POV-Ray : Newsgroups : povray.general : Help creating a 5-pointed gem like star Server Time
3 Oct 2024 08:17:52 EDT (-0400)
  Help creating a 5-pointed gem like star (Message 1 to 8 of 8)
Subject: Help creating a 5-pointed gem like star
Date: 12 Nov 2004 06:55:01
Message: <web.4194a37fc3889db3abbc0b2f0@news.povray.org>
I've been out of the POV scene for quite a few years (since I left
compuserve!) and I'm trying to get back into it.
I'm attempting to create a 3D 5-pointed star that is faceted like a gem,
kind of like this
http://www.lidinc.com/Merchant2/graphics/00000001/SM%20STAR%20K166%20GIF.jpg,
and it's bugging me.  I know I could create it by calculating the points
and putting them into a mesh, but there must be a simpler way of getting
POV to do all the hard work.
Any pointers/links etc would be really helpful.
Many thanks
Dan
Subject: Re: Help creating a 5-pointed gem like star
Date: 12 Nov 2004 08:50:00
Message: <web.4194bf2d8348af124f8e18070@news.povray.org>
> kind of like this
> Many thanks
> Dan
Using math, and pyrimids, I think you might be able to create one
pretty easy.
Date: 12 Nov 2004 10:15:00
Message: <web.4194cc3d8348af12abbc0b2f0@news.povray.org>
> > kind of like this
> > Many thanks
> > Dan
> pretty easy.
Seeing as there isn't a pyramid primitive (please correct me if I'm wrong)
are you suggesting using cubes and plane intersections?
Date: 12 Nov 2004 10:41:56
Message: <Xns959FA9DF23052jgrimbertmeandmyself@203.29.75.35>
> wrong) are you suggesting using cubes and plane intersections?
What about using a prism with a conic sweep for half of it. Then mirror it.
l'habillement, les chaussures que le maquillage et les accessoires.
Date: 12 Nov 2004 13:09:33
Message: <dRnfYAAJxPlBFwFG@econym.demon.co.uk>
>kind of like this
How about using five stretched octahedrons, something like this but with
better material and lighting?
#version 3.6;
global_settings {
  assumed_gamma 1.0
  max_trace_level 15
camera {location  <-4,5,-20> look_at <0,0,0> angle 40}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#include"shapes.inc"
#include"shapes2.inc"
#include"glass.inc"
union {
  #declare N=0;
  #while (N<5)
    object{Octahedron
      scale <1,1.9,1>       // stretch in y direction
      rotate y*45           // bring an edge to the front
      translate y*1.3       // move away from centre
      rotate z*360/5*N      // rotate each point
    #declare N=N+1;
  texture {T_Old_Glass}
  interior {I_Glass1}
Mike Williams
Gentleman of Leisure
Date: 14 Nov 2004 15:00:04
Message: <4197b944@news.povray.org>
"busabus" <nomail@nomail> wrote in message
news:web.4194a37fc3889db3abbc0b2f0@news.povray.org...
The more I think about this the more I think a mesh is the way to go.
Not really that hard - build your mesh using a macro.
Date: 15 Nov 2004 09:50:00
Message: <web.4198c12c8348af12abbc0b2f0@news.povray.org>
Thanks to everyone for their help on this.  I ended up going down the
intersection route by cutting a cube into what I'd call a sloped three
sided pyramid, then squashing it, copying it, squashing that and copying
that.
#include "glass.inc"
camera { location  <-2, 0, -4> look_at <0, 0, 0> angle 40}
background { color rgb 1 }
light_source {<5,5,-5> colour rgb 1}
#declare starGlass =
  pigment{rgbf <1,1,0,0.8>}
  finish {F_Glass9}
#declare facet =
difference {
  box {<-0.5001,0.5001,0.5001> <0.5001,-0.5001,-0.5001>}
  object {
    plane {z,0}
    rotate <45,0,0>
  object {
    plane {x,0}
    rotate <0,0,-45>
  translate <-0.5,0.5,-0.5>
  scale<0.5,1,0.5>
  rotate<0,-45,0>
#declare point =
merge {
 #declare i=1;
 #while(i<=4)
 object{facet
        rotate<0,90*i,0>
        translate<0,0,0>
 #declare i=i+1;
 scale<0.75,1,0.5>
merge{
  #declare i=1;
  #while(i<=5)
  object{point
         rotate<0,0,72*i>
  #declare i=i+1;
  texture {starGlass}
  interior {I_Glass1}
  photons {
     target
     refraction on
     reflection on
If anyone's got some comments on this code then please feel free.  Also
suggestions on getting the gem to sparkly a bit and not look like crap I
would be grateful for.
Daniel
Date: 17 Nov 2004 15:48:19
Message: <419bb913$1@news.povray.org>
Not nice enough for a subject item. Good enough for something small.
> Also suggestions on getting the gem to sparkly a bit and not look
> like crap I would be grateful for.
Add more facets. You really need to just make this a mesh.
  -Shay
