POV-Ray : Newsgroups : povray.general : glowing gem Server Time
10 Sep 2025 17:26:25 EDT (-0400)
  glowing gem (Message 1 to 5 of 5)
Subject: glowing gem
Date: 17 Feb 2005 19:55:00
Message: <web.42153bf93d1d3c88d536b1840@news.povray.org>
I need to simulate a glowing gem. Now I know we cant get things to glow on
their own and there is something called radiosity that can simulate this. I
have never used radiosity before though. The object in question is just a
simple blue sphere. what coding can I put to make it simulate glowing?
Thanks for any help.
Subject: Re: glowing gem
Date: 17 Feb 2005 20:47:29
Message: <42154931$1@news.povray.org>
I
Although radiosity can be used with a high ambient value to cause an object
to emit light, it's probably better to just use an actual light_source with
the looks_like keyword. To make the sphere itself appear bright, you can use
a high ambient value or emission media; this was recently discussed briefly
in the thread "Grr... I want it to GLOW!!!" in povray.newusers.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 17 Feb 2005 21:59:30
Message: <1603814.7XZ3tFSLxF@raf256com>
> object to emit light, it's probably better to just use an actual
> light_source with the looks_like keyword. To make the sphere itself appear
> bright, you can use a high ambient value or emission media; this was
> recently discussed briefly in the thread "Grr... I want it to GLOW!!!" in
> povray.newusers.
To summ up:
ambient:
+ very soft shadows, exacly same shape as object
- light comming from radiosity can not cause speculars and other light
effects
light_source:
+ fast
+ can produce highlights, photons, media, and so on
- is only a point (shadow can look like cased from sphere, rectangle or box)
union of many small light_source:
+ is very accuarate, can be almost as detailed as ambient-based light
- is very slow
+ but can be speeded up using light_group
So I would suggest to combine this light models, in example
* an ambient object
* light_source in center with smooth area_light
* few smaller light_sources with less detailed area_light, number and
quality based on scene quality settings
Rafal Maj Raf256
Date: 17 Feb 2005 22:13:46
Message: <42155d6a@news.povray.org>
  That depends on whether you want it to just emit light or whether
you want a visible halo around it.
Date: 17 Feb 2005 22:15:15
Message: <42155dc2@news.povray.org>
  The looks_like object is shadowless, and in the case of a softly
glowing gem, it probably should not be.
  Just create the gem and put a light source inside it and that's it.
