: 10 Mar 2005 04:10:00
Message: <web.42300df4a2703140c7fccea0@news.povray.org>
> want to do.
If I'm not mistaken, x,y, and z are reserved for the POV-Ray coordinate
system only.  Try using (X,Y,Z) for your functions.
Date: 10 Mar 2005 04:35:00
Message: <web.423013d6a2703140598059850@news.povray.org>
> > want to do.
Another error:
undeclared identifier X found instead.
Thx anyway!
Date: 10 Mar 2005 05:35:01
Message: <web.42302284a2703140598059850@news.povray.org>
> > > want to do.
> Another error:
> Thx anyway!
of course,if i add something like this:
#local X=0;
#local Y=0;
#local Z=0;
then Factor(X,Y,Z) would not to iterate inside the whole bmp, it just
extract the value at pixel (0,0,0).
Date: 10 Mar 2005 05:43:04
Message: <SVV3KEAZSCMCFwxB@econym.demon.co.uk>
>plane{z,-0.00001
>  pigment {
>    image_map {
>want to do.
Although POV defines colour functions, I'm pretty sure that you can't
use them as render-time colours.
At parse time you can pick individual colours from individual points of
a colour function, like
   #declare My_Colour = Wetting(1,2,3) * (1-Factor(1,2,3).gray);
You can use a render-time float function as PATTERN of a pigment, but
you can't use render-time colour functions as the COLOUR of a pigment.
So what you can do is to declare Wetting and Drying as simple pigments,
not functions, use the float function "Factor(x,y,z).gray" as a pattern,
and then use that pattern as a pigment_map to map two image_mapped
pigments, like this:
#declare Wetting = pigment {image_map{sys "wet.bmp"} }
#declare Drying = pigment {image_map{sys "dry.bmp"} }
#declare Factor = function {pigment {image_map{sys "factor.bmp"} }}
plane{z,-0.00001
    function{Factor(x,y,z).gray}
    pigment_map {
      [0.0 Wetting]
      [1.0 Drying]
I believe that gives you the particular effect that you were trying to
achieve. It's a lot less flexible than render type colour functions
would be, but you don't need that flexibility in this particular case.
Mike Williams
Gentleman of Leisure
Date: 10 Mar 2005 09:17:03
Message: <cjameshuff-060E72.09170110032005@news.povray.org>
In article <web.42300839aa72325b598059850@news.povray.org>,
> plane{z,-0.00001
>   pigment {
>     image_map {
Break the pigment out to see what's going wrong:
Put simply...you can't do this. There's no mechanism in standard POV-Ray
for taking a color function and using it directly as a pigment color. If
there were (and if this were corrected to extract gray values from
Wetting() and Drying()), this would still give a grayscale result.
It is possible, though...just a bit tricky. You have to average 3
separate pigments, with the colors multiplied by 3 to counter the divide
in the average so you can get a straight add.
pigment {average
    pigment_map {
        [1
            function {(1-Factor(x,y,z).red)*Wetting(x,y,z).red +
               Drying(x,y,z).red*Factor(x,y,z).red}
            color_map {[0 rgb 0] [1 red 3]}
        [1
            function {(1-Factor(x,y,z).green)*Wetting(x,y,z).green +
               Drying(x,y,z).green*Factor(x,y,z).green}
            color_map {[0 rgb 0] [1 green 3]}
        [1
            function {(1-Factor(x,y,z).blue)*Wetting(x,y,z).blue +
               Drying(x,y,z).blue*Factor(x,y,z).blue}
            color_map {[0 rgb 0] [1 blue 3]}
Oh, and for the sake of your disk space, bandwidth, and everyone else,
please don't use BMPs. PNGs let you do everything they do and more, are
compressed, and are lossless.
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 10 Mar 2005 21:10:00
Message: <web.4230fc88a2703140598059850@news.povray.org>
> plane{z,-0.00001
>   pigment {
>     pigment_map {
>       [0.0 Wetting]
>       [1.0 Drying]
> Mike Williams
wow~~,it works, firstly thks so much!
But will you pls to say something about how to use flexible colour functions
at render-time?
Date: 10 Mar 2005 22:45:01
Message: <web.423113d2a2703140598059850@news.povray.org>
> > plane{z,-0.00001
> >   pigment {
> >     image_map {
> pigment {
> pigment {average
>     pigment_map {
>         [1
>         [1
>         [1
Yes, i tried and it works, many thks!
